Question about Vizio Televison & Video
A Thin black horizontal line developed in 70" Vizio LCD LED television, it is slightly wider on the far left side and narrows and virtually disappears on the right hands side. You can also see back li
Below are links to pictures of my problem. White background: http://i62.tinypic.com/2h4i61s.jpg White test pattern: http://i62.tinypic.com/2a7x402.jpg
    Top Expert:
  • Vizio Master
  • 74,136 Answers
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Line, faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent.
Posted on Nov 18, 2014
  • 4 Answers
SOURCE: Red lines on right hand side of the screen now no picture on right hand side!
I'm not an expert, but I have determined that the vertical bars that are often red, sometimes blue ... and sometimes both ... are related to a bad control board. I've also read that a common fix is to buy a repair kit with includes the ysus, zsus and control boards ... all replaced together. My experience was that after a month or two with the 1.5" wide stripes, that you eventually loose the entire picture and have sound only. MIne comes back, but won't stay working for very long and the stripes are always there (buy used to fade and flicker sometimes). I'm planning on replacing the control board.
Posted on Jul 17, 2008
  • 298 Answers
SOURCE: JVC PD-42DX6BJ plasma 42 inch black horizontal lines over the pic
Here's a link to order the original the JVC upper Y-buffer board and lower Y-buffer board for this model from a major parts distributor if needed:
JVC "PD-42DX6" Replacement Part Upper Y - Buffer Board (LJ41-02760A)
JVC "PD-42DX6" Replacement Part Lower Y - Buffer Board (LJ41-02761A)
Based on the symptoms: It is possible that the Y-buffers are faulty, which may require the replacement of the Y-sus board as well. You may want to get a local technician to diagnose the unit and provide a second opinion.
Posted on Apr 01, 2009
  • 2509 Answers
SOURCE: My new Samsung UN65C8000 LED TV has an
You did not say if the first one went back for the same fault. If it went back for a different fault then this set is faulty! If not then unless it it more susceptible to RF interference possibly mains borne than the flawless set (that is possible) and you have some other equipment in the house which is radiating like a power supply or dimmer or whatever, it must be faulty. Turn everything in the house off just to be sure nothing is causing interference. Even then it could be picking up interference from elsewhere. What affects it or does it seem random (position time of day etc.)? The only way to be truly sure is to try it in another location
If it's new why not return it?
Posted on Feb 16, 2011
SOURCE: Polaroid 40 inch tv (TLX-04011C) Picture is
its the ribon cables from the lcd patern bords on top there is 2 of them normaly its the right side that goes bad but in your case its the left there is only 1 way to fix it
you have to replace the lcd screen panel with the 2 pattern bords on top
Posted on Nov 12, 2011
SD Tech
  • 14553 Answers
SOURCE: LG 37LE5300 HAS HALF BLACK SCREEN
THIS set uses 2 boards inside--one drives the left and the other the right side of the screen.
You have to id which is which (GOOGLE?) AND replace it-every brand has different names for these but it sounds like your problem
Some research (you or me) should give a board breakdown for this model---not looking for main or power board but another like sustain etc. and there will be 2 listed (for right and the left sides)
Posted on Mar 25, 2012
SAMSUNG - UE40F6670 LED TV - I have thin black horizontal lines appearing in upper half of screen. They get lighter as the TV warms up but don't go away.
IMPORTANT: Horizontal lines on the screen are virtually NEVER caused by a bad T-con board. Horizontal lines indicate a defective LCD panel (screen). Check ribbon connectors coming from screen and the T-con board first but likely the Panel.
Dec 28, 2016 | Samsung Televison & Video
Vizio VW46LFHDTV10A vertical lines on either side of the screen. I tapped screen and left side lines disappeared.
If you wish to get some details; check the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/ Line faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
Oct 27, 2016 | Vizio VW46LFHDTV10A 46 in. LCD TV
My Vizio developed a black circle in the bottom corner. Eventually, the black circle disappeared. Now when I turn it on these horizontal lines develop on the bottom of the screen. Any ideas?
Sep 08, 2016 | Vizio Televison & Video
How do I fix vertical lines on my TV?
