My monitor 422 ignites, warms up, but circulation fan never starts, and ultimately the burner shuts down, burner status lights flash. Suggestions?
Combustion chamber gets nice and hot, but it's shutting down without circulation fan ever coming on.
  • 148 Answers
Blower fan relay for older unit or board for newer unit
Posted on Nov 23, 2014
heatman101
  • 43501 Answers
SOURCE: Main blower fan is not starting on my York Diamond
Check to see if the blower motor is actually getting power to it...You will have to check for power on the heating speed terminal... and the neutral wires....you should have 120v across those two wires....
If you have power then the motor is bad...if no power then the heating relay went bad on the circuit board and you will have to replace the circuit board...
That is a common problem as those relays are often to light and wear out...
Just realize that without an electrical meter to trace things through you are really just grabbing at possibilities and not really able to correctly diagnose your problem...
heatman101
Posted on Dec 08, 2010
SOURCE: BURNER STATUS LIGHTS START FLASHING, SHUTS DOWN!
Not sure exactly what is meant by half way it shuts off. My furnance wouldn't heat to 68 degrees from a setting of 63 degrees on the setback thermostat without shutting down several times with a single flashing led. It would reset after an hour or so until it finally reached the 68 degrees. The problem turned out to be the tube that drains the water from the blower assembly. It had a belly in the middle which would cause the water to sit and block the airflow sensor for the gas value. Lifted tube to allow proper drainage to correct.
Posted on Dec 24, 2008
SOURCE: mpi monitor 422 heat problem
I had the same problem last night and this morning. Its in the manual. I had to take the fan off of the back and vaccuum out all of the dust/lint that built up and it was a lot. It is a safety feature. It's a overheating protection feature that usually triggers if there is build up in the fan, front vent or vent pipe to the outside. I hope this helps.
Posted on Jan 06, 2009
tborn6
  • 700 Answers
SOURCE: Goodman pgb 0300751 gas package
then you need toi have them check the fan high limit that is mounted in the blower compartment. if it's closed then the blower fan and the conmbustion air fan will run together.
Posted on Feb 04, 2009
shastalaker7
  • 1515 Answers
SOURCE: Monitor 41 heater not getting fuel
The problem would be in the inducer or combustion motor not starting up and running. This is a safety or one of several in you're system. When the fan comes on, the draft sends air to a switch telling you're unit that fan is on and ready to fire up.If the fan fails, no heat.Check for voltage to the fan motor. Even though it is free doesn't mean that it will work anymore.If there is no power to the motor, on a call for heat, you need to look at the schematic and find out where this motor gets its power. If there is power, remove it and try and find a dealer online or near by to where you can get one.It has to be working. I am surprised the burners come on at all.
Good Luck Wayne, and please let me know what you find out. Sincerely, Shastalaker7
Posted on Nov 05, 2009
Testimonial: "Thanks a bunch. I'm trying to find a schematic!"
Any suggestions on most likely problem?
it should tell you that flashing code of it problems
Nov 17, 2014 | Heating & Cooling
Ihave a 441 monitor kerosene heater,burner status light are flashing and the heater shuts down.the heater has had a turnup, tank filter has been replaced, flow has been checked,igniter or flame dtecti
look and see if the part that stubs out the wick upon turning it off is stuck up or not dis engaging properly. if stuck up the over heating would shut it down!.
Jan 04, 2013 | Heating & Cooling
RED FLASHING STATUS LIGHT
Possible lamp failure but lamp light not status should blink-I have suggestions but want you to try the self check first--if set has been unplugged plug it up and turn on and when it fails:
Mitsubishi TVtroubleshooting
Here's something that might also be useful. After you turn on the set, and getthe regular red blinky lights, hold down the Device and Menu buttons togetherfor about 5 seconds.
The Power light will start to flash in a two digit sequence.
For example, 3 flashes, then 7 flashes = 37.
Here are the error codes, and the corresponding problem:
12 = No error detected, check power supply.
32 = Lamp Cover is open.
33 = Air filtercover is open.
34 = Lamp abnormality
36 = Light Engine (DMD or Lamp Fan stopped)
37 = Exhaust or Lamp Ballast Fan stopped
38 = Lamp Temperature High
39 = DMD Temperature High
41 = Short is detected
44 = DVI cablebetween FMT and Engine disconnected
Jun 11, 2012 | Mitsubishi WD-62525 62" Rear Projection...
Dell dimension 370 randomly shuts down orange light flashes on pwr button
I suspect your graphics card or processor is overheating and shutting itself off to prevent damage.
Cool the unit down with additional fans, introducing cool air and exhausting warm air is key to a reliable, stable computer system.
The reason for this sudden problem is most likely because a higher resolution on the new monitor is supported, therefore making the computer work much harder than before.
Take care!
damnor01
Jun 09, 2012 | Dell Dimension Computers & Internet
Air pro gas furnace model #g8c07512mub11a The combustion fan comes on the igniter glows red the gas fires in the burners for 5 seconds the it shuts down. Any suggestions would be helpful.
I would suggest you change the flame sensor. It will be a small diameter probe extending into burner compartment,usually over or inbetween burners. If your furnace is lighting the burners but they won't stay lit That Is what I would do first.. I also would turn thermostat to fan on to make sure you don't have a problem with the fan. Hope this helps you. Thanks
Nov 17, 2010 | Heating & Cooling
Turn up t-stat, circ fan runs, hot surface igniter glows burner lights blows warm for a short time and then goes cold, flashes 1 flash, ignition problem, no flame when acting up. model# DGAA070BDTB.
The thermocouple lets the control know the flame is burning, and if it doesn't sense flame it shuts off just what you describe. Sounds as though you need to replace the thermocouple.
Nov 11, 2010 | Heating & Cooling
Mpi monitor 422 heat problem
Dec 26, 2008 | Rinnai Toyostove Direct Vent Heater: Laser...
Nov 23, 2008 | Heating & Cooling
Heating & Cooling Logo
491 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
