Question about Craftsman Crafstman 2,500 PSI, 2.3 GPM Briggs & Stratton Powered Pressure
HOW DO I RECONNECT THE SWITCH
What color wire goes where in other to reconnect
    Champion:
  • 208 Answers
Manufacturer will provide wiring diagram if requested. If it's just the kill switch it doesn't matter-just put them on the switch. As long as you're not shorting them to ground, the wiring isn't crucial in a little motorised unit like this-that is: if you get it wrong, no harm but no go/ get it right and your going.
Posted on Nov 26, 2014
2000 monte carlo took radio out with securtiy cut plug off now car wont start what wires to reconnect?
Reconnect all cut wires should be color coated match them back should be fine. Make sure wire color connection match same color.
Sep 28, 2014 | 2000 Chevrolet Monte Carlo
Diagram of wires for a 30 minute timer on a tanning bed
http://waterheatertimer.org/How-to-wire-timers.html#spa
Identify timer on link above and follow wiring diagram.
Gene
h
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Apr 25, 2014 | Hardware & Accessories
I need to know how to re-wire the ccs5000 rocker switch
It just so happens I'm working on one of these at the moment and happened to snap a couple photos to prevent the same issue.3_6_2013_4_55_14_am.jpg3_6_2013_4_55_35_am.jpg
Jan 10, 2013 | Achiever CCS5000 Shredder
Wiring 2003 honda element alarm wire
Match the wire colors and splice them together.
Oct 31, 2012 | 2003 Honda Element
Model 57194 wiring
Re-post question with clear description of timer, and brand of timer, and what timer is controlling.
Jun 22, 2012 | Hardware & Accessories
Whirlpool dishwasher: two loose wires need to be reconnected. Unable to determine which termings to reconnect the two loose wires.
if both wires go too the same switch/componet and these are the only two wires that connect to this componet it doesn't matter which wire goes where.
Mar 20, 2010 | Dishwashers
I have a fan the is connected to 3 switches. If one switch is on the other switches no longer work
Hello. I can help you. Assuming that all three switches used to work and now you have this problem, you have a switch that is worn out or has a wire that has come loose.
Turn off the power to this fan and open up one switch at a time. look for a disconnected wire, or a loose wire. If the wires were pushed into the clip on the switch check carefully as these little clips often fail after a while.
I seriously think you will find a loose wire and that will solve your problem, once you reconnect it.
If that is not the case, you will have to replace one switch at a time until you have replaced the bad one.
I recommend that you make a diagram of each switch once you have it out in the open noting which color of wire goes to each screw or spot. You will always have one screw on a switch which is a slightly different color from the rest. Always note which color wire goes to the odd color screw and make sure you always hook that wire to the odd color screw in the new switch.
Nov 22, 2009 | Leviton COMBINATION SINGLE POLE TOGGLE...
I need to switch out the door and I find that there is a harness of wires and I don't see a detachable plug in order to reconnect wiring controls for windows, locks, and mirror....from the replacement door...
Find the wiring harness under the dash that goes to the door, and use barrel type splicers to reconnect the wires. First compare the wire colors to be sure they match.
May 19, 2009 | 1997 Dodge Ram 1500 Club Cab
Need to replace the HPM dimmer switch with a normal switch
This is not a difficult job. First of all go out to a home depot or other hardware store and purchase one three way switch. They come in white, cream, and brown.
Back home, kill the power to the lights you are working on. Then open up the dimmer switch, the other switch doesnt need to be changed. Now, simply draw a diagram of where each wire color is now connected and remove the old dimmer. Reconnect the wires. Remember that the white wire goes on the dull color screw and the other two go on the brass screws. Turn the power back on.
If you do all this and the switch only works correctly part of the time just reverse the two wires on the bright brass screws. Please mark this answer as a fixya!
Mar 09, 2009 | Electrical Supplies
Craftsman Crafstman 2,500 PSI, 2.3 GPM Briggs & Stratton Powered Pressure Logo
87 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Jim Parker
Jim Parker
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
