Question about Sewing Machines
<!-- from fixya rte -->Need replacement black bobbin holder arms. - Sewing Machines
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 42 Answers
You need to find the correct name for part. If you not sure take it to a Brother dealer in order not to void your warrranty. If its the black drop in bobbin case call Brother directly and find the name and parts number. Then you may order from whomever has it.
Posted on Nov 26, 2014
3 Suggested Answers
Zenqi
  • 208 Answers
SOURCE: the needle keeps breaking in my Yamata FY 910
The bobbin case rests on the lip of the hook and is is held into place by the position bracket. The position bracket is located at about 5 o'clock and has a small square end with a buffer spring. It must be positioned to hold the bobbin case securely and also allow the thread to pass through freely. It may be out of adjustment but may not.
If the bobbin case has turned, it is very likely to have suffered damage as it is made of a soft carbon fiber material. It not polished off, these damaged areas can snag the thread and jam the machine and create tension problems. Some gouges, burrs and needle punctures can be carefully sanded but you may need a new bobbin case. Use a 1500 grit sandpaper to smooth off the rough edges.
Posted on Jun 18, 2009
  • 1564 Answers
SOURCE: thread caught behind the bobbin case holder
Take off the presser foot
take off the needle plate
take off the bobbin plate
take out the needle,
clip bobbin free,
Examine the bobbin carrier on how it fits into place. (important)
Lift out the bobbin carrier.
Each machine is a little different. You may want to take pictures as you do each step for later reference. Use something like an old egg carton or a muffin tin to keep your parts from rolling around or getting knocked off an lost.
Have fun.
Posted on Nov 06, 2012
Problem with thread getting caught under bobbin holder
have you applied any lubricant to the bobbin holder the one that holds the bobbin? I would suggest using your manual and lube your machine. sounds to me like your mechanism is sticking.
Jun 08, 2015 | Janome Sewist 625e
How do I put the bobbin case back in to the shuttle holder, mine keeps falling out?
Put bobbin in holder. Thread properly. Pull out arm on bobbin which holds spool in place and gives u a handle. Place into position. Turn slightly so it fits into appropriate slot. Let go of arm. That's it. Good luck.
Mar 03, 2015 | Sewing Machines
Why does The bobbin holder keeps 'crashing' with a metal 'arm' on the left.
Hum, nothing should
"crash" into anything else while sewing. The Hook (place where bobbin case snaps into) might have a broken "keeper" (internal part that "keeps" the hook stationary when sewing.) Or your bobbin case may not be installed completely or correctly.
Cheers,
Kelly
May 03, 2014 | Janome Memory Craft 9000 Computerized...
Thread caught behind the bobbin case holder
clip bobbin free,
Have fun.
Nov 05, 2012 | Pfaff Creative 4.0 Sewing Machnie
I have a Necchi 4900 and the thread catches on the bobbin holder , moves the bobbin holder out of place , james , have taken it out cleaned everthing under the bobbin and takewn the underneath cover
try changing the needle to see if that helps
if it doesn't,, then I suggest that the sewing machine be checked
at a repair shop to see if the bobbin case needs to be replaced and
to see if the hook and the hook race need to be replaced
Nov 01, 2012 | Necchi Sewing Machines
Elna Supermatic 1960's/cream and blue. The machine is jammed. Hand wheel will turn backwards but not forward. I pulled some quilting thread out out the bobbin area, but didn't fix problem. ...
There may be threads jammed up in the bobbin holder area causing the jam. But removing the inner bobbin holder is a bit tricky if you haven't done it before. There are two little screws holding the silver inner down onto a black ceramic piece (inner guard ring), and you need to get these lined up the right way to get the bobbin holder back into position afterwards.
I would suggest that you join the Yahoo group Elna Heirlooms, then check out the files and photos loaded up by other members who work on their Elnas.
You shouldn't need to remove the feed dogs, just give them a clean with a little brush. But internally the machine may need a good clean and lube and without a service manual or good guide this can be challenging.
If you go this link http://www.arizonaexpressionz.com/elna_service_manuals.html you can down load the manual for this machine, the Star Series SU. Go to page 7 of the first part to see about removing the bobbin holder and inner guard ring.
It is a case of lining up the cut out of the black plate to the front, then putting the bobbin holder on top with the little arms facing front also, then replacing the two screws.
I'd suggest you take photos with a digital camera before you start to help you get it back in the right way.
I hope this helps you with the Supermatic, did you get the discs and accessories with it too? lovely Swiss quality machine with great stitching so if you can't get it unjammed, you may wish to find an experienced Elna Technician to take a look.
White Sewing Center stock lots of parts for these machines too, www.whitesewingcenter.com
Jun 08, 2011 | Elna 1010
I have an Elna Carina Electonic machine. It was just tuned up, but got jammed up in the bobbin. I took it out, used brush to get all lint out but now cannot get the bobbin unit back in an working. No...
Lovely machine, don't dispair. You need to turn the rotary hook with your flywheel so that the open side of the hook is facing you. Now move the black inner piece around inside so that the cutout side is facing you too and just a bit to the left. Now lower the bobbin holder in with the metal arms facing towards you , they should slip in between the outer parts. You want the two bobbin case screws to line up with the holes underneath, just give it a bit of a wiggle until you feel it drop into place. Now screw in the two screws on the bobbin holder with your mini screwdriver from your kit to secure.
Now rotate the flywheel towards you, the bobbin holder should stay still while the rotary hook goes around.
If you have any issues feel free to email me on cwrogers@tpg.com.au and I'll try to elaborate or take a pic of the process tonight.
And remember to hold the two threads when you start a seam at the back for a few stitches to avoid the thread jams, just a quirk on these machines but I love them so much.
Hope this helps you.
Mar 16, 2011 | Sewing Machines
Singer cg-590 floating bobbin keeps jumping out of it's holder.
I'm not completely familiar with the model, but even a floating bobbin holder as you described should have some sort of a hold down. There may see a small swinging arm on the bottom right side of the bobbin area that needs to be located over the bobbin case to hold it in place. Let me know if this doesn't work.
Feb 20, 2009 | Brother CS-8072 Computerized Sewing...
Kemore sewing machine
Practicly impossible to "describe" how to do it, you need to be shown, other added problem is there are numerous different types of bobbins etc. Unless you can get someone to show you the next best option is to get hold of a copy of a user manual for your machine. Best of luck
Mar 25, 2008 | Sewing Machines
Sewing Machines Logo
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
