Question about Whirlpool RMC305PV 30" Built-in Microwave Combination Double Wall Oven with 4.1 cu. ft. Oven Capacity, 1.4 cu. ft. Microwave Oven Capacity, Delay Bake, Preheat Countdown Timer and AccuBake Temperature Management System
Element heats up when we only put oven light on
  • Whirlpool Master
  • 5,323 Answers
Stove will not turn off CHECK
Temperature Control Thermostat
If the oven won't turn off the oven thermostat is often the cause of the problem. The electrical contacts inside the oven thermostat can weld themselves together and then the oven won't turn off. If this happens, turn off power to the entire appliance at the household circuit breaker or fuse. The oven thermostat usually cannot be tested and must be replaced if defective.
Oven Control Board
The oven control board has a set of relays that turn on and off power to the bake and broil circuits according to the customer settings and sensor input. If the oven won't turn off it could be that one of the relays on the oven control board is shorted closed, providing voltage to the heating circuit. It can be dangerous if the oven won't turn off. Don't leave the oven unattended without turning off power to the oven.
Relay board:
Some ovens are equipped with a relay board. This circuit board has several relays which control the switching of electrical current to the oven heat source. If the oven won't turn off it may be that one or more of the relays on the relay board have failed. If this happens replace the relay board. The relays on the board are not sold separately. ALSO CHECK THE BAKE AND BROIL ELEMENT.
Posted on Apr 09, 2015
Fixed fan element, but can't remember how to put it back together again
This tutorial will show you how to check your Smeg element and how to replace your Smeg cooker element.
Here are the 3 main faults to look for in your oven or cooker that is not heating
  1. Your oven will not work until the clock/timer has been re-set after replacing an oven element or tripping the electrical supply. Consult your Smeg manual.
  2. If your Oven is not getting hot or heating up it could be a faulty element, if the fan in the oven is running and the thermostat light is on, this will lead us to believe that the element has gone faulty. With grills the thermostat light should come on there should be heat, if not then this could be the grill element or the thermostat.
  3. When you turn the oven on, the household electrical supply trips on the Rcd (this is the earth trip in the fuse board sometimes called the breaker tripping) your fan oven element has gone to earth and needs replacing.
If this helped you why not get me a beer? Paul is from the Naturally he would appreciate beer How to Repair Home...
Jun 22, 2012 | Smeg Ovens
Beko dvc 62 ,all electrics tripped out ,put cooker
The element has blown. It will cost you around
May 16, 2010 | Ovens
Oven not heating up
You need to replace the oven element, as it has probably blown.
It is located at the rear of the oven compartment behind a removeable cover.
Hope this helps.
Jan 18, 2010 | Ovens
Beko dvc62 main fan oven stopped working, doesn,t get hot but fan still works, it tripped circuit breaker and hasn,t worked since, peter
This tutorial will show you how to check your Beko element and how to replace your Beko cooker element.
    1.Your Beko oven will not work until the clock/timer has been re-set after replacing an oven element or tripping the electrical supply. Consult your Beko manual.
    2.If your Oven is not getting hot or heating up it could be a faulty element, if the fan in the oven is running and the thermostat light is on, this will lead us to believe that the element has gone faulty. With grills the thermostat light should come on there should be heat, if not then this could be the grill element or the thermostat.
    3.When you turn the oven on, the household electrical supply trips on the Rcd (this is the earth trip in the fuse board sometimes called the breaker tripping) your fan oven element has gone to earth and needs replacing.
Jan 14, 2010 | Ovens
Oven not working
fan oven element video. 1, If the fan motor . in the back of the oven is going round and the temperature light is on (normally little red light), but there is no heat then you will probably need a new oven element, these are generally very easy to fit and readily available from our website these can be tested with a electric meter.
To gain access to the element .you will have to remove the back plate from inside the oven. Once removed you will see the fan and element,. if you look closely at the element .you will probably see a small hole burnt in it where it has blown. Sometimes however there is no evidence of a fault but the element is open circuit ie: broken inside the element casing, either way it will need replacing. Some elements will are fixed from inside the oven and some are held in place by nuts from the rear of the machine.
2, If your fan oven is getting warm but takes a very long time to cook or is burning the food more on one side than the other, then you need to check if your oven fan motor is working you will see the blade turning fast if it is ok. if the element is heating but the fan motor is not blowing the heat into the oven then you need To replace the oven fan motor is a little more expensive and a bit more involved.
3. If you have the opposite problem ie: your oven is over heating and burning everything then you will need to replace your oven thermostat
4, A quite common and easily overlooked answer is if your oven is not working at all ie: no heat and no fan then the chances are that someone has put the oven timer into AUTO mode, simply put oven back to MANUAL mode and all should be working again.
For all Free appliance repair videos visit our VIDEO TUTORIALS
Jan 12, 2010 | GE Ovens
Need to put new bulbs and elements in fan oven
the bulbs are screw fit normally Neff fan oven element video. 1, If the fan motor . in the back of the oven is going round and the temperature light is on (normally little red light), but there is no heat then you will probably need a new oven element, these are generally very easy to fit and readily available from our website these can be tested with a electric meter.
To gain access to the NEFF element .you will have to remove the back plate from inside the oven. Once removed you will see the fan and element,. if you look closely at the element .you will probably see a small hole burnt in it where it has blown. Sometimes however there is no evidence of a fault but the element is open circuit ie: broken inside the element casing, either way it will need replacing. Some elements will are fixed from inside the oven and some are held in place by nuts from the rear of the machine.
2, If your NEFF fan oven is getting warm but takes a very long time to cook or is burning the food more on one side than the other, then you need to check if your oven fan motor is working you will see the blade turning fast if it is ok. if the element is heating but the fan motor is not blowing the heat into the oven then you need To replace the oven fan motor is a little more expensive and a bit more involved.
3. If you have the opposite problem ie: your oven is over heating and burning everything then you will need to replace your NEFF oven thermostat
4, A quite common and easily overlooked answer is if your NEFF oven is not working at all ie: no heat and no fan then the chances are that someone has put the oven timer into AUTO mode, simply put oven back to MANUAL mode and all should be working again.
Jan 12, 2010 | Ovens
After baking cake & 2 roasts, the oven will not heat
Jan 12, 2010 | KitchenAid Ovens
The bottom (fan oven) of my Neff U1721 made soft bang noise and failed. The fan stopped, the oven light went out and the thermostat light. I replaced the burnt out heating with a new element with a 32.5...
The power to the fan and thermostat is the fault. You will need to trace wiring from these elements to power source and I suspect that where the power cord meets the oven is where you'll find the cause.
Dec 15, 2009 | Neff U1721 Double circotherm Electric Oven
No heat on bottom oven. fan running but not heating up
Jul 19, 2009 | Neff U1421 Double circotherm Electric Oven
Duco4ss main oven not heating on fan setting
put test bulb on the two wires going to fan heating element,that will tell all,if bulb lights,its the fan element that needs to be replaced!good luck!!
Dec 17, 2007 | Ovens
Whirlpool RMC305PV 30" Built-in Microwave Combination Double Wall Oven with 4.1 cu. ft. Oven Capacity, 1.4 cu. ft. Microwave Oven Capacity, Delay Bake, Preheat Countdown Timer and AccuBake Temperature Management System Logo
97 people viewed this question
Top Whirlpool Ovens Experts
Dan Webster
Dan Webster
 Fix Your Board
Fix Your Board
ashburton
Are you a Whirlpool Oven Expert? Answer questions, earn points and help others
