Question about Ovens
Need a user's manual for a free-standing Russo wood-burning stove.
Stove is in excellent shape, but we cannot find an owner's manual or user's manual, and nothing shows up online. My address is chasyoung21@gmail.com
watugot
  • 290 Answers
SOURCE: Kenmore Oven and stove not igniting
If both top and oven are not igniting, then most likely you need an ignitor board. I should be located behind the left side of the console as you are looking from the front of the stove. I will look it up to be sure. There should be a tech sheet on the back panel of the stove to help in checking the boards.
Thanks/Mike
Posted on Dec 03, 2007
SOURCE: beaumark stove
The bottom element quit working and whats up with that!!!It is not burnt out we checked for that
Posted on Nov 13, 2008
SOURCE: fisher and paykel B1600E multifunction stove manual
I have a PDF copy of the Fisher & Paykel B1600E user manual
Posted on Jul 08, 2009
VtToolMan
  • 704 Answers
SOURCE: I need to change my oven ignitor and I need a diagram
Here's a diagram of the oven along with the Oven Ignitor (Part #19 on the diagram) and the Broiler Ignitor, (Part #26 on the diagram). They are located behind the gas deflectors located at the top and bottom inside the oven compartment, accessible from inside the oven, but you'll need to remove the rear panel at the outside back of the stove to disconnect the terminals tha supply voltage to the ignitors.
Be sure to turn the breaker off and/or unplug the range from the 220V-AC outlet first.
http://www.searspartsdirect.com/partsdirect/getSubComp.pd?modelNumber=FGF353BADB&productCategoryId=0124002&brandId=1428&modelName=FRIGIDAIRE-GAS-RANGE---5995274411&diagramPageId=00003&componentDescription=BURNER&documentId=Y2702738&backToLink=Return%20to%20Sub%20Components%20list
Hope this helps you complete your repair. Best Regards!
Posted on Jul 31, 2009
  • 87 Answers
SOURCE: How can I re-enamel an old wood burning stove?
For my outdoor burner i use Krylon high temp flat black which works great for me, Sherwin-Williams has a large variety of high temp paint for your application.
Posted on Oct 10, 2009
Testimonial: "Thanks"
Traditions the earth stove. how to operate
Try these people who seem to be main dealers.
http://woodheatstoves.com/stove-manuals-earth-stove-user-manuals-c-291_217.html
Nov 03, 2015 | Us Stove Company USSC Eco-Aire Window...
Need knobs for Lady Kenmore free standing stove. do not have model # stove was installed when home was built in 1990
parts need to have the model number sometimes the part with have the number etched on to it
Feb 01, 2015 | Kenmore Ovens
I was inquiring about how to obtain an owners manual for the Harmony l oil stove
Google this and you will find pdf
Harmony l oil stove
Oct 02, 2014 | Ovens
Old timer wood stove manual
I need to find a owner manual for an old timers wood burning stove insert or at least how to replace the fire bricks
Jan 07, 2014 | Ovens
The stove is 26 years old. Has been working very well. Now the two heating elements on the left side of the stove and oven are not working. The pilot lights come on. Fuses in good shape and 220 volts...
check the contact points on the rear of the element they burn off after years of use, if the contacts are still good, Look at the element itself for any white marks on the element, if you see any , the element itself has probably burned out and need replacing , to get to the contacts,, depending on the oven, remove the back they should be right in sight , if you do need to replace the fittings on the wire ends, be sure and get heat range connectors
May 29, 2011 | Ovens
Changing stove from gas to lp do we need to open top of stove to do this?
Only if it is an open burner stove. Sealed burner stoves are converted without removing the top. Which do you have? Your owner's manual shows how to convert it. If you're missing the manual, tell us your stove make & exact model # and we'll see if it's available online to download. Douglas
Sep 12, 2010 | Ovens
I moved into a new flat and the AKP 239/01 IX stove was already built in and there is only user manuals in every other language except English!! The owner does not have it and no-one knows where it is! I...
google -- user manual for ( make and model of stove ) and download the pdf version
failing that go to places like Jaycar and buy an infrared thermometer
you aim this unit at where you want to read the temperature and it reads it
so aim it at the oven glass and you have the temp
or aim it at a hot plate and you have the temp
Sep 08, 2017 | Whirlpool Ovens
Oct 10, 2009 | Ovens
Pf code on frigidaire professional series free standing range
"PF" indicates the electronic control detected a Power Failure.
This could have been caused a brief power outage OR may be an indication that the connections to the oven, either at the stove or at the plug are loose.
Jun 09, 2008 | Ovens
Ovens Logo
132 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
