Question about Refrigerators
Why has my American-style fridge freezer stopped making ice?
My fridge freezer has suddenly stopped making ice. The shoot where (I presume) the water comes out from to fill the ice tray does not appear to be blocked. The filter was recently replaced, approximately three months ago. Water still dispenses from the front of the fridge fine. I have put it into "Ice Maker Lock" mode for 24 hours and then turned that off and checked the next day, but still nothing. Nothing is even in the ice tray
  • Michael Florance
    Michael Florance Nov 17, 2014
    I should add that this has literally just gone out of warranty about four weeks ago. And the make and model is Daewoo DRS30DSMB
  • Michael Florance
    Additionally, I have just found a "Test" button on the underside of the ice maker. Pressed it, mechanism began turning the tray until almost 180 degree and then back again. All seemed to be working fine, so it looks as though water getting to it is the problem...but I have no idea where to go from here!
  • Refrigerators Master
  • 744 Answers
Hello Michael;
My name is Peter. I am a retired field service refrigeration technician.
You did not provide a model number so I will help you as best I can. The fact that your water dispenser works narrows it down.
Here are the causes for your icemaker not to fill:
1.) In the back of your refrigerator there is a solenoid valve for your ice maker and another for your water dispenser. The solenoid valve for your icemaker has the smaller plastic tubing that runs up the back of your refrigerator to the top. With the unit unplugged, remove the bottom back cover. remove the two connectors on the solenoid valve. Using a multi-meter, set the meter to the lowest Ohms. Place one meter lead on one of the solenoid metal contacts and the other lead metal contact. If the solenoid is good the meter will read; '0'.
Ice makers have control modules. The control module tells the water solenoid valve to open and for how long to fill the ice cube mold. Then a temperature sensor will tell the control module when the ice cubes are frozen. The control module will, if the ice maker is cast steel - will tell the heater to turn on for a period of time, and then tell the fingers to rotate to discharge the cubes, or if it is a flex mold, to flex. Then the cycle repeats.
The only one ice maker that is repairable is the one with the cast steel mold. The others are just throw-a-ways.
So, if your ice maker solenoid valve checks out, replace your ice maker. Do not buy it locally. You can save 40% or more if you buy over the internet
Posted on Nov 18, 2014
  • Michael Florance
    Michael Florance Nov 18, 2014
    Many thanks for that response, Peter. I added two comments after I posted that with some additional information. Make and model is Daewoo DRS30DSMB and I found a "test" button - this revolved the ice maker 180 degrees, as if to empty into ice bucket, and then back into position; seems to be water getting into the ice is the problem. Does this affect your answer in any way?
  • 54 Answers
SOURCE: ice maker problem
let it run its caused by stagment water in the system it will clear over time.
Posted on Feb 12, 2008
  • 143 Answers
SOURCE: Neff K3990 Fridge Freezer ice maker not working and water leaking out
Sounds like the water hose to the ice maker has come loose. Is it in warranty?
Posted on Jul 23, 2008
SOURCE: Ice Maker Slow Making Ice and Water Dispenser No Longer Dispenses
Try replacing the filters, they might be slowing the water flow.
Posted on Sep 20, 2008
  • 33 Answers
SOURCE: Amana Side-by-Side Fridge Model SBD21VPSE
If there is a reset button on your ice maker try pushing it. Many ice makers have two holes for reset. A general rule of thumb is if the ice maker fingers are stopped in a slightly vertical position then your ice maker unit is working. If the fingers are stopped anywhere else then it needs some sort of attention or replaced. Make sure there is water, or ice in the ice maker tray, if not then the problem is with water supply.
Posted on Nov 29, 2008
  • 10865 Answers
SOURCE: Ice maker not working
If your ice maker has stopped producing ice completely, check these, in this order:
  • It may be turned off. Look for the wire along the right side of the ice maker that looks a bit like a coat hanger. If the wire is in the raised position, the ice maker is turned off. If so, try one of these:
    • If your ice maker has a small red plastic lever, lower it to lower the wire.
