Question about Konica Minolta bizhub Office Equipment & Supplies
Has anyone seen code 8107 on a bizhub 225e df624
Df 624 on a bizhub 224e.
    Habit-Forming:
    New Friend:
  • 106 Answers
All codes starts with "6" above means Error in their options. Isolate your bizhub 225e option to see.
Posted on Nov 18, 2014
Whats the cause for the code C8101 on a bizhub 600 when switching it on. please help
DF control board (DFCB) communication abnormality.
- Communication abnormality between the printer control board (PRCB) and DFCB. Causes DF control board (DFCB) Printer control board (PRCB)
Dec 06, 2014 | Konica Minolta bizhub Office Equipment &...
What's your problem?i have Bizhub 600,when i make a copy, the Df, and scanner are working normally, after that you see in the screen (Read to accept another jop) and the machines does not copy p
When the last time the machine was cleaned in the drum area along with the associated sensors, when was the last time drum and developer replaced, every 250,000 copies drum developer should be replaced.
Oct 29, 2012 | Genuine Konica Minolta Konica Minolta...
What's your i have Bizhub 600,when i make a copy, the Df, and scanner are working normally, after that you see in the screen (Read to accept another jop) and the machines does not copy please te
Mite be that the copier need s a cleaning inside because it can not complete a copy cycle such as monitor the density of the toner on the drum have a tech do a cleaning when was the last time a 250,000 copy Preventive Maintenance Kit was done on it! Very 250,000 PM is done every 500K new drum. Does your machine a small wrench on the operator screen upper right hand of the purple/white screen
Oct 29, 2012 | Konica Minolta Developer 02xk Dv710 for...
I have a code error c4101 in minolta 350 bizhub
Does the machine come to ready state? and if it does, does the code blow as soon as an original in placed in the df or the start button is pressed?
Make sure you have 2 ribbon cables and one connector running through back of machine from PH unit. Also make sure you have the correct ph unit installed.
Here this is straight from Konica ...
C4101 code at power up.
Description:
Solution:
PROBABLE CAUSES:
1. Failed PWB-A (Mechanical CB).
Replace the PWB-A board (p/n 4040 0101 03).
2. No 24V DC at PJ17A, pin 5.
Replace the 3.15A fuse located on the power supply.
3. Polygon motor in the Print Head Assembly fails to turn.
Begin by checking the connections to the Print Head Assembly. Unplug and reseat all connections. If issue continues, replace the Print Head Assembly (p/n 4040-0751-00).
C-4101 (C4101) at power up.
Description:
C-4101 at power up.
Solution:
CAUSE: Failed BCRS board.
SOLUTION: Replace the BCRS (p/n 4551 2033 01 for bizhub 350 and p/n 4551 2034 01 for bizhub 200/250).
G.L.
Apr 24, 2011 | Computers & Internet
How do i program this remote to my time warner cable box
Time Warner is most likely made by another company and they are not listed on the programming documentation. You can try looking online to see who makes your Time Warner box. You should be able to program the manufacture off of the program list. The universal code for this remote is 8107 and 8108 which may work as well. To program the remote press set and the light next to set will start flashing. Press the desired component button ex(TV , VCR, CBL, DVD). Next enter the code 8107 and press ENTER. The set light should no longer be flashing. If 8107 does not work try 8108 using the above info.
Feb 06, 2010 | Sony RMV210 Remote Control
Bizhub C350 Malfunction Code C-0510
I have this malfunction code, C-11A3, coming up on my Konica/Minolta Bizhub 350 copier/printer. Anyone know what it is? I don't use the techs, because they charge much I don't pay for the service anymore-seems like most things should be able to be fixed by the owner. I needed help for this code
Mar 21, 2009 | Konica Minolta bizhub C250 All-In-One...
Codes for the box t
GO TO MENU
HIT 1570
MAKE SURE EMU IS ON
NAVIGATION
CHOOSE CHORUS OPTION
5E01 (STORE)
00:
CE 19 2E 87 61 74 90
STORE
01:
62 FA D9 F3 CE 05 FA 79
STORE
EXIT
Dec 18, 2008 | StarTech.com StarView SV211K 2-port KVM...
Latest starview codes telepest 30/9/08
try these
00=28 8b 84 9c bf e2 71 15
01=1e df 47 38 4f fb 0b ed
Sep 30, 2008 | StarTech.com StarView SV211K 2-port KVM...
Eurovox codes for ireland
Codes for ntl ireland were last rolled 18th June:
00 = 75 92 B1 CC 6F 23 20 F1
01 = F2 46 B1 59 04 61 77 71
Codes for Telewest last rolled 18th July
00 = 75 4A 66 04 CF 7F 55 F3
01 = 2A 09 4D DF CD 33 00 B9
NTL
00 = E1 53 E6 8C 74 9C 01 56
01 = EF 78 82 33 DF EF CB 15
Jun 24, 2008 | Audio Players & Recorders
Starview codes
Go to Google and search!!!
As of Monday, June 9, 2008
NTL UK (54 01) -- [Last Roll 06/06/2008 @ 3.45pm]
00 = 4F 9F 27 17 E5 76 AE AF
01 = C1 12 13 B2 17 32 78 CD (new)
C&W (5C 01) --[Last Roll 06/06/2008 @ 3.50pm]
00 = 57 3A B0 9B 6A 92 15 B1
01 = 2D 76 11 CC 9E 3E 6F 75 (new)
TELEWEST (5A 01) -- [Last Roll 06/06/2008 @ 3.55pm]
00 = 40 7B EC 04 C4 95 56 68
01 = ED C1 B7 A0 6E 64 B8 C9 (new)
CHORUS IRELAND (5E 01) -- [Last Roll 27/05/2008 @ 02.14pm]
00 = DD F5 65 CA C0 C8 2E F3
01 = B7 CE 07 09 AE 54 8D 36
NTL IRELAND (54 01) -- [Last Roll 21/05/2008 @ 8.25pm]
00 = 22 DO 9F EA FA CB 10 B3 (new)
01 = 76 A7 EE BC 3F 31 D0 0F
Jun 07, 2008 | StarTech.com StarView SV211K 2-port KVM...
135 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Adorjani Laszlo
Ben
Ben
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
