Question about Puma Air Air Compressors Puma Air PUK5520G Contractor Horizontal Air Compressor - 20 Gallon
Manual for model #pp5020
I am trying torestore a air compressoe pp5020
Poulan owners manual
Which model do you have exactly? I have 6 different manuals , 3 for the PP4218, depending on the last Letter A, etc. the PP4618, PP5020 etc.
May 18, 2014 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
Error display E1 01.WHAT IS THE CAUSE?
My samsung aircon its dispayin 416 on the remote wath can be a problem.and the compresso get very hot
Sep 04, 2012 | Heating & Cooling
I have a 1/2") Air
Does the drive move if you try turn it manually, if it does not strip the unit and check the bearings. If the motor and vanes are seized the air will just vent out of the exhaust. If it turns, Dismantle the trigger and air inlet valve and check that for sticking, leaking or broken parts.
Jan 29, 2011 | Garden
Not cooling clicking sound refrig compresso and
IT'S MOST LIKELY THE START RELAY/OVERLOAD PROTECTOR ON THE SIDE OF THE COMPRESSOR. UNPLUG UNIT AND PULL START RELAY OFF AND SHAKE. IF SOUNDS LIKE IT'S FULL OF GRAVEL IT'S BAD, OR GET VOLT /OHM METER AND CHECK CONTINUITY BETWEEN THE START AND RUN TERMINALS ON BACK SIDE OF RELAY, WHILE YOUR THERE CHECK CONTINUITY BETWEEN THE BACK SIDE OF OVERLOAD AND WHERE L1 WIRE COMES IN FROM THE HARNESS. IF ALL THAT CHECKS OUT THE COMPRESSOR MIGHT BE BAD OR DRAWING TOO MUCH CURRNET FOR THE FACTORY START DEVICE. YOU DIDN'T NOTE A SERIAL #, SOME OF THOSE MODELS WERE UNDER RECALL FOR THE RELAY/OVERLOAD PROBLEM.
Oct 06, 2010 | Maytag MSD2756G Side by Side Refrigerator
After running compresso .ther is frost on accumulater.why?
Check your gas levels & ensure that both indoor & outdoor fans are operating . Also check there are no obstructions over either coil.
Jun 29, 2010 | Fujitsu 24R1 Air Conditioner
Do you check the low port side or high port side, when checking air compressor of a 98 Pontiac Sunfire?
mcdevito75 here, I think your speaking of the air conditioning, it is charged from the low side, if the compressor will not come on you"ll most likely need freon, the compressoe must be on to check it"s operation.
Jun 17, 2010 | 1998 Pontiac Sunfire
Machine will not clear existing pressure
Please check your unit compressor also & make sure compressoe haveing minimum 13''Hg suction.
Jul 03, 2009 | Robinair Cool Tech 34700Z Recovery,...
Dometic Blizzard 1300 roof top unit blowing fuses
YES< this is a "direct ground and either the motor or compresso is grounded--(DEAD)!and needs to be replaced.
Sep 09, 2008 | Dometic Rooftop RV Air Conditioner
Bought virgin VM-500 MP3 player 5 GB
Make a Hidden folder and Name it System, then put the firmware file PP5020.mi4
then it will work
Regards
http://a.b.vcdz.free.fr/vcdz/PP5020.MI4
Jul 31, 2008 | Virgin Electronics VM-500 MP3 Player
Puma Air Air Compressors Puma Air PUK5520G Contractor Horizontal Air Compressor - 20 Gallon Logo
43 people viewed this question
Top Puma Air Air Compressors Air Tools & Compressors Experts
John Trevino
Joe Garcia
Joe Garcia
Are you a Puma Air Air Compressors Air Tool and Compressor Expert? Answer questions, earn points and help others
