Question about Boss By Roland Boss MICRO-BR Ultimate Palmtop Recording Studio
Micro BR...only have 16 mins of music/songs recorded. Did the "copy" procedure and did not say "card full". But, when converting to MP3 only total of 4 mins would convert. Why won't all of the 16 m
Why won't the full 16 mins of our song recording convert to MP3? We have only 16 mins of music recorded, nothing else. We did the procedure to "copy" (p. 58 in the manual) the data to be able to then convert the data to an audio file ie MP3 (page 127 in manual). The copy phase went to completion. But, the MP3 phase only converted 4 mins total. Again, why won't the entire copied file convert to MP3?
How do I transfer track data to computer?
Why you have to convert to mp3 ?. Did not the card can be removed and installed on the computer and then copied?
Where you convert the file? BR or computer?
What software you use to convert?
Mar 26, 2015 | Roland Boss Micro BR Multi Track Recorder
I had recorded 16 complete songs of my own on a 512 mb sandisk sd card. When the card was almost full i removed it and recorded other new songs on another card. when i re-introduced the first card it had...
A very important thing when using these recording devices is to PROPERLY close the media. I would not panic at this point. Search for a forum regarding the Boss Micro BR and ask there as somebody may be able to help you recover the data. Read up on your manual about shutdown. I have Tascam recorders and I prefer to stop the recording and then when it is done I turn power off before removing the media. You may have to use a special procedure when introducing the nearly full card... even forcing it to load.
Apr 27, 2011 | Boss Micro BR Digital Recorder
I downloaded a song on my laptop, saved it to my sd card, put the card in the mirco br, but it doesnt show up??
It is in different format. You must go through a format convertor to make it compatible. Use Google to find Micro BR format convertors.
Feb 08, 2011 | Boss Micro BR Digital Recorder
I want to use my sd card to put my own songs and when i change the song from an MP3 to MIDI file using the program WIDI 3.3 Pro. When i put the MIDI file which is the song, into the Sd card and then into...
You need to understand what the program is doing.
An MP3 file is a recorded music performance like a phonograph record. A MIDI file is a set of instructions for performing music, like sheet music. The converter program is an attempt to turn the record into sheet music. There is no perfect way to do that. You should have gotten something out of the program, though. It sounds more like a computer problem. Try a very simple sound file, convert it to MIDI, and see if you can get something out. If your keyboard can't read it, try putting any known good MIDI file on the card and read that. Possibly your keyboard will only read certain formats or sizes or speeds of cards. See if the manual tells you anything. It might read FAT16 regular speed cards under 1 GB, for instance, and balk at a SDHC 16 GB NTFS formatted card. So, do some detective work.
Apr 05, 2017 | Casio Lighted Keyboard LK90STADMC
Boss micro br not converting all the tracks in the song to MP3
You have to "mix" the tracks to create a final work before saving the file.
Jan 31, 2010 | Boss Micro BR Digital Recorder
Reloading backed-up song data on Boss Micro BR
Are you transfering from one disk to another on your computer? There is a possibility that the format of the original disk is not being recognized.
Nov 29, 2009 | Boss Micro BR Digital Recorder
I need help with my Boss Micro BR. I want to convert the song I recorded to MP3, so that I can hear it on my laptop. I connect the recorder with the laptop through U.S.B. and can only get to the files that...
Go to bossbr.net - Plenty of answers there! And yes, you have to master or export the tracks to .mp3 or .wav. These files will be located in the mp3 folder. Boss also makes a free .wav converter located on their website.
Oct 05, 2009 | Boss Micro BR Digital Recorder
Downloading music
To download music to the sync is not as difficult as it may seem. You have a multitude of options but i'll just cover 2..... 1- there are website's through your phone that able you to download full songs.... 2- any song that is mp3 will play on the syc. there are also programs that will convert any music file to mp3... google- convert wma to mp3.... exct.....
anyways after you have your your music set up as mp3... you can us your micro SD card that's in your phone (if you don't have one...radioshack usally has them on sale) make sure u have an thumb drive reader for the micro SD...... then drag/ drop your music..... insert micro SD back into phone and aslong as everything was done correctly..... BAM! and enjoy >; )
Nov 25, 2007 | Samsung SYNC SGH-A707 Cellular Phone
Boss By Roland Boss MICRO-BR Ultimate Palmtop Recording Studio Logo
262 people viewed this question
Top Boss By Roland Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Boss By Roland Audio Player and Recorder Expert? Answer questions, earn points and help others
