I've got a board want to know if its defective. Panasonic TZT/A1NFUU (TNPH0905UB) Main Tuner Board for TC-L32C3 the tv works for 30 seconds and shuts off ,and when I try it again same thing works
I've got a board want to know if its defective. Panasonic TZT/A1NFUU (TNPH0905UB) Main Tuner Board for TC-L32C3 the tv works for 30 seconds and shuts off ,and when I try it again same thing works for 30 seconds and shuts off. please advise
    Problem Solver:
  • 7 Answers
Take it to a tv repair shop the charge like 30 dollars in my area to see whats wrong with it
Posted on Nov 26, 2014
  • 13 Answers
SOURCE: ilo 26" TV stuck on one station and will not respond to buttons.
all you need to do is buy a control board its a 15 dollar part try shop jimmy .com
Posted on Apr 14, 2008
  • 718 Answers
SOURCE: how hard it is to replace by yourself main board Samsung LN-T4065
You need to do some more diagnosing of the problem. If you get sound and change channels take a bright flashlight and place it again the screen. Look for an image around the edge of the flashlight.
If you see an image that means the LCD controller board (TCON) is probably good.
The problem is probably one of three causes;
1) Inverter board is bad
2) CCFT (cold cathode fluorescent light) are bad.
3) Power to the inverter board is bad. You can also check the connectors.
Posted on Mar 30, 2009
SOURCE: 32'' Winbook Lcd Tv bad main board
eBay: Find WINBOOK LCD TV CONTROLLER BOARD 6870C-0060F in the Electronics
I located this board at anewparts on ebay, hope this helps you also
"Q"
'Til the Wheels Fall Off!!
Posted on Apr 20, 2009
techman007
  • 1112 Answers
SOURCE: my model tv is Samsung model LNS4692DX/XAA
Hello: The problem is on the power supply, there are two capacitors on the power supply near the plug that goes to the mainboard, these caps will look swollen at the top on them compared to the other capacitors in the circuit, if you know how to unsolder and resolder parts then this is a simple fix. The value of the capacitors on the board are 1000uf rated at 10 Volts, replace them with 1000uf rated at 16 Volts instead so this will not happen again. You can find them at any local electronics parts store, (Radio Shack) for instance..There will be two of them that look puffy at the top,they should all be flat so spotting them should be very easy...
Thks: Have a Happy Holiday...
Posted on Nov 22, 2009
  • 8457 Answers
SOURCE: plasma 50 inches dont turn on
The power supply board is dead.Tries the websites like Shopjimmy.com,Ebay.com to buy the refurbish power supply board for the replacement.
Posted on Jun 22, 2010
Need to know if Panasonic TC-L32C3 is a smart TV?
The Panasonic TC-L32C3 is not a smart TV. There is no network connection available (wired or wireless). It does have a slot for an SD card to make it a 32" photo viewer. You can also update the firmware by placing the unzipped file (see the site listed below) on the SD card. You can find the specifications and user guide on the product site: http://shop.panasonic.com/support-only/TC-L32C3.html . The direct link to the manual is ftp://ftp.panasonic.com/television/om/tc-l32c3_mul_om.pdf .
I hope this helps.
Dec 06, 2016 | Panasonic Televison & Video
Hdmi 1/2 working
You are in need of the a board inwhich you can more than likely install yourself. Make sure the power is not plugged in when you do it. The board that you need is Panasonic TZT/A10QXL (TNPH0856AC) A Board for TC-L32C22
There are lots of different places you can look to get one. Usually, the cheapest method is off ebay or retech
Regards,
Joe Van Buren
Aug 09, 2014 | Panasonic TCL32C22 32 in. TV
TC-P55ST50 problems with netflix loading
You might be dealing with a bad Main Board ( the board with all the inputs on it) you would need to replace it. You can find the part here
Jul 18, 2012 | Panasonic Televison & Video
I have a panasonic TC-P42C1 blinks 10 times no picture no sound What is common to go on this model (which board)?
Check the tv power supply board.That the board where the tv power A/c plug into it.Check the tv power supply board carefully for dying components parts that are called capacitors parts.Bad or dying capacitors parts on the tv power supply board are alway causes this problems to the tv.Bad or dying capacitors parts are very easily to spots,all these capacitors parts are alway bulges up onto it tops.Never have plats round tops as they suppose too.U have all the tools and know basic electronic also can do basic soldering work,u should changes all these dying capacitors parts in the tv power supply board with no problems at all.If u check all over the tv power supply board and it have no dying and leaking capacitors parts to the tv power supply board all.Then the tv Y-Sustain main logic Tuner board it is the causes and the problems.The tv Y-Sustain main logic Tuner signal board that is the board that take in the tv imcomming tv broadcasting signal cable plug into it.Or tries websites like Shopjimmy.com,Ebay.com to buy a whole new refurbish tv power supply board and or the tv Y-Sustain main logic Tuner signal board for the replacement.
Nov 06, 2011 | Panasonic TCP42C1 Plasma TV
Panasonic VIERA TC-L32C3 32-Inch 720p LCD HDTV by Panasonic
Hello, welcome to Fixya!
You didn't state any problem concerning this TV. What precisely is the problem with your Panasonic VIERA TC-L32C3 32-Inch 720p LCD HDT?
I look forward to your reply.
Regards.
Sep 27, 2011 | Panasonic Televison & Video
Just opened up a panasonic TC-L32C3 from its box, pluged it in and the remote (with brand new batteries) wont turn it on. I am able to turn it on manually and went through the initial on-screen set up...
Yes,the tv manual controls board infered signal light from the LED diode,to the tv have problems.Take the tv back where u bought it and exchangce it for another new tv.
May 21, 2011 | Televison & Video
Televison & Video Logo
43 people viewed this question
Top Televison & Video Experts
Electro Med Services...