Line Defects On Vizio TV Screens - Vizio TV Help
vizhdtv.com/line-defects-on-vizio-tv-screens/
Aug 26, 2015 - If you see a line on your TV screen it might be the result of several causes. Some might be simple to fix and others may actually require you to replace theTV. Pixels on a TVs display panel are organized in groups of straight vertical lines. ...Notice the line defect above is red but they can be white, green, ...
how to repair vizio lcd tv vertical lines then fail - YouTube
? 17:05
https://www.youtube.com/watch?v=YUKMl7_19gk
Jul 5, 2014 - Uploaded by bam6972
how to repair vizio lcd tv vertical lines then fail ... I do know quite a bit, not everything but I do know my fair share about tvs. this tv needed a new ...
TV Repair Help for Vertical & Horizontal Lines on Your TV ...
? 2:47
https://www.youtube.com/watch?v=b0sI7LB4cZE
Apr 25, 2014 - Uploaded by ShopJimmy.com
TV Repair help with troubleshooting lines on your TV Screen. ... I have Vizio M470SL. My TV has .... Why does my T.V. suck Don't buy Rca T.V..
Jan 19, 2016 | Vizio E480-B2 48" 1080p 60HZ LED HDTV
My 42 in phillips LCD flat seen has a black horizontal line toward the bottom how can I fix this.
Samsung LN46B650 Thin Black Horizontal Lines - Forums - CNET
www.cnet.com > Forums > Samsung
CNETI'm experiencing thin black lines from the top of the screen to the bottom. ... by babes808gpa / January 15, 2010 1:42 AM PST ... lines are about 1/4 inch apart from top to bottom of screen. starts on the right and about a 1/3 of the way toward the ...have the exact same problem, my lcd tv has multiple lines are horizontal it ...
Faulty HD- LCD - LED TV - Horizontal Lines STRIPS on the ...
? 3:05
https://www.youtube.com/watch?v=KiqJuMiEiak
Jun 8, 2013 - Uploaded by Sameh Moustafa
Faulty HD- LCD - LED TV - Horizontal Lines STRIPS on the picture SOLVED .... I just have one black line ...
? 2:47
Dec 20, 2015 | Televison & Video
2 days ago, a narrow black horizontal line appeared in the middle of the screen.
CNETJun 11, 2015 - I'm experiencing thin black lines from the top of the screen to the bottom. ... my lcd tv has multiple lines are horizontal it starts from the right and fades too the left, ... Samsung LN55a950 - Horizontal lines on right side - Forums - CNET
Jun 11, 2015
Samsung 52" LCD TV black lines - Forums - CNET - CNET.com
Jun 10, 2015
More results from www.cnet.com
Plasma TV Repair Horizontal Lines - How to Diagnose ...
? 2:49
https://www.youtube.com/watch?v=h4XWCxUsSVU
Sep 2, 2014 - Uploaded by ShopJimmy.com
I have thin horizontal black lines on the top and bottom areas of my TV. .... Hi, I have a 2011 64-inch 3D Samsung PN64D8000 Plasma TV.
how to fix horizontal or vertical lines on lcd tv - YouTube
? 4:52
https://www.youtube.com/watch?v=k2QpYJp6MU8
Apr 12, 2014 - Uploaded by cr4zyw3ld3r
Hi my LG 47ln5700 tv set has thin greyish black horizontal lineson one side of the .... I hope this works good with Samsung LCD as well....
Dec 19, 2015 | Samsung HP-R5072 50 in. Plasma HDTV
Any idea on what is causing these issues with Vizio TV? Black lines horizontal, shadow vertical.
Line, faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent. Line faults to all LCD TVs will be similar, irrespective of its screen size and brand.
Jul 27, 2015 | VIZIO M701d A3R 70 Inch 1080p Smart
Vizio 32 inch thin black vertical line on left side of screen
it is very likly you have problem with the buffer boards, sometime help to unplug conector and reconect, also check the smd fuse located on one of the boards since there are 2 buffer E&F.
Jan 09, 2013 | Vizio 32" Lcd Hdtv E320VA Hdmi Hd Tv Flat...
Horizontal lines on 42" vizio LCD
i have the same problem. any solution
Dec 21, 2009 | Vizio VW42LF 42 in. LCD HDTV
Vertical line on LCD TV Panel
Had this same issue on right side of 52" about 1 inch from side but had 3 vertical lines that disappeared after 40 minutes. Have Samsung LNT5265FX/XXA and about 16 months old. LCD Panel itself had to be replaced to fix it, fortunately had extended service plan
Oct 17, 2008 | LG 42LC2D 42 in. LCD HDTV
Televison & Video Logo
91 people viewed this question
Top Vizio Televison & Video Experts
CoppellTVRepair.com
Computer Repairing
Computer Repairing
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
