Question about Hardware & Accessories
<!-- from fixya rte -->Instructions for Astro Timer, Model 457864 - Hardware & Accessories
2 Suggested Answers
claudeinmo
  • 9098 Answers
SOURCE: Heavy duty astro model 457864 how do I set the event timer
[PDF]24-HOUR TIMER AND AQUASTAT CONTROL ...
armstrongfluidtechnology.com/.../11_871_astro2_timer_and_aquastat_i-...
Jun 3, 2015 - 9.0 Timer programming with manual override switch 3. 1.0 Timer ...eration of the circulating pump during high peak usage periods in order to ... pm timesetting. 2.0 aquastat ... 2 Astro 2 Series circulator and 24-Hour Timer wiring diagram.... In the event of power outage, the timer must be adjusted for.
Posted on Oct 29, 2015
Oct 28, 2015 | Astro Systems Armstrong Astro 20B050S-TA...
I have a Amrstrong Astro 25B050S recirculating pump on my 50 gallon State water heater (both installed in 2006). The timer works fine and the I can hear the Astro pump and the pump feels very hot to the...
If the pump is very hot, unplug it.
Heat damages motor coil and indicates that pump is not rotating at correct speed, or not rotating.
Take apart and clean inside pipe with white vinegar or CLR to see if pump rotor can be freed to rotate.
If pump does not rotate after cleaning, then replace pump.
http://waterheatertimer.org/Water-heater-recirculation-system.html
Aug 16, 2011 | Astro Systems Armstrong Astro 20B050S-TA...
I am programming my sto1 and I cannot get to dusk setting to program dusk on dawn off i have followed instructions and get only to dawn I have cleared and started over but to no avail purchased on...
ST01C instructions are confusing, and are longer than space allowed for free answer.
Open following link for re-written instructions that might be clearer, with illustrations how the display should look.
http://waterheatertimer.org/ST01C-program.html#astro
To clear the timer, hold down on-off button and press reset button.
Release reset button and keep holding down on-off until INIT displays.
If you go through re-written instructions and get confused, add a comment with exact step where it is confusing and I'll pull out the ST01C I use for testing and maybe I can find what is causing the problem.
Add a comment with your experience so others with same-similar problem can benefit.
Also take advantage of fixya expert assistance live.
For a price, expert works with you while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call.
Apr 03, 2011 | Solar Intermatic Self-adjusting 7 Day Wall...
I need to find instructions on how to reprogram an Intermatic indoor wall timer.
You posted under ST01C Intermatic battery operated timer.
If you have different timer, then add a comment.
Let's review ST01C timer for a moment.
Programming will stay inside timer memory indefinitely until timer no longer works.
Even if battery is removed, programs remain. Current time setting does not remain in memory.
If battery goes dead, then current time will disappear, but programs remain forever.
If previous programming was correct, you might only need to set current time,.
In that case, you do not want to 'reset' timer and clear memory.
If you want to clear old programming entirely, then you can 'reset' timer using following instructions.
Press and hold on-off button, and then use paper clip to push in reset button for 3 seconds.
Release reset button but keep holding on-off button until INIT displays momentarily.
Release on-off button.
If display does not show, then timer battery is bad, or timer is bad.
For instructions how to set current time, click link below.
In addition to current time, the link has ST01C manual and also has EZ to follow instructions and photos for setting on-off times (but not astro times)
Instructions are different for astro dawn to dusk.
Add a comment at any time if you need free help with specific steps in the manual.
If you do not want to read the manual or open a link and read the steps or add a comment for further free help, then you can pay a fixya expert for phone support and that person will walk you through the steps while on the phone.
Keep in mind that ST01C timer has 1 year limited warranty, and your timer might be broken.
In that case you should try the free steps first.
Dec 16, 2010 | Intermatic Inc. ST01C Digital In-Wall...
How to set utilitech wall timer for dusk/dawn settings
The Utilitec 0192773 timer has astro dusk-to-dawn functions.
The manual is very unclear at the exact point you need it to say how to set dusk-to-dawn.
The following page has the manual, with explanation how to find the astro dawn-to-dusk setting
http://waterheatertimer.org/Program-wire-Utilitec-0192773.html
When you are programming the timer, press TIME button and hours start flashing.
Press the +/- button ... the trick is to keep pushing the +/- button until it finally gets to astro, and the sun-moon symbol shows on display.
When the sun-moon symbol shows, the display also shows AM.
Press the +/- again and PM show.
So if you want Program1 to turn lights ON at dusk (PM), then your display needs to show: 1 ON PM sun-moon.
To continue setting astro, do not set hours, just press PROG button.
Then repeat the steps above until: 1 OFF AM sun-moon show on display.
Nov 08, 2010 | Intermatic Inc. ST01C Digital In-Wall...
Need a copy of manual
You can get the manual on the link below.
http://www.intermatic.com/~/media/files/intermatic/products/instructions/timers/et8215c%20-%20english.ashx
Good Luck please rate 4 thumbs up and please leave a testimonial
Oct 25, 2010 | Intermatic ET8215C- 7-Day Electronic...
How do I get the intermatic dt27 timer to work with out astro? I set it for an event, but it still uses the sunrise/sunset operation.
This manual is a bit confusing because it jumps across steps without telling you.
Look at manual instructions above Fig 11 where it says "Programming ON/OFF event times without astro." This is where your instructions are.
But let's start back at Fig 6. Setting DST
I think the instructions jump from DST at Fig 6 to programming at Fig 11
DST says:
If you want timer to compensate for DST, the display automatically defaults to AUTO.
If you do not want DST, press SET+ or ENTER/NEXT and display reads MANUAL
Then it says: Press MODE+ to go set up ASTRO feature
But you don't want ASTRO
I think this is where you by-pass ASTRO completely by pressing MODE+ until the screen looks like Fig 11 below:
Now you are at programming steps to right of Fig 11:
EVENT1 shows in screen
-Press Day to set days > you keep pressing Day to show M-F, Sat-Sun, or individual days
Then use SET+ and SET- to set ON time for EVENT1
Press ENTER/NEXT to go to EVENT2
EVENT2 is OFF time for EVENT1
Tip: Other intermatic timers ignore all Events that conflict ... so you might make on-off chart before programming
After EVENTs are programmed, press MODE+ to go to AUTO
Oct 03, 2010 | Hardware & Accessories
Hardware & Accessories Logo
838 people viewed this question
Top Hardware & Accessories Experts
Gene Haynes
Hippy_dd
Are you a Hardware and Accessory Expert? Answer questions, earn points and help others
