Question about Panasonic TH37PX60 37 in. Plasma Television
Problems using video to record from tv
Ok to record analogue pictures on VCR but cn't seem to pick up and record the freeview channels from the TVs embedded freeview
  • Anonymous Mar 21, 2014
    have tried switching off at wall because no response from the remote [batteries ok]
  • 67 Answers
The tv has 3 scarts try connecting to AV3.
If still no luck go to the TV Menu and then 'Setup Menu' find settings and change AV2 OUTPUT TO TV.
Posted on Nov 14, 2007
I hava psvr71 vcr and a new Sharp Asquos tv and I cannot get the vcr to record. It will play back but not record.
The VCR doesn't have a digital tuner. It has an analogue tuner. So it won't pick up the digital TV transmissions. You need a Freeview box connected to the house aerial system, and then connected to the VCR by a SCART lead. Put the VCR on one of the AV channels so it "sees" the signal from the Freeview box as a predicament for its own tuner.
Some older TVs had a video out function. This no longer applies to new TVs.
Sep 15, 2014 | Proscan New Original PSVR71 Remote Control
Connecting up CRT TV, VCR, DVDR and digital box
I think the better task is (A)
You can try switch scart's!! Then try to record on DVDR or leave as it is and look out for picture on your VCR!!! If you do (B) you will lose a picture quality!
good luck
Jan 31, 2008 | Televison & Video
The picture doesn't hold. The picture shows just snow on the tv.
VCRs are analogue. So their tuners won't pick up digital TV signals, and their output from the aerial socket is analogue too. You'll have to make sure your TV is on the analogue TV tuner and then tuned to the VCR output channel if you want to use the aerial connection for viewing. It's probably a lot simpler though to use the VCR's AV output to the TV.
If you connect a TV receiver (Aerial/cable/satellite) to the AV input on the VCR, then switch the VCR to that AV input, you will see and be able to record programmes.
Aug 25, 2014 | Televison & Video
I have a Panasonic TV with inbuilt Freeview TH-42PX70BA. I also have a Hitachi VCR VT-FX980E which I use to record analogue channels. Now that the analogue signal is disappearing I would like to record...
The simple solution is to connect your VCR to a Freeview set top box, which you can pick up for around £10. Simply connect the box via a scart lead. If the Video has two scrat sockets use the other for the box. For recording set the VCR up the same way but instead of selecting channel one or two etc set it as AV2 if that is the place the box is connected. When recording leave the box on the station you want to record and the VCR will record it. Don't forget to allow a few minutes either way for the start and stop times. Also if the VCR has PDC switch it to off.
You should be able to record this way whilst watching another channel on the TV. Some Freeview set top box's have timers on them so if you are out and want to record two shows on different channels you can.
If you have only one scart then a scart switching unit such as this below will solve that problem. Found on Amazon.
Sep 13, 2011 | Televison & Video
I live in the United Kingdom and we are in the process, area by area, of converting our TVs from analogue to digital. My area was converted to digital in May. Since when my VCR will not function - it...
If the video does not have a freeview tuner it will not be able to record. There is a solution! All you need to do is get a freeview box, Argos have an Alba model for around £18 at the moment, Connect it via a scart to your video, if it has to scart connectors use the second one, often marked AV2. Then when you want to record, turn the box on to the channel you want to record, set the record timer, but change the channel to AV2 for the recording. That should then record the station, while you watch the other channels. If the VCR has only one scart, you can get a scart switching box, as shown below, from places such as Amazon.
Jun 21, 2011 | Televison & Video
I have an Alba 32880hdf freeview tv. I cannot record freeview programmes to my panasonic NV-FJ 780 vcr which has 2 scart sockets. I have no problem recording the teresteral channels. Can you help pls
Hi Victor,
You can't record the Freeview channels from the TV. It doesn't work that way. The reason you can still record terrestrial channels is because the VCR is still connected to your roof aerial with a co-axial cable and the VCR has its own built-in analogue tuner for recording terrestrial TV programmes.
To record the digital Freeview channels, you will either need to connect a separate Freeview set-top box to the VCR, or buy a VCR which has a built-in digital (DVB-T) tuner.
The VCR does not record programmes from the TV. It needs to be connected directly to the signal source, i.e. your aerial.
If you need any further assistance, please let me know.
Regards,
BElectric
Jan 15, 2011 | Televison & Video
Digital tv -analogue vcr records and time records and plays back only with the picture on. It will not record with picture on standby
Of course it won't record if the TV is in standby as there is no signal. If you wish to record TV programmes without having the TV switched on, you need a freeview or freesat box for your Video Recorder.
Hope this helps.
Nov 15, 2010 | Hitachi C21FL20F TV
Can,t record from digital channels
You’re dvd/vcr only has analogue tuner so the only way to record is by using the Phillips tv but as said tv will need to be switched on.you would need a sky or cable box or a free view box separate to the tv to record with tv off.the vcr will recieve only on the av channel av1 when connected to tv.a sky box or cable can be connected to av2 on sharp using a second scart lead and box
Feb 05, 2018 | Sharp Televison & Video
This tv has inbuilt freeview, how do i use a dvd recorder to record off it?
The Wharfdale Machine that has Freeview has an F on the end ie vdrhd400f. It may be yours is an analogue version. Always possible that you can use the TV as an output via a scart to record what you are watchin
Jul 14, 2007 | Sony BRAVIA KDL-40S2000 40 in. LCD HDTV
Panasonic TH37PX60 37 in. Plasma Television Logo
114 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
