Question about Coby DIGITAL FRAME COBY DP102 RTL
I can't get my coby digitnal frame to take my card
I can;t get my frame to read my card. it keep saying pit a card in it
Today, I added photos to a 16GB SD card and the digital frame is indicating that there is no card inserted, when it is. Is there any way I can get the picture frame to read the new SD card?
it may be that the sd card is incompatible with your digital picture frame
It may be too large in capacity .....it may be the incorrect type of sd there are sd hc and ad xc at the moment
Jul 06, 2015 | Coby DP-772 Digital Picture Frame
Sd card wont work
The card needs to be formatted first.
Dec 12, 2013 | Coby DP-768 7-Inch Widescreen Digital...
Dosen't read my sd card
This unit only reads SD Cards that are 2 gigabytes or less, make sure the card is under 2GB
Mar 15, 2011 | Coby DIGITAL FRAME COBY DP102 RTL
I have a digital photo frame Coby DP-5588. I bought a sd card Kington 4GB when I insert the card in the photo frame appears a message "wrong Card" and it doesn't read the card content. What can I...
Your 4GB card is actually an SDHC card, not an SD card. While SDHC cards will fit into SD slots, they are electronically incompatible and will not work. You need to use an SD (or MMC or xD or MS), 2GB and smaller.
Dec 05, 2010 | Coby DP-5588 5.6-Inch (4:3) Clock &...
Hi, I purchased 3 Coby digital frames DP 700 with the intention of putting vacation pictures on for three friends. The included directions are useless. Hope you can help. Can I transfer and SAVE...
Good day,
I read up on the specs of the frame and it does not have an internal memory, thus you will have to have the sd card inserted at all times to display photos.
Hope this helps!
Regards
Dec 01, 2010 | Coby Cameras
Even after I put the memory card in, it still keeps asking for a card to be inserted.
This frame is only supported by:
SD, MMC, xD and CF cards.
Try w. dif. card. low gig and not highspeed hopefully it willl work.
If it does pls. rate me TXS
Nov 12, 2009 | Coby DP-772 Digital Picture Frame
Video OK but no audio when use SD card on photo frame COBY DP702
Audio is probably recorded with different codecs, one of which is unsupported by your frame.
Mar 23, 2017 | Coby DP-772 Digital Picture Frame
Can't copy pics from camera to frame
hmm sounds like the frame doesnt support the HC. what you should do is, transfer from the camera to a PC, then PC to a standard SD card and try.
Mar 19, 2009 | Coby DIGITAL FRAME COBY DP102 RTL
I just purchased a digital photo frame, the DP-758. I loaded photos from my USB key, 52 photos. I somehow have 233 photos on the photo frame, I don't know how. I would like to know how to delete...
hi there
your photo frame has not got a built in memory so it can only read pictures from the card you put in and only while the card is inserted. these extra pictures are either on your card, which you can delete yourself via your p.c., or they are stock demo pictures on the picture frame which can't be deleted.if you insert your card before you switch the frame on it should read only the card.
hope this helps
beergut707
Oct 08, 2008 | Coby Televison & Video
Coby DIGITAL FRAME COBY DP102 RTL Logo
44 people viewed this question
Top Coby Photography Experts
Torashi
richie46
Are you a Coby Photography Expert? Answer questions, earn points and help others
