Question about Vtech 5.8GHz Analog Cordless Phone
<!-- from fixya rte -->How do I register a cs6114 phone - Vtech 5.8GHz Analog Cordless Phone
  • Vtech Master
  • 5,054 Answers
Do you need to register a handset? Make sure the battery is fully charged on the handset and remove the handset from the base. With the phone not in use, press and hold the Find Handset button on the base. After about 4 seconds, the In Use light should light up. Now press the # key on the handset that you need to register. It should say Registering and then complete the registration within 60 seconds. This will only work if the base has power and is connected to a working phone line.
If you need to register the phone with Vtech, go to http://www.vtechphones.com/support/general/product-registration .
I hope this helps.
Posted on Nov 18, 2014
How do I register my vetch cordless phone?
General - Product Troubleshooting - VTech® Cordless Phones
www.vtechphones.com/support/.../35/178
VTech Communications Inc.Step 1: Place the handset in the base or charger. If PRESS FIND HS 4 SEC ON BASE does not appear on the screen after a few seconds, lift up handset and recradle it in the base or charger. Step 2: On the telephone base, press and hold FIND HANDSET for approximately four seconds.
Product Registration - VTech® Cordless Phones
https://www.vtechphones.com/.../product-re...
VTech Communications Inc.Vtech DECT 6.0 cordless phones are among the most advanced and innovative homephones on the ... Product Registration. How do I register my product?
vtech cordless handset, how to register - YouTube
? 3:21
https://www.youtube.com/watch?v=dV9rZ_cYcks
Feb 22, 2015 - Uploaded by Brian Williams
i registered my handset but im not able to call and answer call from my ... you lose your phone you have to de register allphones and start over.
Jan 21, 2016 | VTech Communications CS6114 - cordless...
I have a vetch mod# CS6114 I checked the base unit and it gets power to charge phone but I can't get a dial tone. I even hooked up to another line and still won't work.
This sounds like a registration problem, the
handset must be de-registered from wherever
it thinks it is and then registered to your base.
( I ). First, to de-register a cs6114 handset ---
0. Start by taking off the battery compartment cover.
1. press [menu]
2. scroll up/down to "Settings"
3. enter * 7 8 9 0 #
4. scroll from "Test Base" to "Test Handset", press [select]
4. scroll down to "next page", press [select]
5. scroll down to "Register Clear?", press [select]
6. display asks "Confirm?" or "Register Clear??",
press [select]
7. display reads "Ok" and chirps, press [ off ]
8. UNPLUG THE HANDSET BATTERY
(this is why the cover was off)
9. Wait ~30 seconds, re-connect the battery &
replace the cover
10. display reads "Not Registered"
( III.) To register the cs6114 handset to the base:
1. press [Find Handset] on the base and hold for
~4 sec until the "In Use" lamp lights.
2. press # on the handset and set the handset into
the handset cradle on the base
3. within 30 seconds or so, the handset will either
chirp and display "Handset Registered", then
"Handset #x" or it will say "Registration Failed".
NOTE: the battery must be well charged prior to the
registration process, a weak battery may cause a
"Registration Failed". Charge the battery for a
few hours and try the registration ( III ) again.
NOTE 2: Some cs6114 bases do not have the "In Use"
lamp indicator. To register the handset simply park it
displaying "Not Registered" in the base cradle and wait
for the registration to occur. Pressing # as above may
be required, maybe not.
Good luck !!
Feb 12, 2015 | Vtech DECT 6.0 Cordless Phone with Digital...
My vtech phone say not registered and see manual #cs6114
VTech Communications Inc.My handset displays Not Registered. ... If PRESS FIND HS 4 SEC ON BASE does not appear on the screen after a few seconds, lift up handset and recradle it in ...
My vtech phone says not registered and not sure why ... - Fixya
www.fixya.com/support/t10092346-vtech_phone_says_not
Aug 13, 2011 - my vtech phone says not registered and not sure why and how come? can ... See page 26 of the manual for detailed instructions on HOW TO ...
My vtech dect 6.0 phone says not registered how do i fix it ...
www.fixya.com/.../t7993579-vtech_dect_6_0_phone_says_not_registere...
Jan 26, 2011 - my vtech dect 6.0 phone says not registered how do i fix it - VtechDECT 6.0 ... If you click on the above it will take you through to the manual, hope i`ve helped .... See all Vtech DECT 6.0 Digital Cordless Phone Questions ...
? 3:21
My phone says no line plz help me. Been without a ... VTechuser manual had no instructions to set up an ...
[PDF]User's manual - Vtp-media.com
Feb 10, 2015 | VTech Communications CS6114 - cordless...
How to change number of rings on VTect cordless CS6114-11
The CS6114-11 isn't an answering machine. It will ring until you answer, an answering machine or voicemail system picks up, or the caller hangs up.
To change the ring count on your answering machine, consult its documentation. If you require further assistance, please add a comment to this question and identify the answering machine or voicemail system.
Jul 30, 2014 | VTech Communications CS6114 - cordless...
How do i check my voice mall on my Vtech phone Model number CS6114
The CS6114 isn't a voicemail system. You have unheard messages on the voicemail system provided by your telephone company. This system records messages when someone calls while you're already on the phone. Please contact your telephone company for instructions on accessing their voicemail system.
Dec 10, 2012 | VTech Communications CS6114 - cordless...
Vtech phone model CS6114 failed to register
There is no red in use light on the CS6114 Model
Sep 09, 2012 | Vtech i5871 Cordless Phone
How do I check voicemail on my vtech cs6114?
The CS6114 isn't an answering machine. If you have a separate answering machine connected to your phone line, consult its documentation. If you subscribe to a voicemail system offered by your phone company, contact them for information.
Oct 26, 2011 | Lands Phones
How do i retrieve my voice mail model cs6114
The CS6114 isn't an answering machine. Please consult the documentation for whatever answering machine or voicemail system for instructions.
Aug 30, 2011 | Uniden DECT 6.0 Cordless Phone ID
How do i listen to voicemail on my CS6114 cordless Vtech phone?
The CS6114 isn't a voicemail system. If you have messages on the voicemail system provided by your telephone company, contact your telephone company for instructions on accessing their voicemail system.
Aug 23, 2011 | Vtech DECT 6.0 Cordless Phone with Digital...
I just bought an vtech cs6114 one hanset, when i connected it appears a messeage Not registerd, it looks dead, who can i register it
If the CS6114 handset says "Not Registered", press and hold down the FIND HANDSET button located in the Base cradle. In about 4 seconds, the IN USE light on the Base will glow red. Now, release the Find Handset button and press the # key on the handset. The handset will display "Registering" and then "Registered".
Jan 17, 2011 | Cell Phones
Vtech 5.8GHz Analog Cordless Phone Logo
242 people viewed this question
Top Vtech Lands Phones Experts
Are you a Vtech Lands Phone Expert? Answer questions, earn points and help others
