Question about Yamaha RX-V595 Receiver
Yamaha RX-V595 Receiver will play Dolby Digital 3/2.1 audio Blu-Ray disc with player set to bitstream but will not play DTS-HD 3/2.1 unless output is set to PCM. Is this an issue with the Yamaha Recei
Connected to a Panasonic Blu-Ray Disk DMP-BDT360 via optical cable. The Yamaha displays "Digital DSP" when playing Dolby Digital with bitstream out and displays "DSP Pro Logic" when playing DTS with PCM output from player. (No sound when DTS set to bitstream.)
    Scholar:
  • 127 Answers
The optical connection (SPDIF) doesn't have enough bandwidth to transfer DTS-HD audio. To use DTS-HD, you must connect the blue-ray player and receiver via HDMI cable.
Each DTS-HD audio track on blue-ray includes also "normal" DTS audio, which is probably used when you select PCM. Player decodes it and sends decoded (non-HD) audio via optical cable to receiver.
Posted on Nov 26, 2014
avenger77
SOURCE: Playstation 3 audio connection into Yamaha HTR-6040 AV Receiver
Solved problem with Yamaha HTR-6040 AV Receiver. My daughter had inadvertently changed the program to "Direct Stereo" mode which allows sources to bypass the decoders and DSP processors so you can listen to 2-Channel PCM and Analog sources. Nothing to decode digital audio in this setting!
Posted on Aug 10, 2008
localwonder
  • 6784 Answers
SOURCE: decoder problems
OK, use the down mix function on your blue ray player. this will decode for your receiver. the down mix feature should be located in the audio options on the blue ray menu screen.
Posted on Mar 16, 2009
dunnbiker
  • 8546 Answers
SOURCE: Unable to play DTS-HD & True-HD
What do you hear? Do all other modes work ok?
If Audio Select (Page 44 and 98) is set to HDMI you will hear silence if no HDMI signal is present. I think AUTO is the best choice here.
On Page 98 of the manual it says a bunch of things concerning automatic signal detection and input selection.
Initial configuration D) INIT. CONFIG
Use this feature to select the settings of the audio input jack select, active decoders and extended surround when you tum on this unit.
Audio select AUDIO SELECT
Use this feature to designate the default audio input jack select setting (see page 44) for the input sources connected to the DIGITAL INPUT jacks when you tum on the power of this unit.
HDMI set E)HDMI SET
Use this feature to select the component to play back HDMI audio signals.
Support audio S. Audio
Use this feature to select whether to play back HDMI audio signals on this unit or on another HDMI component connected to the HDMI OUT jack on the rear panel of this unit.
CHOICE = RX-V663
FUNCTION
Plays back HDMI audio signals on this unit. The HDMI audio signals input at the HDMI input jacks of this unit are not output to the HDMI component connected to the HDMI OUT jack on the rear panel of this unit.
CHOICE = OTHER
HDMI component connected to the HDMI OUT jack.
NOTES
This unit transmits audio and video signals input at the HDMI input jacks to the HDMI out jack only when this unit is turned on even if "S.AUDIO" is set to "OTHER".
I'd look in these areas for specific guidance.
Posted on Apr 27, 2009
gymhasafit
  • 31 Answers
SOURCE: 8' Optical Cable from TV to Receiver and Signal is Breaking Up
Before you buy anything try checking the AUDIO Settings in the Menu of Each Device (Mostly TV) and see if they are set to PCM or BITSTREAM. HDMI is mostly set to PCM while Optical is generally Bitstream. The TV may be set to the opposite of what it needs to be. I would try to get PCM to work first cause it is Better, If not then set what you can to Bitstream and it should pass. Also check in TV Menu for SOUND OUT or AUDIO OUT or SPEAKERS. Some TV's have a problem passing Audio through when they are already Outputting them to it's own Speakers! I Hope this Helps out!
Posted on May 05, 2009
dunnbiker
  • 8546 Answers
SOURCE: Hi. I have a Yamaha DSP
Audio output and bitstream selections are dependent on the unidentified BluRay player and the invidual disc.
Posted on Jul 18, 2011
RX-V465 Yamaha Reciver we can get picture but no sound w/PS3
Check HDMI Sound settings:
Enter Setup menu via remote, then Func. Setup / HDMI / Audio. You can choose from Amp (sound will be played via Yamaha), TV (sound will go straight via HDMI out to your TV and not play on Yamaha) and Amp+TV (Yamaha will play the sound and also pass it to the TV).
Also what is your source? DVD or some network player? For example Yamaha cannot decode audio in AAC or other computer formats, so be sure to change the audio settings of your player to output PCM and not raw/bitstream.
Mar 26, 2010 | Yamaha Rx-v465/rxv465 Home Theater...
