Question about Craftsman 26" 208cc* Dual-Stage Snowblower
How do i remove newspaper from craftsman snowblower 26" model # 247.889703 ?
Stuck in the impeller
    Sergeant:
  • 416 Answers
WARM UP THAW OUT
just pull the pcs out
Posted on Feb 02, 2015
Rock stuck behind impeller on swisher snowblower model 627851xo7a how do I remove auger and impeller
if rock is quartz or grannite use a torch to heat them up and dose it with cool water , shatters the rock into sand happend all the time in the quarry i worked at on heavy equipment , that torch idea worked everytime
Dec 09, 2014 | Swisher Garden
Remove a news paper from impeller for snowblower ,craftsman 26
Is a dry newspaper if so get your garden hose and it and run the snow blower a little at a time stopping and using small crow bar with a curved nail puller on one end or anything that has something that can grap..pull the wet paper out small pieces at a time keep soaking and pulling..may take some time but it ell comr out...good luck
Nov 17, 2014 | Craftsman Snow Blower 26 In. 208CC...
Craftsman snowblower
does it have a fuel shut off valve on it , make sure the tank hose to carb is clear ,take the carb bowl off to see if the float and needle and seat are not sticking
Jan 22, 2014 | Craftsman Arnold Mtd Snow Thrower Blower...
Impeller does not rotate consistently and powerfully enough
check belt then check and adjust tension
it can be done on idler pulley or the cable going to handle for auger drive
Jan 01, 2014 | Craftsman 26" 208cc* Dual-Stage Snowblower
I have a 3 yr old 26" snow blower. I ran the machine up against hard packed snow/ice and now the auger spins freely and all shear pins are still in place. The secondary impellor functions fine. I...
I am going to assume the belt is good if the impeller it running. You can check the belt by removing the plastic cover in the center of the snow blower.
With the unit safely turned off reach in and turn the blower by hand while putting a little resistance with your other hand on the impeller. Does the shaft from the impeller to the gear box turn?
Does the shaft that the augers are attached to turn? If the impeller shaft turns but the auger shaft doesn't, the gearbox in the front is bad and will have to be replaced.
I the auger shaft turns, check your shear pins again. Sometimes they will break but still stay stuck in the holes. Actually take one out and check it.
If it is a Craftsman you can get a manual from managemyhome.com and parts from searspartsdirect.com. You will need the model number of the snowblower. The number looks like 247.123456.
Any other questions please ask. Do't forget to rate this answer!
Jan 16, 2011 | Craftsman Garden
Craftsman Snowblower. One auger is disengaged...turns freely when touched....does not push snow
the augers on many craftsman snowblowers have a sheer bolt. If the auger encounters too much resistance, ie, a foreign object like a piece of wood or even a newspaper buried in the snow, this bolt will break off preventing damage to the gear box, which is a lot more expensive to repair than replacing the bolt.
This bolt requires not tools to install, just insert and secure with a cotter pin.
The parts dept at sears can sell you the replacement bolts with the correct sheer force rating. Have your snow blower model number handy when you call or go in.
Dec 27, 2010 | Craftsman Garden
Craftsman 26" 208cc* Dual-Stage Snowblower Logo
125 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Dean Gruber
Roland W VanLue
Roland W VanLue
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
