Question about Craftsman Snow Blower 26 In. 208CC Dual-Stage
Remove a news paper from impeller for snowblower ,craftsman 26
    Sergeant:
  • 406 Answers
Is a dry newspaper if so get your garden hose and it and run the snow blower a little at a time stopping and using small crow bar with a curved nail puller on one end or anything that has something that can grap..pull the wet paper out small pieces at a time keep soaking and pulling..may take some time but it ell comr out...good luck
Posted on Nov 17, 2014
News paper in auger
Hi Robert:
This can be really annoying and requires patience to remove.
If it's not freezing outside, a garden hose with the jet setting or a kettle of hot water can be helpful to soften the paper. Then use a sturdy knife or screwdriver to pick the paper out a bit at a time.
Hope this helps
Mar 11, 2016 | Craftsman Sears Snow Thrower Manual Model...
Snowblower....auger takes time to get going...like five minutes...it will struggle to start spinning then eventually warms up and is fine....whats the issue?
It is most likely your auger drive belts. There are two of them, and they need to be replaced periodically. Your manual should describe in detail as to how to replace the belts. Always start by removing the spark plug wire.
Improper gearcase lubricant could also cause problems. Your manual should tell you specifically what to use in the gearcase, and how to fill it. Also look for grease fittings on the auger and use a low-temp grease to service those fittings.
Lastly; behind the auger is the impeller shaft. Reach in and see if it wiggles. If it does, then have your impeller bearing replaced.
Feb 13, 2015 | Craftsman Snow Blower / Snowblower Bottom...
Auger will not engage
check tension on the belts
check for broken belt
Feb 14, 2014 | Craftsman 26" 208cc* Dual-Stage Snowblower
Craftsman snowblower
does it have a fuel shut off valve on it , make sure the tank hose to carb is clear ,take the carb bowl off to see if the float and needle and seat are not sticking
Jan 22, 2014 | Craftsman Arnold Mtd Snow Thrower Blower...
Impeller does not rotate consistently and powerfully enough
check belt then check and adjust tension
it can be done on idler pulley or the cable going to handle for auger drive
Jan 01, 2014 | Craftsman 26" 208cc* Dual-Stage Snowblower
How to take a carburetor off an MTD Snow Thrower
Get user manuals for craftsman snowblowers to train yourself in clearing the pathways that are fully covered with snow.
Dec 15, 2013 | Mtd Yard-Man 26" 208cc Two Stage Gas...
Craftsman Snow Blower 26 In. 208CC Dual-Stage Logo
112 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Jim Parker
Jim Parker
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