Surround sound for Blu Ray on older Sony receiver
Hello, it sounds to me like the receiver doesn't support the sound format being sent from the blu-ray player. This is because the blu-ray disc would have HD encoded sound such as DTS HD Master Audio or Dolby True HD. Most receivers have not been fitted with these sound formats untill quite recently. The reason for the menu sound playing correctly would be for the PCM (Pulse-code Modulation) which sends simple two channel digital sound supported by all digital receivers. It may be possible to use Dolby Pro Logic or similar formats to give a surround feel, but the only way to get true surround sound in this way would be decode the sound externally and input it through several phono cables into the multichannel input, however blu-ray sound comes in 7.1 so the receiver would need to be able to accept this to get the full effect. If it is possible, see if the blu-ray player will allow downsampling to a surround sound format that your receiver can accept such as Dolby Digital or DTS. Hope this helps.
Aug 21, 2009 | Audio Players & Recorders
Different Audio options from an older receiver
If your receiver has a multichannel input and the player has the multchannel output then that is the only way you can get surround sound from it with source inputs that it cannot decode, such as DTS. The player will then do it alone.
However, in the setup menu of the blu ray player you should be able to change the audio output to downmix to 2ch audio...at least you'll get to watch the movie.
Jun 14, 2009 | Kenwood VR-405 Receiver
DTS Master HD audio problem
Hey! Make shure your amp and blu-ray player output and input signals are set to "bitsteam" and you are useing HDMI and optical connections. I hooked up my Onkyo tx sr 506 integrated amp to a Samsung BD 1400 player and everthing worked perfectly right out of the box. Perhaps your amp can"t decode DTS HD Master or your blue ray doesn't support it although i think a firmware upgrade may accomplish this. Put on The Chronicles of Narnia Prince Caspian which will DEFAULT to DTS HD MASTER 7.1 and see if it works. It's an excellent source to test your system. Picture and audio recieved 5 stars from Home Theatre magaziene and like i said, either your amp, or player doesn't support it or your interconnects are keeping it from coming thru. HDMI and OPTICAL connects and check your set up for "bitstream" Remember what Todd Rundgren allways said,"Everything will work if you just let it!"
Feb 05, 2009 | Yamaha RX-V663 Receiver
No DTS-HDMA or Dolby TrueHD shown on display
DTS-HDMA and Dolby TrueHD cannot be passed to your receiver via bitstream on the PS3. DTS-HDMA cannot be decoded either so you're out of luck there.
Dolby TrueHD can be decoded internally on the PS3 assuming your firmware is up to date. Set the Blu-ray HDMI output to PCM and you can then pass it to your receiver.
If this doesnt work, do a system update on your PS3.
Jan 24, 2009 | Onkyo TX-SR606 Receiver
No output of hd audio
Change audio settings on PS3 to PCM not bitstream
Jul 26, 2008 | Denon AVR 3808Ci Receiver
No Audio when I play Blu-Ray discs with Dolby TrueHD
For dolby digital to work you have to have the optical or coax cable hooked up to the reciever ,The HDMI cable is for digital video and audio output but does not support dolby digital out the cable into your reciever , so just turn off the dolby digital on your reciever and you should hear the sound.
here is more info
Dolby TrueHD is an advanced lossless multi-channel audio codec developed by Dolby Laboratories which is intended primarily for high-definition home-entertainment equipment such as Blu-ray Disc. It is the successor to the AC-3 Dolby Digital surround sound codec which was used as the audio standard for DVD discs. In this application, Dolby TrueHD competes with DTS-HD Master Audio, another lossless codec from Digital Theater System.
Dolby TrueHD uses Meridian Lossless Packing (MLP) as its mathematical basis for compressing audio samples. MLP was used on the earlier DVD-Audio format, but details of TrueHD and DVD-Audio differ substantially. A Dolby TrueHD bitstream can carry up to 14 discrete sound channels. Sample depths up to 24 bits/sample and audio sample rates up to 192 kHz are supported. Like the more common legacy codec Dolby Digital, TrueHD bitstreams carry program metadata. Metadata is separate from the coding format and compressed audio samples, but stores relevant information about the audio waveform. For example, dialog normalization and Dynamic range compression are controlled by metadata embedded in the TrueHD bitstream.
May 19, 2008 | Marantz SR-7200 Receiver
Onkyo sr 605
Check with and download the firmware update from the Onkyo web site.
Mar 16, 2008 | Onkyo TX-SR605 Receiver
Only decoding in pro-logic
go in blue ray dvd menu as dvd is playing and select the audio out formatt u wann use has to be on 6.1 or least 5.1 digital not 2.o ch ok and u may be seding the digital with the hdmi outs not both be hard for it to do doe syour tv had digital opti out run that to reivciver on digital input ok tell blue ray options menu also digital oput bitrate ok
Jan 18, 2008 | Sony STR-DE835 Receiver
Yamaha RX-V595 Receiver Logo
194 people viewed this question
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Electro Med Services...
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
