How to fix the flame
Flame has quit working everything else is fine
Electric wall double oven no power, no display, nothing works, breaker not tripped. What is the problem?
GAS OVENS
The spark igniter tip is dirty (can clean it with either a little wire brush or a piece of fine sandpaper).
2) The Pilot flame is too low, and the tip of the igniter is not in the flame good enough. (the flame acts as a circuit when it touches the tip & completes the circuit).
3) The spark module is no good and needs to be replaced.(But 1 & 2 are your best bet).
spark module does not sense the flame when it's on. The spark igniter is also the flame sensor which provides feedback to the spark module.
Make sure the igniter is properly aligned with the burner lighting holes and it is clean. All lighting holes must be clean too. You can enlarge them using a drill bit one size bigger.
If it would not fix the problem, replace the bake burner and the igniter.
There is a small chance for the spark module itself to be bad as well.
The oven safety valve
(also called the gas valve) is the part that ensures that gas is not released until the igniter has reached the correct temperature needed to ignite the gas. While this part can fail, it is uncommon. If the hot surface igniter does not glow you should first verify that you have voltage to the circuit. This is a live voltage check and should be performed by a qualified person. If voltage is lost at the valve terminals then you should verify the continuity of the bi-metal in the valve using a multi-meter.
Aug 04, 2014 | Ovens
I have a ppm 3000 and one of the XLR outs quit working. Easy fix or not worth it? Everything else works fine. Suggestions for a replacement??
If it's really just the socket that's quit then it may be an easyish fix depending on which one. If it's worth fixing really depends on which XLR out had died and in what way. These were from the 'bad' behringer phase and are normally not worth fixing.
Sep 27, 2013 | Behringer PMP 3000 POWER MIXER
HOW CAN A DRYER IGNITE A FLAME AT FIRST FOR TEN MINS THEN WHEN THE DRYER WANTS TO HEAT UP AGAIN I SEE A GLOW BUT NO FLAME COMES THE SECOND TIME SHOULD I REPLACE THE THERMAL FUSE
No you should replace the coils. 3a3915a.jpgWhy? You know you are getting power to the gas assembly so that means the fuse and control are functioning. The igniter glows so that is good. The Flame detect is fine because it shuts down the glowbar when it heats up. So those pesky coils get hot and quit. They eventually cool back down and work a little more, very aggervating to diagnose but easy to fix.2b3709e.jpgNote you do not have to remove the gas assembly to replace these coils.
Apr 23, 2010 | Whirlpool Dryers
Minimax NT Heater will not fire. Everything about the unit seems to be running fine but it simply will not fire. The blower continues to run even though it does not light. No error codes are shown....
Check the limit switch. It may be stuck open. TAP the cover with a screwdriver. If the unit starts, the limit will be the problem. You should also check the flame sensor. The unit may try to start but the flame sensor doesn't see the flame, the unit shuts off..Good luck...Lee
Nov 05, 2009 | Pentair Minimax NT Heater
Heater fan stop working after a couple of muinutes
Dimplex Electralog Model 6901050600 Ser 17807D2F - 048 Blower and Heater Works fine, Flame has quit working. How do you find and replace the Bulb? Email cairoeichard@gmail.com
Jan 02, 2009 | Dimplex Compact Electric Flame Stove...
My GOODMAN furnace GMH80703ANAA Starts but quits 5 seconds later
You have a flame sensor that may just need cleaning take out and take fine sand paper or emery cloth and clean
Nov 30, 2008 | Goodman Heating & Cooling
Flame problem
check the holes the flames come out of, they may be clogged, you may need to clean with a wire brush, if rusty then replace the burners. easy to replace
Sep 25, 2008 | Thermos QuickSet 462836203 (LP) Grill
Amana gas range bake burner does not heat
Pull the bottom of the oven off. You will see 2 to 4 screws that hold the panel on. The ignitor is under there. Look at the ignitor carefully for breaks. I say carefully as the ignitor is very easy to break.
Feb 03, 2008 | Ovens
Heating & Cooling Logo
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
