Get a schematic for Fisher MT 6420 turntable. Need to know if there is a belt.
Need a schematic. I want to see if it takes a belt.
    Scholar:
  • 188 Answers
The 6420 is a direct-drive turntable. There is no belt.
Posted on Nov 22, 2014
fire sine
  • 382 Answers
SOURCE: Teac turntable belt came off.. help!
Through the 2 holes on the platter, lift the platter up. Take the belt, flip the platter over, and stretch it around the center ring. Flip the platter back over and turn to so one of the holes is over the spinning motor. With your finger or with a blackstick, stretch it back onto the motor head.
Also check the belt for wear....that should do it.
Keep me posted.
Posted on Dec 16, 2007
djproaudio
  • 515 Answers
SOURCE: I need a belt for a fisher DAC-145 turntable
You can find a replacement belt HERE.
- Davis
DJ Pro Audio
www.DJPROAUDIO.com
Posted on Jul 15, 2008
  • 122 Answers
SOURCE: belt drive replacement B&O Beogram 1000, type 5203 turntable
length approx 30mm shorter than old one, knock out pin on shaft to take platter off.more often than not the motor runs slow after repair,if its a round style ac motor htey cant be fixed.
Posted on Jan 11, 2010
  • 256 Answers
SOURCE: turntable belt is off.
Under the felt of the turning platter section, there should be two rather large holes. Insert your thumb and forefinger and pull the table off. You should also see where the existing belt is running. Insert new belt around the motor first and replace the table section. Now, through the two holes, manouver the belt onto the table section until it spins freely
Posted on Jun 12, 2010
SOURCE: I need to replace the belt on a fisher MT-6117
Hi,All you need to do is get a rubber mallet or such and smack the spindle shaft and it will pull straight up and off!!
Posted on Sep 11, 2010
User manual for a Fisher MT750 turntable
Elektrotanya for electronics experts
The above is for service.
Fisher MT 750 Manual Linear Tracking Turntable Vinyl Engine
The above is for general users, and registration to login for free download is required. Activation is by email that you must respond to within 12 hours. Check your spam folder to be sure it is received within 1 hour, in case their email to you is accidentally blocked.
Feb 11, 2018 | Fisher Audio Players & Recorders
Fisher mt 6250 I need a replacement stylus. What will fit my turntable?
Hi, your Fisher MT6250 takes a Pickering XV-15 stylus. We have them in stock. cheers john. Stylus City
Jan 25, 2014 | Audio Players & Recorders
Turntable will not turn, power goes on. Does this system have a belt for the turntable or is there a manuel or schematics to this system?
You will need to check your belt for wear. Lift felt on platter and check belt tension. It may need replacing. To replace, simply lift platter section of the unit, taking note of the belt position. replace and your problem will be solved
Apr 04, 2010 | Crosley CR49 Shelf System
http://www.archive.org/details/Turntable_Belt_Installation
above is a generic video that applies to almost all belt driven turntables including yours that will show how to install the belt and a few other things. the website shown in the video lists your belt under the "find my player" button on the left side of that site. look for DAC-145A listing. your old belt or the belt path should measure about 30-31 inches or so.
Sep 20, 2008 | Panasonic Home Theater System System
- Davis
DJ Pro Audio
www.DJPROAUDIO.com
Jul 13, 2008 | Audio Players & Recorders
Fisher Studio-Standard Belt-drive Semi-Automatic Turntable MT-32
Most likely the grease in the whole system has started to stiffen or the motor is failing. This can be fixed. Try oiling the motor first. If that fails, I'd look at the motor driver IC as the most likely failing part.
Dan
May 22, 2008 | Audio Players & Recorders
Fisher turntable mt 6410 removal
Look at spindle bearing in center of t-table. There is probably a small ring lock there holding the table. Use a pick or small screw driver to carefully remove this ring.
May 07, 2008 | Audio Players & Recorders
Keep me posted.
Dec 05, 2007 | Teac P-A688 Turntable
110 people viewed this question
 Grubhead
Grubhead
