Question about Rinnai 110,000 BTU condensing wall-mounted gas boiler - E110C
I'm getting a e 06 code and it shuts down the boiler
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 69 Answers
This should be a overheating issue , check for clogged blocked exhaust vent pipe , and make sure there is enough water flow .
A boiler tech may be needed as boilers can be dangerous if not serviced properly .
Posted on Nov 30, 2014
I have a laars mascot combi boiler which keeps shutting down showing error 41.what is the cause?
The only code I can find is 47 which is clean flame sensor there is a video on u tube on your boiler which may help you
Dec 27, 2017 | Water Heaters
The screen displays "LOCK OUT APS FAIL (close)"
sounds like a service call wold be in order . things like boilers and furnaces are best left to the pro's
Feb 16, 2015 | Water Heaters
Boiler will not switch off
Morning, Many answers to this question. But usually if your timer is not shutting down you boiler its time to replace the timer. Try removing the boiler leads on the timer. (the loads). To see if this shuts down your boiler. We can try this step first.
Jan 11, 2014 | Hardware & Accessories
Hansgrohe Ecostat (with part 94282000 thermostat). Shower runs fine for a few minutes then boiler shuts down and shower runs goes cold. Boiler starts up again after 30 seconds and runs fine for a few...
Check the 94282000 cartridge for debris on the filters. If your boiler requires a certain flow rate to come on, then you must get enough flow through the cartridge to make that happen. Also, if your boiler is producing very hot water, the cartridge will self regulate and reduce the hot flow accordingly. try lowering the output temperature of the boiler to resolve that possibility.
If you need further assistance, you can call us direct at 800-334-0455
Sep 03, 2011 | Home
Ferroli boiler error code A3
boilers need a certain amount of water pressure to operate as specified--there may be a pressure regulator valve, allowing a certain amount of water to your boiler, and when water is drawn elsewhere, there may not be enough getting to the boiler---this is one possible solution, but there are easily 20 more, and that is where a trusted plumber is worth it's gold...very difficult to diagnose most plumbing problems without being onsite
Mar 03, 2010 | Water Heaters
Code 13 help... Everytime I go to use the shower (a mixing system of hot and cold) Code 13-- Code 12 the system shuts down. If I just use hot or cold I am fine-- Any one?
if cold supply to boiler and shower are off the same feed this could be your problem as the boiler governs flow of hot water best of luck
Oct 20, 2009 | Rheem EcoSense by 4.2 GPM Tankless Water...
I have Crown Tobago boiler that cut off two days ago
Possibly due to a power failure, control unit needs to be reset. Hit reset button. Hold for 30 seconds. Also no fire typically due to nozzle clogged, no fuel which means control will shut down. Water in fuel will also shut boiler down. Clogged filter will decrease fuel flow. Electric eye face is dirty which will also shut it down. If you have a two line system, open up bleeder and see if you get a good flow. Check electrodes for burned ends or out of gap specs.
Aug 04, 2009 | Water Heaters
Pressure upto max nearly im my bolier
You don't say what kind of boiler this is but I'm going to guess that it is a hot water boiler.  If so, you have a combination valve which adjusts the water by pressure and bleeds off excess.  These valves do get corroded and dirty.  Shut down the boiler, shut off the feed water valve.  Replace the valve assembly.  Do not try to adjust these things.  Your new valve should maintain about 15 psi.
Dec 19, 2008 | Heating & Cooling
Rinnai 110,000 BTU condensing wall-mounted gas boiler - E110C Logo
82 people viewed this question
Top Rinnai Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
vance jones
Are you a Rinnai Heating and Cooling Expert? Answer questions, earn points and help others
