Question about Electrical Supplies
Why can't I start my Rigid RD905712 ?
Have put in fresh gas and a new fuel filter. Fuel is not getting to the spark plug. The air filter is clean.
  • Tina Strait
    Tina Strait Nov 17, 2014
    We got it started. Had to add more gas so it could get over the crook in the gas line.
  • 1,169 Answers
Thanks for letting us you found the problem.
Quoted Text>
Posted on Nov 19, 2014
mamicheddy
  • 79 Answers
SOURCE: Won't continue running
This unit has a fuel solenoid on the carberator, which opens to allow fuel to the carberator. Check to see if this solenoid opens while cranking.
Posted on May 07, 2009
  • 7 Answers
SOURCE: 2 year old honda eu1000i generator with new spark
SOUNDS LIKE TO ME YOU HAVE A PROBLEM IN THE OIL ALERT SYSTEM, IF YOU HAVE THE REPAIR MANUAL IT WILL TELL YOU HOW TO TROUBLE SHOOT IT!!!
Posted on Sep 10, 2009
  • 9 Answers
SOURCE: Onan Generator stopped working in motorhome
Yes it wil not let you run your motorhome out of fuel they set it up that way so you dont strand yourself you may have a air bubble in the fuel line to the generator try blowing air generator fule line back into the tank
Posted on Feb 01, 2010
  • 90 Answers
SOURCE: Honda eb3800x will not start.
the worst thing for generator and compressors are to sit up. when you do sit them up put stabil in the gas. run it and then run the gas out of the carburator. now, make sure the gas in the tank is good and has no water or trash. check the fuel line that it is in good conditon and not plugged. pull the carberator and clean varnish out and clean jets. soak it over nite in varsol or parts cleaner. check to see if you have a low oil shut off. oil level must be correct. check your exhaust to make sure it isn't plugged. some have a little screen that get coated with carbon and won't let it exhaust.( fuel in, spark, exhaust out)
Posted on Sep 02, 2010
  • 7 Answers
SOURCE: the motor will not start...
You need fuel, spark and air...Fuel supply turned on? Air cleaner not blocked (mouse nests!)? I've seen corroded spark plug wire caps that don't conduct electricity. Pull the plug wire off, and check if it's shiny on the inside or corroded....if not shiny, clean it with a piece of emery cloth or use some fine grit sandpaper to make it shiny again.
Posted on Jan 08, 2011
New spark plug, fresh gas, clean air filter. Wont start.
take the fuel line off at the carburetor. if fuel is coming out then you have a plugged carburetor. take it off and apart. clean it really good with carburetor cleaner and put in a new needle and seat. it should run as good as new.
Apr 30, 2016 | Garden
My d100 will not start
Check for good , strong spark. Take spark plug out and ground the outer core of the plug to the engine. Hold the plug with a pair of insulated pliers. Have someone crank the engine while you observe for a good strong blue spark. If the spark looks nice and bluish, then next would be to clean the carburetor. I suggest trying a "quick clean before taking the carburetor bowl off. Take spray carburetor cleaner and spray inside the carb throat with the air cleaner off. Also take about 1/2 can/bottle of fuel line injection cleaner and put it in the gas tank. Then try starting the mower. May sure the gas in the tank is fresh.
Jun 20, 2014 | John Deere Garden
Craftsman YT 4000 Won't Start
Did you check for "spark" at the plug? Check fuel filter ( maybe plugged up ". How fresh is the gas?
Nov 10, 2013 | Craftsman YT 4000 42" Briggs Stratton 24...
My weed eater lower start reasonably well, but shuts down after running less than a minute
SOUNDS LIKE YOUR MAGNETO IS BAD,, TO FIND IT JUST FOLLOW THE SPARK PLUG WIRE THERE IT IS,, HOPE THIS HELP
Oct 17, 2013 | Weedeater 25cc Gas Blower ()
Lawn mower will not start
check gas tank with light is there dirt in tank? did you change fuel filter? is there spark at the spark plug? try a 2 second spurt of starting fluid in carburetor and crank does it fire?if it does then you most likely need to clean carburetor with carburetor cleaning spray, flush fuel lines with spray and swap fuel filter.
Apr 23, 2010 | Briggs & Stratton Briggs Stratton Intek V...
Cannot get my bike to start
Remove rubber connection from carby inlet (between carby and air filter) enough to get a piece of thin card to cover inlet to carby. Turn motor over with throttle half open for a few seconds. Remove card and see if any fuel is on the card. If there is, repeat process (fresh card) without throttle, fuel should still appear. If there is no fuel present, you have a fuel blockage. If engine still not starting with fuel present, you have an electrical problem, check for spark by resting attached plug to engine metal and turning engine over.
Apr 19, 2010 | 2001 Suzuki DR-Z 400 SE
Kawasaki KRB750 B: Won't start. Have spark,
Check your off/on switch you can test it with an ohm meter to see if you are getting a open curcuit
Mar 12, 2010 | kawasaki Krb750b Backpack Leaf Blower
My string trimmer will not start
Possible solutions:
-Kill switch is shorted out-check the wire and connections.
-Buy a new plug.
-Primer bulb needs to be replaced.
-Fuel filter needs to be replaced, and it's located inside the gas tank so it's a bit tricky to replace.
-Try starting it without the air filter attached.
Is it possible an incorrect mix of gas/oil was used (or straight gas) which in turn ruined the motor?
Jul 29, 2009 | Garden
Lawnmower wont start
Possible Causes Corrective actions
Unit will not start Control handle is not engaged Engage control handle spacer.gif spacer.gif
Spark plug wire is disconnected Connect spark plug wire spacer.gif spacer.gif
Fuel tank empty or stale fuel Replace with clean, fresh gas spacer.gif spacer.gif
Air filter filled with dirt or debris Replace or clean air filter
May 23, 2009 | Mtd 22" Yard Machine Push Mower
Electrical Supplies Logo
Top Electrical Supplies Experts
ken skalski
Gene Haynes
Are you an Electrical Supply Expert? Answer questions, earn points and help others
