Question about LG Refrigerators
How do I find the fuse panel on LG model LSC269055b refrigerator
    Sergeant:
  • 251 Answers
I think your model number is actually LSC26905SB
There isn't a fuse panel, per se. If I remember your model correctly, the main board is on the back, so pull your refrigerator out, unplug it, and take off the access cover located about halfway up your refrigerator's back. Look at the fuses on the main board. There is a 20 amp fuse that blows easily (the newer boards have a slower blowing fuse in them, now). Temporarily jumper the 20 amp fuse and then plug your refrigerator back in. If you hear relays clicking and such, that's good. The compressor should start up shortly afterwards and all the lights should be on in your refrigerator.
After you have verified operation, go to Radio Shack, or somewhere similar and get yourself a 20 amp slo-blo (slow blowing) fuse and solder it on top of the old fuse on your main board.
Remember to always unplug your refrigerator when dealing with the main board and power circuits.
Good luck and let me know if you need any more help.
Posted on Nov 27, 2014
Testimonial: "I found the panel on the top of the refrigerator. I had it all fixed and working by the 18th. Thank you for your answer though."
  • Bill Myers
    Bill Myers Nov 27, 2014
    PS - Thinking about it, sometimes, it's a 15 amp fuse, not a 20 amp. Check to see what the amperage is and replace it with a slo-blo fuse of the same rating.
  • Bill Myers
    Bill Myers Dec 03, 2014
    Hmm... Okay, your panel was on the top of the refrigerator... Make sure your compressor fan is working correctly! That's the number one reason why that fuse blows on the ones with the control board mounted on top of the refrigerator.
Why is my LG french door act like is has no power?
Probably a bad fuse on the main board. Fuse is not replaceable so either you have do a workaround (search LG refrigerator fuse repair for several fix videos and how-to's) or you have to replace the whole control board (part EBR41531302 I believe, but double check with your the part vendor before ordering).
Check the fuse by pulling the refrigerator out, unplugging, taking off back control board panel, and checking the fuse for continuity.
Aug 02, 2014 | LG LFC23760ST Side by Side Bottom Freezer...
LG refrigerator not running
Your model has a computer board on the back behind the access panel. This board contains a fuse, if your unit is dead with no lights when the doors are opened, your fuse may be blown, The fuse is not always intended to be replaced as there is typically a root cause of the fuse blowing. In some cases the unit will be fine otherwise but the fuse may be defective. If lights come on when the door is opened, and a fan motor can bea heard running when you put your finger over the door switch after several seconds, you are likely experiencing a different issue. Pleazer Appliance...
Apr 11, 2014 | Refrigerators
Where can i buy a circuit board for my lg refrigerator model lfc23760st
No need to buy a new main control board !
The problem is mainly from the fuse that soldered in the main control board, go to buy a "125V 15A or 250V 15A" fuse ($5.00 a pack of 5 pcs), cut the burnt fuse from the board, re-soldered the new fuse into the board, the refrigerator work again. you save $80 for the labour cost of the technician and $180 for the cost of a new main board.
Jul 18, 2012 | LG LFC23760ST Side by Side Bottom Freezer...
LG Refrigerator side by side suddenly not working at all other than interior lights.
If you're lucky, it's just the capacitor on the motor. Have it checked, but be prepared to need a new compressor.
Mar 10, 2012 | Refrigerators
Re: LG lfd22860 refrigerator. Breaker tripped during the night, now fridge will not turn back on. Is there a reset switch or something?
No, there is a built in fuse that has failed and the whole board has to be replaced. Behind the refrigerator is rectangular panel where the control board is located. Not sure of the part number because of different model variations.
Hope this helps.
Nov 04, 2011 | LG LFD22860 Bottom Freezer French Door...
Burned our fuse in circuit board
it is a 250V 15 amp. clip the fuse off the wire, close, and solider in a new one. Terrible design. LG should have to replace free or be sued !
Feb 23, 2010 | LG LFC23760ST Side by Side Bottom Freezer...
LG Model LFC23760 (French Doors, bottom freezer) power prob
Unplug fridge.
Open panel on back of fridge (the one at hip height that says Service Panel Only - Do Not Remove, blah blah blah)
See pictures here: http://www.amazon.com/LG-LFC23760SW-French-Refrigerator-White/dp/B00198A5C0/ref=cm_cmu_up_thanks_hdr
Replace fuse with 9A 250V slow-burn fuse. I used a gray fuse harness from Radio Shack so that if the fuse needs to be replaced again I can just pop in a new one without doing the soldering over.
I nuked the original fuse, the end-caps and the wires that went from the end-caps/fuse to the motherboard. I replace those wires with some I scavenged off a fresh thermal fuse (also bought at RS, just needed the wires themselves which seemed to be the same diameter/gauge as the original leads) and ran them from the motherboard to the wire harness.
So far, so good!
Good luck to you.
Jan 31, 2010 | LG LFC23760SW Side by Side Bottom Freezer...
Where is this fuse located on the LG refrigerator is displaying a ER DH code error
GO TO SEARS .COM ,CLICK ON PARTS,PUT YOUR MODEL NUMBER IN AND YOU WILL FIND WHERE THE PART IS,LET ME KNOW-MIKE
Jul 07, 2008 | LG LRFC25750 Refrigerator French Door
LG Refrigerator Defrost Error ER DH-- Defrost fuse
the fuse is in the fz compartment behind the evap cover panel once you get the panel off it will be at the top right-hand corner wedged between the evap coils
Jun 23, 2008 | Refrigerators
Refrigerators Logo
101 people viewed this question
Top LG Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a LG Refrigerator Expert? Answer questions, earn points and help others