    • If there's no plastic lever, simply lower the wire.
    In either case, the ice maker should begin producing ice again. Also make sure that the temperature is 8 degrees Fahrenheit or lower. If the freezer is too warm, the ice maker won't cycle properly.
  • The ice maker fill tube may be blocked with ice. If so, melt the blockage using a hair dryer-but be careful to not melt any plastic parts! Also replace the water shut-off valve or water-inlet valve, or both, if necessary.
  • The ice maker head assembly may have broken parts. Look to see if the gears are broken. Check to see if the small plastic arms that rest against the ice rake are broken. If the ice maker head assembly is modular and you've found broken parts, you can just replace it.
Posted on May 30, 2009
Freezer not making ice
Is it an icemaker? Either the water valve is bad or the freezer isn't cold enough or the ice maker is bad. Is it just a ice cube tray? Then it's not cold enough.
Aug 25, 2016 | Samsung RSH1DTMH American Style Silver 524...
My American style fridge /freezer - Siemens KA62DS506B stopped producing Ice and water . The panel stopped being lit and there is a msg saying IWD Off
Your ice delivery water soleniod has failed, you can locate the solenoids in the rear lower of the fridge freezer unit where the pipes for water delivery goes in to the unit, locate the Ice delivery solenoid and replace it, easy test is to place a test cord on each solenoid and chech for operation under pressure. Russ
Apr 25, 2012 | Refrigerators
Neff K3990 American style fridge ice maker is not producing ice
The ice maker unit give the command to the water valve to relese water for a short time.
you cna check with volt meter on the water volve that got the pip go to the ice maker unit if it getting 120V for short time when the fingers of the ice maker making full round.
if you get 120v the problem is the valve (the ice maker and the water have difrent water path so its difrent valve used) if you dont get 120v or the fingers of the ice maker not turning then its your ice maker unit need to be replace.
I hope you find this Very Helpful and best regards!
Jan 04, 2010 | Refrigerators
Hi freezer on american style fridge freezer is
there is a defrost mode that melts any frost or ice on the evaporator coils and drains it into a pan under the fridge. if that drain is blocked, the water will pool inside. also check the door seals. if warm moist air leaks in, it'll condense on the cold interior and pool as well.
Nov 10, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
The fridge of my American style fridge/freezer is
You can use a hairdryer on the frozen parts.
The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp ..
Sep 06, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
RS21FCNS - No water
It could be the water soleniod screen is clogged or if you have a filter clogged. Take the water line loose and check the screen first.
Sep 25, 2008 | Refrigerators
Water Dripping Inside
Sounds like a blocked defrost drain. By "American" I presume you mean side-by-side.
I had a similar problem with a freezer-on-top style Samsung. The solution to that was to defrost the freezer, remove the false backing plate in the freezer (required removal of the ice cube tray. the panel just pops out with a bit of pulling). The drain hole beneath the freezer coils was blocked with ice. This drain passes down into the fridge and then out the back of the fridge into the evaporation pan next to the motor. There is a collector pan under the freezer coils, this and the drain hole were filled with ice. When the freezer goes into its self-defrost cycle the water collects here and then overflows into the fridge.
I removed the ice with hot water/vinegar mixture (so it doesn't re-freeze immediately) and simultaneosuly used a bit of chiselling with a screwdriver to clear the drain plug. I did this from inside the fridge working up the drain hole into the freezer. The whole job took about an hour.
Aug 24, 2008 | Freezers
Jul 23, 2008 | Refrigerators
Freezer defrost LG american style
Defrost the unit for two days with the doors open...I know you're going to lose your contents. You may have ice on the coils internally. Next make sure you've cleaned the external coils under the unit. Leaving liquids open inside the unit or setting it colder than required will both cause issues like the ones you've got. Also, be sure all air vents inside the unit are unblocked and the door closes tightly all around.
Mar 09, 2008 | Refrigerators
Refrigerators Logo
76 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
