I can't get no sound from my receiver to my speakers! I have the rca tr2760
  • 31 Answers
Make sure your speaker selection is correct with the actual outlets on the back/ check if muted
Posted on Nov 18, 2014
RCA RT2770 Sub-woofer sound doesn't come
The sub should generally have its own power supply, is it plugged in ???
Feb 16, 2016 | RCA RT2770 Theater System
Connecting tv external speakers
If you connected R/W RCA cables to the AUDIO OUT RCA jacks on the rear of the TV and connected the other ends to the TV AUDIO IN jacks on the receiver, you should be able to select an input on the receiver that will deliver sound to the Bose speakers. If you went to TV setup and selected external speakers, you directed output from the TV amplifier to external speakers which is not what you want.
Jan 27, 2014 | Televison & Video
I have marantz Av surround receiver model SR301 I have tried a lot but I am having sound from only 2 speaker when I put in setero mode but when I put in surround no sound from any speakers I checked all...
First off you will need to do a little bit of trouble shooting. Is the source (dvd, Blu-ray, cable box, etc...) plugged into the receiver with the standard red and white RCA cord or by an optical (toslink-fiber optic) or digital RCA (orange color code). If you are connected with a standard RCA cord then that it your problem and you need buy digital cord that both the source device and the receiver can accept (toslink - http://www.we-supply.com/browse.cfm/optical:-audio/2,779.html or Digital RCA). If the connection is now correct then you need to make your receiver do a "test-tone" to insure that a signal can be sent to every speaker (this is an internal test that just checks the speaker connections). If the tone tone operates correctly then you know the amplifier is functioning. If both of the mentioned things are now done and still not surround output then you need to check the internal menus on your source device and make sure that it does not require you to manual change a setting in the audio menu to make it work (i.e. change from 2-ch 44KHz to 5.1 or 7.1 or Dolby Digital or AC3 or some other surround sound protocol.)
Austin
www.we-supply.com
Aug 08, 2013 | Audio Players & Recorders
I have a Vizio Flat Screen TV. I have speakers in all the rooms in my home. Can the TV be hooked up to the speakers with any success?
yes, the TV can be hooked to the speakers, but you will be needing a receiver (amplifier).
Check your TV, if you will have any earphone input space. If you find it on the TV, then it means job is half done.
Get a 3.5mm to RCA cord, connect the 3.5mm part to your TV's earphone space (if any), then connect the RCA part (Red and White) to input (Aux/Video/CD in etc) at the back of your receiver (amplifier) or deck, select the input (Aux/Video/CD in etc) on your sound system (receiver/amplifier) and sound should come out of the speakers.
Also, you can use this same method, but this time with a different wire which is RCA to RCA.
Connect the RCA (Red and white, to "Output" or 'Out' at the back of the TV, then connect the other part to the "Input" of your sound system (receiver/amplifier).
Good luck.
Dec 02, 2010 | Televison & Video
Connecting computer speaker to a receiver
Which output section of the Denon are you using? Tape monitor out? And are you getting sound through the speakers (not the PC speakers) that are attached to the Denon speaker terminals?
Oct 26, 2009 | Denon AVR-1601 Receiver
Yamaha HTR-6130 sound only from centre, rear or front speakers
its not how there connected its in your settings. rehook up all your speaker connections properly,then make sure you proram the reciever to recieve fiber optic,hdmi,digital coax etc in the reciver.
May 18, 2009 | Yamaha HTR-6130 Receiver
RE: RCA RT2500 Receiver
take the cable of right speaker(which is ok)and put it instead of the left cable if it is ok-your problem will be in your left speaker or its cable-if it is not working the problem in your receiver output stage.(left channel path problem)
May 18, 2008 | RCA RT2500 System
Cables
you coudl use a single rca to a left and right rca cable. However most woofers will have a lfe single rca input on the woofer that you connect to a single rca on the receiver.
Are you sure you are not confusing the +/- on the woofer that is used to connect your speakers? ie. my woofer has the +/- so i can connect to my front speakers and my receiver to filter the low frequency sounds via the woofer.
hope this helps
smeags.
Feb 19, 2008 | Sony STR-DE575 Receiver
No Sound
Maybe the speakers are no good. Have you tried hooking up a different set of speakers?
Oct 11, 2007 | RCA RT2500 System
No sound to right speaker
It's probably just a cable problem. Reconnect the RCA cable from the receiver to the right speaker and even try to replace the cable. Good luck.
Jan 19, 2006 | Yamaha HTR-5250 Receiver
 Grubhead
Grubhead
