Has a Fishman Isys III controls with volume, bass, middle, treble, and tune buttons. I want to just tune the guitar so I pressed the tuner button, but the tuner lights do not change and no letter appears.
SOURCE: Fender Jazz Bass E string saddle vibrates down
Hi Mike,
If the sound is like a string vibrating against something, ensure that is not strings (usually G) vibrating against the bridge.
Ensure that the two screw on the saddle are well in place.
Ensure also that the vibration is not coming from a string vibrating against the frets, in that case you can fix the problem by adjusting the action and rectifying the bow of the neck.
In either case, if the sadde and neck bow are cause of vibration, try tweaking the saddles a little, and lowering the position of the saddle a bit downward. Try also to rectify the neck. turning the apposite screw.
SOURCE: Fender bass guitar shorting out
it sounds to me that you need to fix the input on the bass (where you plug in), sometimes just tightening the nut will do it, or buying a new one and replacing.
SOURCE: there is a repetative clicking sound whenever I
Did you mean the treble control potentiometer (knob)?
This was posted as an amplifier problem, but since you mentioned that the use of the treble (button?) on the guitar is causing the clicking, i would have the treble potentiometer checked first.
It could have a loosely soldered or broken wire on any of the tabs, oxydized slider contacts, bad ground (negative) connnection, possibly dirt or damage on the resistive track inside the pot.
A broken wire can easily be resoldered, but if there is internal damage or oxydation, the potentiometer should be either cleaned or replaced.
In short words - it may be a faulty treble pot.
There are ways to disassemble and clean a potentiometer, but the difficulty of this task may vary and depends mostly on the type and build of the pot.
The other alternative is to have it replaced.
regards
Triarcuate
SOURCE: I have a Fender CD220SCE acoustic guitar with a
Try this page:http://www.fender.com/products/search.php?partno=0962211021 Hope this helps. If not contact Fender at that site.
SOURCE: Hello ! Do You have shematic
Try this link:http://www.fender.com/support/amplifier_schematics.php If your amp isn't listed contact them and they will send you one.
