Question about connector. control module. transmission control module. . sky
What does a transmission control module look like
  • 603 Answers
This part you refer to is also called a transmission solenoid. It's difficult to tell you what this part looks like, because everyone looks different. I can tell you this ,some are on the outside of trans, and some are on the inside of the trans over the valve body. You would have to drain pan, drop pan, and drop valve body. I would recommend you take it to be done. GOOD LUCK FRIEND.
Posted on Nov 18, 2014
Where is transmission module located on 2002 Chevy siverrod truck 5.3 engine
Transmission control module is part of the PCM - powertrain control module . Engine an transmission module all in one . It's in the engine compartment .
Powertrain Control Module (PCM) 4.8L,5.3L,6.0L
Near the left front inside the engine compartment
Apr 24, 2017 | Cars & Trucks
Tip
I get code p0700 after an OBDII scan.
P0700 Transmition Control system is the transmission control module.
The transmission control module is a separate computer module, you need to read codes stored on transmission control module.
If there are no transmission code stored, then there is a bad Transmission Control Module (TCM) ground circuit or a bad TCM. In that case the ground to TCM must be tested, and TCM eventually replaced.
Faults that can cause troubles when shifting from first to second gear are : transmission fluid, speed sensor, TPS, transmission shift solenoid, gear box problem, TCM, neutral switch, torque converter problem.
The best thing to do is scanning TCM codes.
on Dec 02, 2009 | Jeep Wrangler Cars & Trucks
The transmission control box mounted under the cubbyhole keeps on beeping when i drive my toyota verso
What is a transmission control module? A transmission control module makes adjustments based on the data it collects from the different signals it receives. Some of the sensors that communicate with the transmission control module are the brake pedal position sensor, the transmission fluid temperature sensor, the turbine speed sensor and the throttle position sensor. The information that the transmission control module gathers from all of the sensors is important in making determinations regarding smooth gear shifting. Processing this information and sending out the correct signals contributes to better fuel efficiency and better vehicle handling, as well as decreased engine emissions. For instance, the transmission fluid temperature sensor sends signals indicating if the transmission fluid is at the proper temperature. Based on these signals, the transmission can downshift if necessary. The brake pedal position sensor relays information that tells the transmission control module if the driver has applied the brakes. The throttle position sensor helps manipulate the timing of shifting.
Sep 30, 2016 | Toyota Verso Cars & Trucks
Where is the automatic transmission modular located on 2001 buic centry
Do you mean the transmission control module ? It is incorporated into the engine control module . PCM - powertrain control module .
Powertrain Control Module (PCM) (L36/L67)
Left front of the engine compartment, inside the air cleaner assembly
Engine Controls Component Views in Engine Controls - 3.8L
Powertrain Control Module Connector End Views in Engine Controls - 3.8L
Powertrain Control Module (PCM) (LG8)
Oct 04, 2015 | Cars & Trucks
My 2004 Saturn ion 3 has 2 codes coming up u2105 p0700 an it won't go in drive or reverse what could it be
First off you need to understand your vehicle has several control modules on board . The PCM - engine computer , TCM - transmission control module , SRS - air bag module , Anti theft , antilock brakes , An these modules all are able to talk to each other on a communication network , On your vehicle it happens to be the CAN data bus !
The transmission control module (TCM) uses the controller area network (CAN) to signal the engine control module (ECM) that the TCM is requesting malfunction indicator lamp (MIL) illumination. This happens when the TCM has determined that a failure that affects emissions has occurred in the transmission control system. When the ECM receives the correct message from the TCM, DTC P0700 will set.
Which transmission does your vehicle have ?
Automatic Transaxle AF23-5
OR
Automatic Transmission VT25-E
DTC U2105-U2199
The controller area network (CAN) serial data line is a high speed serial data bus used to communicate information between the engine control module (ECM), body control module (BCM), and the transmission control module (TCM). Typical data-transmission speeds must be high enough to ensure the required real-time response is maintained. The CAN serial data line does not communicate with the scan tool via the data link connector (DLC). CAN serial data information is interpreted by the BCM and transmitted to the serial data line by the BCM.
I suggest you take this to GM dealer or some other ASE certified repair shop .
Aug 13, 2015 | Saturn Cars & Trucks
What is a control module
I small computer box that performs engine or transmission or accessory functions. for example: ecm electronic control module. or tcm transmission control module. or pcm powertrain control module. or lcm lighting control module.or bcm body control module
Apr 16, 2015 | Cars & Trucks
Code U0101 what can cause this on a 07 GMC C5500
lost communication with TCM (transmission control module.
Check and clean all connectors to the transmission, check the ground at the transmission control module and the connections to it. Something in the wiring is not letting the signal from the transmission control module display it's results to the master electronic control module. It's a problem in the wiring harness somewhere between the transmission and the TCM or the TCM and the ECM.
Apr 03, 2014 | Gmc / Chevrolet C4500 / C5500 2003 & Later...
Transmission control module is on transmission as far as the the fuse it should be under the hood it should say TCM but maybe the wireing is different but that's a good guess
Feb 17, 2013 | 2010 Hyundai Santa Fe
Part number for transmission control module/1999v6cougar
There is a HUGE difference between a "control module" and a "transmission range sensor". Your vehicle is not even equipped with a trnsmission control module. The transmission is controlled by the Powertrain Control Module (PCM). There are lots of things under the battery area that have an effect on transmission shift - especially when it is considered that the entire transmission is under the battery area....
With that said, the OEM part number for the transmission range sensor on a 1999 Mercury Cougar is 6L8Z-7F283-AA.
Apr 11, 2012 | Cars & Trucks
I need to change the transmission modulator valve on a 2003 Chevy Impala. I need help with the location of the valve and even steps on how to change it. Thanks
Hello, the 2003 impala's dont have a transmission modulator valve. this transmission is electronic controlled by the power train control module. the transmission uses a pressure control sol. inside the transmission instead of a vac. operated modulator valve. if you are having a late harsh shifting problem, this would be more in the area of a pressure control sol. at fault
Jun 08, 2011 | Chevrolet Impala Cars & Trucks
connector. control module. transmission control module. . sky Logo
54 people viewed this question
Top Saturn Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Tim Garcia
Tim Garcia
Lawrence Oravetz
Are you a Saturn Vehicle Part and Accessory Expert? Answer questions, earn points and help others
