Question about 1993 - 1997 Honda Civic del Sol Engine Coolant Thermostat W0133
Were is the thermostat on a 1993 Del Sol - 1993 - 1997 Honda Civic del Sol Engine Coolant Thermostat W0133
  • Gates Master
  • 14,406 Answers
Here's a link on replacing your thermostat Scott. Repair Guides Engine Mechanical Thermostat AutoZone com
Posted on Nov 19, 2014
1993 Honda Del Sol makes noise when turning and
Sounds like your CV joints (axles) may be going bad.
Nov 01, 2013 | Honda Cars & Trucks
1993 honda del sol horn does not work. Horn
Im in the same boat with my 99 civic si. it is wiring in the steering wheel that is causing your horn to not work. it is a lot of work to replace the wire in the steering wheel, so if you want a horn, my suggestion is to wire the horn to a aftermarket switch. it is a cheap and easy solution and will get the job done.
Sep 08, 2009 | 1994 Honda Civic Del Sol
Where can I get wiring diagram for 92 Honda Civic LX?
Here several documents:
Engine wiring-1992-95 Civic (except VX)
Engine wiring-1992-95 Civic VX
Chassis wiring-1992-95 Civic, 1993-95 del Sol
Good luck... remember rated this help.
Aug 19, 2009 | 1992 Honda Civic
Where is the low pressure access port located on a 1993 honda civic del sol?
Low side acces (A/C) is in the suction tube, between the compressor and the firewall (thicker tube)
May 12, 2009 | 1994 Honda Civic Del Sol
1993 honda del sol... heater wont blow out hot air, only cold...
Sounds like he left a hot wire out, and not a ground. Most likely shorted something in your heater controls. Check there first.
Mar 07, 2009 | 1994 Honda Civic Del Sol
Which engine fits a del sol honda 1993
Anything that is OBD 1 or newer if you want it to be legal, here are the most common options and the basic requirements. 1. B16A2/3: Completely bolt-in Swap, VTEC needs to be wired, SIR II, Hasport shift linkage. Del Sol VTEC for the del sol 2. B18B: Completely bolt-in swap, SIR II, Hasport shift linkage. Del Sol VTEC for the del sol 3. B17A: Completely bolt-in swap, cable-hydro transmission kit(not recommended) or hydraulic b-series transmission, VTEC needs to be wired. 4. B18C1: Completely bolt-in swap, VTEC needs to be wired. 5. B18C5: Completely bolt-in swap, OBD conversion, VTEC needs to be wired. 6. B16B: Completely bolt-in swap, OBD conversion, VTEC needs to be wired. 7. H22A: Mount kit required, Hasport shift linkage, VTEC needs to be wired. 8. B16A: Not recommended! Too much work, more costly compared to B16A2/3's. 9. D16Z6: Completely bolt in, VTEC needs to be wired. 10. D16Y8: Completely bolt in, VTEC needs to be wired. If you want to know more check this out - http://hondaswap.com/swap-articles/en gine-swaps-101-a-29052/
May 18, 2008 | 1995 Honda Civic del sol
1993 - 1997 Honda Civic del Sol Engine Coolant Thermostat W0133 Logo
Top Gates Vehicle Parts & Accessories Experts
Lodhi Autos
Lodhi Autos
Walter Turteltaub
Level 1 Expert
Bill Boyd
Are you a Gates Vehicle Part and Accessory Expert? Answer questions, earn points and help others
