Mutant MIG-MCS2 - M-wonder Ipod Dock With Logo
D
Douglas Voss Posted on Nov 18, 2014
How do I set the time on my M-Wonder 2 Mutant MIG-MCS2?
Trying to figure out how to set the time on my ipod dock? I have the remote & the buttons on the system, but no manual. Any info would be greatly appreciated.
Joe
Level 1:
  • Contributor 55 Answers
  • Posted on Nov 25, 2014
Joe
Contributor
Level 1:
Answers
55
Questions
0
Helped
18724
Points
89
Try e-mailing the manufacturer http://www.mutantinnovation.com/
requesting a PDF User Manual
Can you get me a remote control for my Mutant MIG-MCS-2
Sorry we do not sell parts but you can try the company at the link below.
1 800 Remotes
2answers
3helpful
Anyone know how to set clock on iCoustic A-101 iPod Dock/Clock Radio?
Ok I have this figured out, if it's the A-101a dock, with the power turned off, double click the MEM/SET button, that will get you there! Choose from format first (24/12 hour time) then click again for hours and minutes. Took me ages, just figured it out!
I am trying to connect my Onkyo DS-A3 ipod dock to my Onkyo TX-SR508 receiver and I cannot get the TV to display the ipod menu. I've connected the red and white (R/L) and yellow video cable to the...
Is OSD set to ON? See below
Set the OSD (onscreen display) mode before you start using the RI Dock. 1. Plug in the AC adapter. 2. Turn on your TV and amp, and select the appropriate inputs on your TV and amp. 3. Insert your iPod into the RI Dock. 4. Select the video output mode depending on the video connection. While pressing the remote controller's [SETUP] button, press the Up [ ] button for the component video connection, press the [ ] button for the composite (default) connection. 5. Use the remote controller's [MODE] button to set the OSD mode. On: Playlists (artists, albums, songs, and so on) are displayed on your TV, and you can navigate and select your music or video while looking at your TV. While this mode is selected, your iPod displays the Onkyo logo. Off: Nothing is displayed on your TV and you navigate and select your contents by using your iPod's display.
6helpful
2answers
I have an i-connex ipod docking station model 583258 with clock/alarm and radio but I have been unable to set the clock as I have mislaid the instructions. I am usually pretty good at working these things...
1. Fit the DC power and switch on the appliance by pressing the standby button 2. To set time, press CLOCk button to alternate between 12 and 24 hour format. 3. Press and hold CLOCK button until the set hour flashes on display 4. Adjust time using SKIP/SEARCH 5. Press CLOCK to set the time, same procedure for minute
To set alarm
1. Press AL SET 1/OFF 1 button, then press and hold the same button until the alarm time starts flashing 2. Press SKIP/SEARCH to to set time as above
14helpful
Lost my manual for the NP 105CR Model Next Play IPOD Dock cube. Can't figure out how to turn off a radio alarm which comes on at odd times.
The Alarm is controlled by the Set button. Press Set once, then press Function to cycle through Alarm 1 functions until the display reads OFF. If needed, press Set again, and press Function until Alarm 2 also reads OFF. Press Set a third time, and you can set the main time with the Vol +/- (minutes) and the Skip (hours) buttons. Press Set a fourth time to return to normal display.
20helpful
6answers
Bose Sound Dock remote control - only volume works
My remote worked perfectly until I changed the battery. The original battery was CL 2032 and I replaced it with DL 2032. After replacing the battery, only the volume control works. The off button will only fade the sound while the button is depressed. Release the button, and the volume returns to the original level and the unit remains On.
None of the other buttons work.
If you've found a solution, please post it here.
1helpful
Remote won't control my 4th generation ipod nano
Hey I figured it out. When you bought the 4th generation ipod nano it came with it's own dock insert. It fits perfectly and fixes everything, including the remote issues. Now my only problem is I have a black ihome and a white insert :( Good luck!
92helpful
Alarm clock and time w/ clok smooth ipod system
According to the instructions that we received with our clock. You should be able to get the Instruction manual from [email protected]. It is also supposed to be under the support section of the website www.dpi-global.com but I couldn't find such a link.
However the "Operational Support" insert has the following:
Setting the clock
1. With the unit powered off, press and hold the "Clock/Display/Play/Pause Button" for at least 4 seconds.
2. While holding the "Clock/Display/Play/Pause Button", press the "Hour" and "Minute Buttons" to adjust the hour and minute on the time.
3. When the correct time is selected, release the "Clock/Display/Play/Pause Button" to set the clock
Setting the Alarms
1. With the unit powered off, press and hold the "AL1" or "AL2" Button for at least 4 seconds.
NOTE: An alarm icon will begin to flash on the LCD display.
2. While holding the "AL1" or "AL2" Button, press the "Hour" and "Minute Buttons" to adjust the hour and minute on the alarm time.
3. When the correct time is selected, release the "AL1" or "AL2" Button to set the clock.
4. Press the "AL1" or "AL2" Button consecutively to switch alarm one and alarm two between sounding to a buzzer, the currently set radio station, or a docked iPod.
3answers
IPod Nano will not shutdown
turn hold button on and off, then press the menu and centre key at the same time to reset it. T
Top Mutant Audio Players & Recorders Experts
 Grubhead
Grubhead
SmartAviator
SmartAviator
Are you a Mutant Audio Player and Recorder Expert? Answer questions, earn points and help others
