Question about Heavy Machinery
HOW DO FORKS LIFT - Heavy Machinery
  • 2,509 Answers
How to change the fork seals on 95 electraglide
You take the front wheel out then undo the top and bottom yoke pinch bolts,twist the forks downwards then undo the bolt in the centre at the bottom.then lift the dust seal out with a flat screwdriver and lift out the circuits you may need circling pliers.then pull the top and bottom of the fork apart quickly.it will separate.then change the seals and put it back together you need to install the new seal squarely and do not damage it.refill the oil by undoing the bolt at the top and pouring the fork oil in there.
Feb 22, 2015 | Motorcycles
Linde manual
have a check this www.filehippo.com
Aug 09, 2014 | Bruder Linde H30D Fork Lift With
Lifting a engine out of a 256c cat skidloader
check around the rear section and see if there is a way of removing the door/weights. Use a lift bar on another fork lift and chain the motor to that bar . Undo all the bell housing bolts and engine mounts and lift a bit and back the fork lift to get the motor out.
Jun 24, 2014 | Cars & Trucks
How much money should a fork lift cost?
at least $20,000 new. for a less advanced 'electric pallet jack', you may find one for $10,000.
Apr 22, 2013 | Heavy Machinery
Which companies make fork lifts?
There are at least 10 companies, only in the US. you can see them here:
http://stevewong.hubpages.com/hub/Who-makes-forklifts-in-the-USA
How far can the forks move from side to side?
the forks can generally move only 6-12 inches from side to side by using the 3rd lever. However, all modern trucks have forks that are easy to manually move. Just lift up the pin that is holding the fork in its groove, and put it in the groove where it will work best for what you're doing. don't forget to lock it again with the same pin
Jan 13, 2013 | Heavy Machinery
How much can you tilt a forklift's forks on average?
It depends on the make and model of the fork truck, but on average you can tilt the forks between 15-30 degrees both up and down
I have replaced fork seals
I am assuming the old oil is drained.
Once the tops are opened, lift the bike onto the center stand which will make the forks extend. Refill through the top of the fork with 12 oz of fork oil. The manual states that you must use oil with a weight of approximately SAE 3, and the amount going in needs to be equal in each fork.
Hope this helps
Mar 25, 2009 | 1984 BMW K 100
Heavy Machinery Logo
883 people viewed this question
Top Heavy Machinery Experts
Tom Chichester
Bill Boyd
Daryl Gleaton
Are you a Heavy Machinery Expert? Answer questions, earn points and help others
