I have an old robin ey20d generator and can't figure out what its fuel is! Thank you!
15 years old more or less
    Champion:
  • 203 Answers
You can get the manual for your generator at this site.
Posted on Dec 17, 2014
How to change the fuel filter on guardian quietpact rv generator
Dec 05, 2015 | Generac Electrical Supplies
Homelite LR5550 serges when it runs is there a way to set the governor so will run smooth
Try opening the high speed jet about 1/8 turn. If that don't work clean the carb.
Jul 07, 2014 | Garden
99 C230 slowly dies on road
Some possible solutions (from general experience (i'm 55 yrs old)): 1. Plugged up fuel filter; Replace it. Part costs less than $10.00.If the filter is just in front of the tank, it should take a screwdriver and 15 minutes or less to swap. 2. Water in the fuel tank; Add a bottle of "Heat" to the tank. Cost ~ $3.50 or less. This next may require some trouble shooting or head scratching first. DO #1 & #2 First. (Won't hurt & Doesn't cost much) 3a. Partly clogged fuel line. 3b. Cracked fuel line. (Sucks air into the fuel line) Depends where the fuel pump is.(Also look for fuel leaks, especially around hoses in the fuel line.) 3c. Clogged carb.Filter (if it exists). Verify fuel delivered to Carb by disconnect @ Carb. attach small hose to catch container then turn on (NOT Start) ignition.Should hav a steady flow of fuel for at least several seconds. If so, Replace carb. filter. 4. Weak/ failing fuel pump. Major pain but backyard mech can do it with helpmay take half a day.May need to have a few empty gas cans available to save the existing fuel.. Replacement In-Tank pump assembly should be less than $50.00.
Mar 25, 2012 | Cars & Trucks
Onan 5500 marqui gen set stumbles on demand
Steve,
The microwave alone shouldn't cause a problem for the generator as even the most powerful models run about 1200 watts or about 10 amps. An air conditioner on the other hand, can draw considerably more power to run depending on BTU size; 15 amps and up is not uncommon (and even twice as much as that though only briefly when starting).
If these were the only things connected and on, the generator should be able to handle them - again depending on the BTU size of the AC unit. Generators state their capacity in Watts, but must of the devices we connect are in Amps. Calculating Watts in an AC circuit is complicated, but pretty close to the much easier Watts in a DC circuit for most residential settings. Here's how it's done:
Watts = volts x amps. Pretty simple stuff. Your generator is rated at 5500 watts. The microwave is say, 120 volts / 10 amps - which equals 1200 watts. The generator has 4300 capacity available now. Suppose your air conditioner is rated at 120 volts / 15 amps - which equals 1800 watts. 4300watts - 1800watts = 2400watts capacity is left. But, the starting current for the AC is as much as 25 amps for a few seconds (and once started drops back to 15 amps) - which means there's only 1200 watts capacity left. Add up the rest of the appliances you're running at the same time (TV set, Cable / Satellite box, stereo, toaster, lights, computer, etc.- you get the idea), and you can see how you might have exceeded the 5500 watts capacity of the generator for a few seconds. It's at these times that your hear / see the generator speed falter and sputter, lights dim, etc.. If this is happening a lot, you may need a larger or additional generator.
I hope this helps and good luck!
Dec 25, 2011 | Watts Onan Portable Generator - 5000 ,...
I have an old makita g2700 generator with a robin ey25 engine.i need to change the oil.what grade of oil is recommended please
Hi Tim,
That engine's original production started out in 1987 by Teledyne and then taken over by Robin Subaru. Replacing your oil depends upon your climate, here's a list Below 14 degrees F 10w30 14-68 degrees F SAE #20 68-104 degrees F SAE #30A complete fill requires 28.7 OZ of oil according to the service manual.If the engine is burning a lot of, oil I would suggest that you jump up a rating on the oil. For example if you are in Florida and it's 95 degrees outside I would useSAE #40. If the engine is still within its tolerance and not consuming oil I would stick with the factory recommendations. On a further note,This is a fairly old generator and was designed to run on straight gas, NO ETHANOL!!!! Today's gas has at least 10% and it will wreak havoc on your fuel system. Ethanol will absorb water from the moisture in the air, It bonds with the water and sinks to the bottom of the tank. Gas with ethanol has a shelf life of about 30 days. Ethanol will also act as a solvent on the fuel line, creating a gum on the inside of the line and make the line very brittle. The gum will eventually migrate into the carburetor and foul it. I would strongly suggest that you replace the fuel line with Tygon or any other ethanol safe material, I would also swap out the fuel filter or add an inline one. Do not store the generator full of fuel, store it empty. Check out the website pure-gas.org to see if ethanol free gas is available in your area. It will last much longer especially with a little bit of Stabil in it. Good Luck,Michael Burke
Dec 01, 2011 | Coleman Electrical Supplies
The generator kicked the breaker of and was smoking and smelled like electrical
What type of load (electrical) was hooked up to this generation?? If the surge voltage and current was exceeded above the generator maximum for any length of time. There problems, it could be the regulator, insulation burnt off the windings.
I am taking a guess here. Now, 7100 Watts is it typical surge wattage. This mean that the generator will deliver 7100 Watt (voltage times current) this is know as the power factor. The actual operating load would be 6800 Watts and I would even operator the generator at its peak wattage. Something in the neighborhood of 10--15% less the peak wattage. Therefore a good positive theatrical Wattage would be 5800 to 6350 operating wattage. Then this generator would run all day.
Just remember Ohm's Law. Current plays a big factor in loading of a generator while the operation voltage is at 120 AC Volts. Example: electric motor; Now electric motor when starting will pull three time its operation current. Operating current for a 1/2 HP AC motor is 6 amperes but start this electric motor will require 18 amperes. This is one reason why they starting capacitors on smaller electric motors. Larger three phase electric motor can literal stop a generator cold...in its tracks. It put such a large demand on the generator it stops the engine powering the generator. I have seen crankshaft break because the generator could handle the heavy current load.
Remember, any time you are running a small gas powered generator. All ways figure what the load and surge current load will be before hooking up any generator. Normally this is figured in VA (volt/amps). Wish you lock. GB...stewbison
Sep 05, 2011 | Robin Subaru RGX7100 7100 Watt Gas...
Briggs & stratton 550 / surges, gas hog
check your air filter. If it's clogged, the engine will spool up to keep from dying, run for about 15 seconds, then it will happen again. If that's it, just clean the air filter. Solved my problem
Jul 26, 2010 | Briggs & Stratton Garden
Is Husky 5000w a Chinese product?
Well tricky question ...Coleman factory is out of Wichita, Kansas that is there headquarters. but Subaru's head office is out of Nishishinjuku, Shinjuku-ku, Tokyo. so i think you have a mixed bag...good luck
Apr 17, 2010 | Coleman Powermate Subaru 5000W Portable...
Televison & Video Logo
43 people viewed this question
Top Televison & Video Experts
Electro Med Services...
