Remove stand body - Televison & Video
    Top Expert:
  • Televison & ... Master
  • 74,136 Answers
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Disassemble procedure to many popular brand TVs and other devices are given in detail with illustrations.
Posted on Nov 18, 2014
What does Err3 mean on taylor body fat scale?
Remove your shoes and socks and wet your feet slightly with a damp cloth if you receive the "ERR3" error. ERR3 is a contact error and your feet should ideally be bare and wet to achieve an accurate body-fat reading.
  • Step off the scale and wait for it reset. Remove your shoes and socks and wet your feet slightly if you receive either the "ERR4" or "ERR5" errors, which means your body-fat or body measurements are out of range.
  • Reset the scale if it doesn't work or you continue to receive error messages. Remove the battery and set the scale on a flat surface. Stand still on the scale for five seconds and step off. Re-install the battery and place the scale back on the flat surface. Place one foot on the scale until it displays zeros or dashes. Remove your foot and wait for the scale to turn off. Step back on the scale to weigh yourself
  • Sep 28, 2016 | Taylor Health & Beauty
    I have wall mount and now I need remove the pedestal stand from the TV. But I have lost the manual and can some body explain the steps to remove the stand? Thank you
    Without knowing the model of your TV, it may be tough, but typically it's 1 or 3 types:
    - the whole base is a single piece that slots into the bottom of the TV, with a clip release.
    - the base removes from the stand, and the stand removes from a slot in the TV. This may be fastened with clips or screws.
    - the base is screwed into the TV, and you'll have to remove these to remove the stand.
    If that doesn't help, please provide more details, like the make and model of your TV.
    Dec 18, 2014 | Televison & Video
    Rack remove steering
    try jacking up the body while leaving the front wheels on the floor. When the body is as high as you can get it . USE JACK STANDS UNDER THE BODY to support it as there is no room for error if the jack gives way.
    Dec 18, 2013 | 2002 Ford Explorer
    How to take a transmission out of a truck without it on a lift
    There are car ramps that give enough clearance to be able to remove tranny from beneath vehicle. Most jack stands are too short for same. in the past I have had to do this, and with car not moving, required jacking truck up jjust to get ramps in place under tires. not fun but possible.
    Sep 28, 2013 | Cars & Trucks
    96 monte carlo idle fluctuates when standing still. Also lights go dim when idle drops. changed both O2 sensors, battery, tensioner belt, and altenator. Mechanic thinks its the choke sensor but knows...
    Hello and welcome. sounds like the throttle body may be just dirty. remove hose from air cleaner to the throttle body. clean out the throttle body bore and around the throttle body with some throttle body cleaner. then retest and see if the problem is repaired
    Dec 20, 2011 | 2001 Chevrolet Monte Carlo
    2004 jeep code 1763 what to do
    P1763 - Governor Pressure Sensor Voltage Too High
    This code is refer for the governor pressure sensor which is located in the valve body of the transmission. If getting power to the sensor and the wires are not open or shorted then the sensor will need to be replaced.
    GOVERNOR SOLENOID AND PRESSURE SENSOR
    REMOVAL
    Hoist and support vehicle on safety stands.
    Remove transmission fluid pan and filter.
    Disengage wire connectors from pressure sensor and solenoid (see picture)
    Remove screws holding pressure solenoid retainer to governor body.
    Separate solenoid retainer from governor (see picture)
    Pull solenoid from governor body
    Pull pressure sensor from governor body.
    Remove bolts holding governor body to valve body.
    Separate governor body from valve body
    Remove governor body gasket.
    INSTALLATION
    Before installing the pressure sensor and solenoid in the governor body, replace O-ring seals, clean the gasket surfaces and replace gasket.
    Place gasket in position on back of governor body
    Place governor body in position on valve body.
    Install bolts to hold governor body to valve body.
    Lubricate O-ring on pressure sensor with transmission fluid.
    Align pressure sensor to bore in governor body.
    Push pressure sensor into governor body.
    Lubricate O-ring, on pressure solenoid, with transmission fluid.
    Align pressure solenoid to bore in governor body
    Push solenoid into governor body.
    Place solenoid retainer in position on governor
    Install screws to hold pressure solenoid retainer to governor body.
    Engage wire connectors into pressure sensor and solenoid Install transmission fluid pan and (new) filter.
    Lower vehicle and road test to verify repair.
    1 - PRESSURE SOLENOID RETAINER
    2 - GOVERNOR
    1 - PRESSURE SENSOR
    2 - PRESSURE SOLENOID
    3 - GOVERNOR
    Hope helps.
    Sep 29, 2011 | 2004 Jeep Grand Cherokee
    How to change transmission filter on a 1997 grand am GT
    The filter is located inside the transmission pan. I prefer to do this procedure with the vehicle sitting level up on four jack stands. Position the jack at the lower body flange and at the center of the vehicle towards the front slightly. lift the vehicle in the air high enough to install two jack stands at each end of the body at the lifting pads. lower the vehicle onto the pads. roll the jack under the body and lift the other side up to the same height and place the other two jack stands in the same place on the other side. Place a large pan under the transmission pan and loosen all the pan bolts but do not remove them yet. Fluid will start to run out of the sides of the pan. Slowly loosen the bolts that are farthest away from you while holding the pan with your other hand. Drain more fluid out by slowly lowering the pan with your other hand. Once the fluid has stopped coming out, press the pan back up against the transmission and remove the rest of the bolts. Lower the pan straight down and place it in the drain pan. The filter should now be visible. It will either be held in by a single bolt or press fit into place. This is a messy job so, wear old clothes and always wear safety glasses when performing this procedure.
    CAUTION : Use quality jack stands for this procedure. The gasket is usually reusable.
    May 17, 2011 | Pontiac Grand Am Cars & Trucks
    Trans valve body removal
    Start by elevating the vehicle and supporting it on jack stands.
    the removal of the transmission pan will expose the valve body (removing the filter and replacing that and the gasket will be a good idea) there are a few 10mm bolts that hold the valve body in place. just reverse the order of removal to finish the installation.
    Apr 26, 2011 | Nissan Maxima Cars & Trucks
    Can't take apart the body on the mixer
    from what i can see you need to remove the mixer head assemble which has a retainer that i havent been able to remove from mine as yet. need a special retainer pliers and you need to remove the rear stand asemble. i have not figured that out yet either. there are no screws under the logo plate. and the screws on the body only loosen the inner assembles, motor and such. this is a tough nut to crack. mine overheats kneading bread and i want to ad a fan.
    Jan 04, 2009 | Hamilton Beach 63221 Stand Mixer
    Televison & Video Logo
    Top Televison & Video Experts
    Electro Med Services...
