Question about Dometic 3313189.031 3313189.072 Black Single Zone LCD Cool/Furnace/Heat Pump
I am upgrading an analog thermostat to the dometic 3313189 thermostat. My question - how will i connect the present 6 wire to the new 3 wire
How to connect wiring. currently I have a 6 wire analog and this is a 3 wire.
  • 101 Answers
Do have AC? if you do you have to by a thermostat that can handle both heating and cooling, if you only have 3 terminals it must be a heat only thermostat.
Posted on Nov 26, 2014
  • Victor Scarpita
    Victor Scarpita Dec 11, 2014
    Sorry! "buy"
  • Chevy Blazer
    Chevy Blazer May 10, 2015
    I have the same thermostat and need to know the wiring diagram please.
  • 534 Answers
SOURCE: We have a duo therm rv analog thermostat. When we
red wire to the r section of the thermostat white (heat) to the w marked on thermostat Green (fan) to the g marked on thermostat yellow (a/c compressor) to the y marked on thermostat. Blue to the c marked on thermostat. Orange to the orange marked on thermostat.
Posted on Oct 30, 2009
motor1258
  • 6674 Answers
SOURCE: problem w/ dometic penguin a/c. upgrade kit?
You know what, I have never ran into that yet in 15 years, so I think your best bet would be to go to, (dometicusa.com) and send then a quick inquiry to confirm, what would be required, they are usually pretty helpful believe it or not.
Posted on Aug 07, 2009
motor1258
  • 6674 Answers
SOURCE: I have a DuoTherm BriskAIr 13.5K BTU. The Dometic
If you look at control box at roof unit, they usually use a separate set of wires for furnace. See what colors they are attached to at harness to thermostat. Some just follow other harness, and come out at thermostat. (bypass control box) Once you've determined which 2 they are, join them together & see if furnace starts, as it should. If it does, thermostat is faulty. If not, pull outside cover off & check voltages at furnace. I'm guessing by furnace model that your unit is approx 30 ft , but if it's a park model, you may have 24 volt system on furnace or 12 volt. Another way of confirming is to go to back of furnace where air intake grille is inside your unit, and locate 2 blue wires going to furnace & remove whatever wires are attached to them & connect them together. Furnace should start up.
Posted on Jul 08, 2009
Testimonial: "thanks for the link. info solved my problem."
  • 415 Answers
SOURCE: looking for wiring diagram for a duo therm by
There are several models out there. Here are a couple of manuals with wiring diagrams that I believe will help you regardless of the model number. However, if they are unable to help you, let me know the exact model number and we'll search for the wiring diagram. :-)
Link #1
Link #2
Posted on May 19, 2010
intower18
  • 957 Answers
SOURCE: Need instructions to install a
I have read and checked all the diagram on how to install your thermostat, you can check on this website address below, you have lots of options and diagram for you to install it.
http://www.modmyrv.com/2008/07/14/rv-digital-thermostat
I hope you can install it as soon as you have checked it.
Posted on Jul 17, 2011
How to wire six wire to three wire termenal
I'm pretty sure this thermostat uses digital communications with a dometic control board. In other words, there are no contacts in the digital thermostat to turn something on and off. Even if you ran a 12VDC wire to the thermostat for power, it won't work to replace a "real" thermostat. I bought one to replace my old analog thermostat and it's not going to work for me.
Oct 10, 2015 | Dometic 3313192.000 White Single Zone LCD...
Can you replace Dometic 3107541.009 analog control unit with Dometic 3313192.000 digital control unit?
e-mail or call dometic support : (www.dometicusa.com) and make sure you give them the model # of your control box at ceiling assy and they will tell you if they will work together.
Jul 30, 2014 | Dometic 3107541.009 Analog Thermostat...
We have a duo therm rv analog thermostat. When we opened it up none of the 7 wires were attached. Do you know the wiring code?
Oct 30, 2009 | Dometic Rooftop RV Air Conditioner
Problem w/ dometic penguin a/c. upgrade kit?
Aug 07, 2009 | Dometic Rooftop RV Air Conditioner
I have a DuoTherm BriskAIr 13.5K BTU. The Dometic thermostat also controls my HydroFlame 8531-IV furnace. This morning, the furnace would not come on. I checked the wiring and there is no voltage at the...
Jul 08, 2009 | Dometic Rooftop RV Air Conditioner
Analog thermo.stat control kit
Have you tried removing the RH wire connected to the thermostat and try it ? This might rule out furnace as short in system. If it does the same, put RH- (heat) back on and try removing RC-(cool) , if it doesn't pop the fuse, you may have isolated the problem.?
Jul 30, 2008 | Dometic Rooftop RV Air Conditioner
Dometic 3313189.031 3313189.072 Black Single Zone LCD Cool/Furnace/Heat Pump Logo
431 people viewed this question
Top Dometic Heating & Cooling Experts
Bill Long
Donni Steen
mike cooper
Are you a Dometic Heating and Cooling Expert? Answer questions, earn points and help others
