Question about Tools & Hardware - Others
Where can I get a schematic for swingline heavy duty stapler model 415?
  • 40 Answers
SOURCE: instructions on unjamming swingline electric
First, are you using the recommended staples for this stapler? Many heavy duty electric staplers don't use "standard" desk staples. Second, try unplugging the stapler, unloading the staples, and if possible, reach a couple of fingers into the stapler and try manually pushing up on the staple head to see if you can get the driver blade to come down. Does it come down smoothly, or does it seem like there is something stuck in there? If you aren't sure about disassembling the unit (my usual method-but I'd recommend having the parts diagram handy), try using a flashlight to look at the underside of the staple head, where the staples come out - can you see anything stuck in there? If so, you might be able to use a small knife blade or small dental pick to get jammed staple pieces out.
Posted on Mar 14, 2009
  • 40 Answers
SOURCE: Swingline Stapler Staples Only After You Open It Up....
When you lift up the top of the stapler (as though you are going to put staples in), does the pusher slide freely back and forth? It might be getting stuck at some point and not pushing the staples (either due to a worn pusher spring, or friction). First (after removing the staples) try spraying some light oil on the mechanism and lifting the top part of the stapler up and down a few times and observe how easily it moves back and forth. Also, with the top open try GENTLY sliding back and forth a little - if it slides fine with no sticking, try loading staples and using stapler. If it slides ok, but doesn't quickly return to it's "normal position" when pulled so as to put tension on the spring, rhen the spring may be worn and need replacing.
  • 23 Answers
SOURCE: Need staples for my Swingline Heavy Duty Tacker #800
If you can find Arrow brand staples - 60x30 series staples are interchangable with the old Swingline 8xx staples, sizes as follows:
Arrow 60430 = 1/4"
Arrow 60530 = 5/16"
Arrow 60630 = 3/8"
Arrow 60830 = 1/2"
Arrow 60930 = 9/16"
Posted on Mar 22, 2009
Hugh fulton
  • 62 Answers
SOURCE: Where can I get staples swingline stapler
Asssuming that you are in Australia , you could go to Bunnings and ask them or they might point you in the right direction.
Good Luck
Posted on Sep 13, 2009
  • 332 Answers
SOURCE: I have a Swingline Optima Heavy duty manual
You may nave too many staples remove half of them and see it that helps
Posted on Mar 11, 2010
Where do I get staples for a B&D stapler? #9700
There are several brands of staples that will fit your stapler and the price will vary according to the depth of staple you are looking to buy. Arrow brand staples are the most common. All the ones I saw that fit the 9700 are Wide Crown Swingline Heavy Duty
Arrow 606 Wide Crown Swingline Heavy Duty 3 8 Inch Staples 1 000 Pack
Jan 06, 2015 | Staples Tools & Hardware - Others
900XDN-C SWINGLINE HIGH CAPACITY HEAVY DUTY STAPLER OPERATIONS MANUAL
auto parts store sells a pick with straight on one end and 90 degree on other end.
This should be slender enough to pull staples out.
Mar 27, 2013 | Tools & Hardware - Others
Swingline optima 40 how do you open and close the stapler?
Swingline heavy duty staplers provide the power to staple up to 120 pages of 20-lb. paper easily and consistently. The all-metal construction of these staplers makes them an indispensible office tool. However, the way to load staples into a Swingline heavy duty stapler differs from the method for loading most other manual staplers and can cause a little confusion.
Difficulty:Easy Instructions
    • 1 Remove the follow block at the back of the stapler by pushing the mechanism in, lifting the block up over the holding hooks and sliding it out from the stapler. The follow block is the spring-loaded mechanism that holds the staples in place within the stapler.
    • 2 Load the heavy-duty staples into the staple tray.
    • 3 Replace the follow block by inserting it back into the stapler and locking it into place over the holding hooks.
Read more: How to Load a Swingline Heavy Duty Stapler ' eHow.com http://www.ehow.com/how_5822366_load-swingline-heavy-duty-stapler.html#ixzz1bVwG5bBn
Oct 21, 2011 | Swingline ® High-Capacity Heavy-Duty...
Trying to load the staples into a model #90010. They're fine except at the very front of the stapler, they wont go all the way down flush with the others and the chamber won't even close.
1. Make sure you have the correct staples for the machine, Swingline Hvy-Duty Staples for 90010 Stapler, 0.625-Inch Leg Length, 2500 per Box (90009)
2. Check the staples to make sure there are no visible jams. Remove some staples from the row if this helps them fit.
3. If you continue to have problems, contact the manufacturer at http://www.acco.com/swingline/, or
Repair Service/Technical Support:
Phone: 800.790.7787
They will replace the stapler if needed.
Apr 14, 2011 | Swingline ® LightTouch Heavy-Duty Stapler,...
Optima Model # 8787x. Appears to be jammed. How do I open up the stapler to remove cause of jam. I think if I could open it up I could fix it. If all fails can this be sent away to be fixed and...
You need to open the stapler from the back. Push the black piece at the back of the stapler in, then pull it up and out. Remove the jammed staples, and reinstall. Make sure you use the correct staple . It appears to be: SWINGLINE 35550 HIGH CAPACITY STAPLES, 3/8"
Apr 13, 2011 | Swingline Heavy Duty Stapler 30 160 Sheet...
How to load staples?
  1. Remove the follow block at the back of the stapler by pushing the mechanism in, lifting the block up over the holding hooks and sliding it out from the stapler. The follow block is the spring-loaded mechanism that holds the staples in place within the stapler.
  2. Load the heavy duty staples into tray.
  3. Replace the follow block by inserting it back into the stapler and locking it into place over the holding hooks.
Resource 1 : eHow Article
Feb 21, 2011 | Swingline Heavy Duty Stapler 30 160 Sheet...
Instructions on how to load a swingline heavy duty stapler.
You pull up and back on the stapler head. Then pull out the spring that keeps the staples loaded. Be careful as the spring is very strong. Then put in the staples and put the spring back in behind the staples.
Aug 13, 2010 | Swingline Heavy Duty Stapler 30 160 Sheet...
Hello. I have a model #1000 Swingline Power Gun. It says,the extra heavy duty staple gun on the handle. I would like to purchase a box of 1/4" and 3/8" staples. The gun is so old I don't know the new...
Went to the local hardware and read the labels. The store brand fit and works as good as the original staples. The 1000 has outlasted several of the new fashion staplers. And the local hardware store is an Ace Hardware.
Jan 20, 2010 | Staples Swingline® 36115 Staple Guns Tools...
Need help to reassemble Swingline Optima desk stapler
You must have purchased the Swingline Stapler that is actually a Paper Weight. Do you have the 747 model, the one the airplane of named after?
Sometime the imbeded PC fails, preventing the robotic controls to release the staple or to reassemble automatically.
Please return for a complete replacement and a free trip to Disey Lane just pay for transportation, tickets, lodging, food, shipping, packaging, and handling. Have a nice day and thanks for flying with us.
Sep 15, 2009 | Stanley Bostitch 00540: 00540 AntiJam ?...
Tools & Hardware - Others Logo
66 people viewed this question
Top Tools & Hardware - Others Experts
J.D. Browning
J.D. Browning
Are you a Tool and Hardware - Other Expert? Answer questions, earn points and help others
