<!-- from fixya rte -->Unit was on heat and has tripled the breaker - Heating & Cooling
  • 101 Answers
I suspect you have electric heat? your element maybe shorted!
Posted on Nov 26, 2014
Changed top thermostat 11060832990 and now pops breaker
Sounds like incorrect wiring, like you have a "hot" wire going to the chassis somewhere. I'd double/triple check the connections. If you only pulled off the 2 thermostat wires, and reconnected them directly back, then it's unlikely that's the problem, but if you disconnected the thermal fuse or other connectors along the way, it sounds like something is hooked back up wrong. Good luck!
Dec 04, 2013 | Kenmore Dryers
As soon as I turn on my heating unit, it trips the breaker. The heating unit will come on and in a matter of a second, it trips the breaker. What's wrong and what can I do?
Heating element short circuited. Or wires to heater may be loosen or short circuited. Check your breaker also. Sometime, due to defective breaker also it happens.
Dec 15, 2010 | Heating & Cooling
I have a intertherm mobile home furnace. When i turn on the heat the circuit breaker in the funace heats up and blows the breaker. this only happens when i turn on the heat if i turn on the fan it is...
you said it yourself. when an electrical device is running it produces amps, with every amp is a unit of heat. breakers are heat sensitive as well. so you might want to consider a new breaker. newer breakers are made out of better materials that are able to displace heat more efficiently. or check to make sure the screws on the terminals where the wires go in are tight. if there is a loose connection that will increase the units of heat traveling through the termination. or, worse case scenario, like when all hope is lost. splice in some more wire, correctly, emphasis on correctly, and relocate the breaker. perhaps use insulation around the breaker, non flammable of course.
Nov 11, 2010 | Electric Electrical Supplies
Heat / Cool unit runs approx 45 minutes then trips the breaker
Check the amperage of the breaker or change the breaker out completely with a new one. The tripping problem is that the breaker itself is heating up to the point that the bi-metal in the breaker (safety device) is throwing the breaker off. This could be the problem for you however, I would get an ampherage draw from the unit to insure that the breaker is the proper size for the unit. If you can find what kilowatt the unit is divide that number by the amount of current being supplied and that will give you the breaker size.
Good luck hope I helped you some
Dave
Jan 08, 2010 | Kenmore Heating & Cooling
Goodman unit blows 45 amp fuses only in heat mode, worked fine all summer on a/c. It works well for some time then blows them again.
Check the breakers on the unit How many KW--electric heat? Check to see if you have the right wires wired up to the correct breaker cause some units have 40---and ---60 ---amps breakers and your thickest wire could be wired to the 40-amp breakers,, (some 5 KW pullls 19-23 amps respectably some breakers have 7.5 KW heat stips and pulls more and if the wire size can,t cary the amps, then all you have to do is reduce a heat strip.
Dec 18, 2009 | Goodman GMS90703BXA Heater
Compatability of a R22 air handler and a R410a heat pump
1. The units should match up without a problem.
2. You will need a 40 or 50 amp breaker for the A/H and 5 KW heat strip. You will probably need a 20 or 25 Amp for the condensing unit. I would check the FLA (full load amps) rating on both units, total them and install a breaker with no more than 20% more rating than the total. You can install a small box at the A/H with a breaker for the A/H and one for the condensing unit.
Nov 15, 2009 | Carrier XHB123D X/Y Series Heat/Cool Air...
Breaker trips on condenser unit on heat pump after several hours of operation
Hi, check amps on unit, and make sure breaker matches, check unit voltage tag, it will tell you what size breaker you need, or may be breaker is loosing resistance, replace breaker, if problem continues, a/c maybe over working because of high temp, temp. affect amperages, and that would be normal, if it trips after few hrs. also check a/c for lack of freon, sometimes, they need a tap up of refrigerant, not enough freon and they would run longer, get hotter and eventual trips. breaker doing his job. good luck
Aug 03, 2009 | Amana PTH123B25AJ Heat Pump Air...
My ac circuit breaker keep tripping
If your outside condenser has a locked rotor or short circuit, than the unit WILL trip the breaker - as it should. On the other hand if a breaker is tripped a few times it will have less of a capacity that the rating, (this is designed in it). You will need to determine if the unit is locked (and broken) or the breaker has become too sensitive.
Apr 20, 2008 | Heating & Cooling
Heating & Cooling Logo
23 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
