Question about Garden
Need owners manual and a break down on how to repair the steering column
    New Friend:
    Problem Solver:
  • 12 Answers
Google it with make and model most manufactures will supply for free
Posted on Nov 19, 2014
Mitsubishi Airtrek 2001 steering wheel has dropped right down.
There's a lever on the underside of the steering column. Pull this down, push the column up to where you want it, and then push the locking lever back up. Have a look in your Owners Manual if you have one.
Dec 10, 2017 | Mitsubishi Cars & Trucks
ERROR CODES C 1140 AND C 1202
1140 is for the **** spring/ steering angle sensor. In the steering column. 1202 is the brake pedal switch. I would check fuses first. Your owners manual will tell you which ones.
Aug 21, 2016 | Mercedes-Benz C-Class Cars & Trucks
93 corvette tilt steering colum rebuild
It will be the top shaft bush that locates the steering shaft in the centre of the column tube . It is normally just a push in fit . You will find reference to it in a parts break down book
Jan 26, 2014 | 1992 Chevrolet Corvette
Steering column replacement
you need haynes repair manual with photos show you how to remove steering column.you can buy haynes repair manual at any auto parts stores.you can try go on line internet look up how to remove steering column on a 1999 chevrolet tahoe.
Jul 15, 2013 | 1999 Chevrolet Tahoe
Battery is dead need to put in neutral but is lock already push break still won't unlock
Did you check above the steering column? sometimes there is a lever-type bar that you can manually move to switch gears..This is how my car is. Mazda Tribute 2002. I only know this from my Owner's Manual. seems like i read it somewhere
May 11, 2012 | 2004 Honda Odyssey
I need an Illustrated Parts Break down for a 1989 GMC Sierra 1500. 350 w/ PS/PB loaded. Steering column Removal Repair or Replace
Hi.
Below you get all the parts breakdown for GMC Sierra 1500, including steering column assembly:
1500 SIERRA
Here diagrams for all 1989 GMC trucks.
If you need to take apart the steering column you will also need wiring. below the color codes and wiring tips:
GMC SIERRA 1988-2005 VEHICLE WIRING
Regards.
Ginko
Aug 31, 2011 | GMC C1500 Cars & Trucks
Need to replace ignition cylinder. no keys
This is not an easy repair due to anit theft requirements. need to chisel off bolts.
Section 11-04: Steering Column 1997 Probe Workshop Manual REMOVAL AND INSTALLATION Procedure revision date: 05/17/2000
Ignition Switch Lock Cylinder Removal
  1. Remove the steering wheel (3600). Refer to the procedure in this section.
  1. Remove the four lower steering column shroud screws.
  1. Separate the upper and lower steering column shrouds.
  1. Remove the ignition switch lock cylinder illumination miniature bulb from the lower steering column shroud.
  1. Remove the upper and lower steering column shrouds.
  1. Remove the multi-function switch (13K359). Refer to Section 11-05 for the removal and installation procedure.
  1. If equipped, remove the ignition/shifter interlock cable screw.
  1. Disconnect the ignition/shifter interlock cable (3F719) from ignition switch lock cylinder (11582).
  1. Use a chisel to remove the two ignition switch lock cylinder bolts.
  1. Remove the ignition switch lock cylinder from the steering column.
  1. Disconnect the ignition key reminder switch electrical connector.
  1. If necessary, remove the ignition key reminder switch.
Installation
NOTE: Use new ignition switch lock cylinder bolts. Tighten the bolts until the bolt heads break off. Check for proper ignition switch (11572) operation.
To install, reverse the removal procedure.
Mar 25, 2011 | 1997 Ford Probe
Much play in steering wheel; possibly the 3 set screws in the bottom of steering column? how to fix? this is on 1987 chev 1/2 ton
Replace steering column with a better one or you must break down the steering column all the way down untill you the screws in the bottom of the column and tighten them up. It is some work and you may need to video while you are taking it apart so you can remember how to reinstall it.Good Luck!!!
Nov 14, 2010 | 1986 Chevrolet K1500
Loking for fuse box/relays diagram for 1994 Olds 88 Royale
Fuses (located on a swing down unit near the steering column or in the glove box) protect all the major electrical systems in the car. In case of an electrical overload, the fuse melts, breaking the circuit and stopping the flow of electricity.
I suggest check your 1994-Oldsmobile-Eighty-Eight-Owners-Manual for descriptions (page 223 and next).
Hope this help..
Mar 30, 2010 | 1994 Oldsmobile 88
Cruise control doesnt work,,,i there any fuse for it? this is for a cadillac deville 94
Cadillac's of this year have been known to have the wire(s) fromt he cruise control break in the steering colum. This is due to the tilt wheel moving up and down over the years. You should be able to either repair the broken wire or get a used unit (turn signal/cruise) and wiring harnes at a salvage yard. The wiring runs along the steering column to a connector on top of the column about half way down.
Check your fuses first. I believe the cruise and a couple of other accessories are on the same circuit. Is there anything else that doesn't work? (i.e. cigarette lighter, dome lights...) If you have the owner's manual that would help OR a trip to the public library in the auto section...Hope this helps.
Nov 19, 2009 | 1994 Cadillac DeVille
Garden Logo
24 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
