Question about Husqvarna Designer I
How do I download from a cd to a flash drive. I've tried every thing. I think I have it down loaded and the stick is empty.
  • Husqvarna Master
  • 10,263 Answers
The stick will show up as a drive letter. Switch to that drive letter and then highlite all the files on the CD drive Click copy. Change to the drive letter of the stick and then paste the files onto the stick.
Posted on Nov 17, 2014
I have a singer futura xl-400, don't have the cd to install the software on my computer, can it be downloaded off the Internet somewhere?
if it can, you will find it --go google and type in --software for singer futura xL-400 sewing machine
from you operators manual it will explain how to connect the machine to the computer for the down load or to download to a usb stick for installation to the machine
if you don't have the manual then go google and type in -operators manual ( for the machine)
Feb 22, 2016 | Singer Sewing Machines
I accidentally took my usb stick out while the machine was stitching and now it will not read the usb when I send the design by send1
Your drive is probably corrupt. Try to get a copy of the pattern on the PC hard drive. Then format the stick. To do this: PC: insert the stick, go to my computer, find the stick, right click it, and click format. Check "Quick format", unless you have a lot of time and are very patient. Then, put the pattern on the stick. Mac: open utilities, then find drive manager (I don't think that's what it's called, but something close to that.) then highlight the drive, and click format. Now that the stick is formatted, copy the pattern onto the stick, then retry sewing it. DO NOT UNPLUG THE STICK DURING THE FILE COPY, THE DRIVE FORMAT, OR THE SEWING! Hope I helped!
~Conner
Nov 27, 2015 | Sewing Machines
How to download embroidery from floppies to a stick
the floppy disc format will be different to what the external hard drive uses or a stick uses. check with your local it nerd shop and find out how it can be done.
Apr 01, 2015 | Sewing Machines
How can I send designs from my PC to my Toyota 830 embroidery machine when my Pantograms software/hardware is no longer working?
Some of the Pantograms software programs require a USB dongle connected to the computer. However, the driver for this dongle has to be installed before you install the software or connect the dongle. I suspect you may not have installed the driver or the dongle is missing.
Assuming that the dongle is connected:
Close your embroidery software program and all of the Pantograms software, including the Network C software, on your computer and remove the USB device. Put the software install CD into your machine's optical drive. (If your new machine doesn't have an optical drive, get a USB optical drive or copy the files from the CD to a 1GB+ USB flash drive at another computer with an optical drive.) If Windows XP starts the autorun routine for the CD, click Exit. Then double-left click on My Computer to launch File Explorer. Go to the CD drive (or USB drive if you used the work-around) and double-click on it. Open the Rainbow Drivers folder and then open the XP folder. Double click on the program: setup.exe . Choose Complete install as the program executes. Then close File Explorer when the install is done. Now insert the USB dongle and follow the on-screen message about New Hardware found to install the Rainbow driver from C: .
If you do not see the New Hardware found message, try putting the dongle into a different USB port. (Make sure to avoid USB hubs - they can add to USB device issues.) If the dongle doesn't work at any port, you may need to use a different method. There is a flash reader available for connecting a USB flash drive to the Toyota 830 here: http://www.plrelectronics.com/lab/usb_reader.php . (Scroll down to the Toyota machine section. This isn't cheap but it is cheaper than some of the newer embroidery software packages.)
I hope this helps.
Oct 26, 2014 | Sewing Machines
Error Message This embroidery card cannot be used with this machine
Is it a pre-loaded card - or one you add patterns to?
If its one you add patterns to, make sure the pattern isn't too large for the machine. EG if machine does 4"x4" and you've loaded a 5"x7" pattern, try down-sizing the pattern/ breaking it up into smaller sections to load & sew
Feb 16, 2012 | Brother SE-270D Computerized Sewing...
USB drive does not regularly read the USB flash
I have a Designer I USB that suddenly started not reading the usb stick that came with the machine. I was terrified that my machine was going bad, but I always start with the cheapest solution first. I bought a new usb stick, loaded the designs from the old one into my software then loaded everything on the new usb stick. My machine reads it every time so far. I replaced the usb stick about 3 months ago and have not had another problem since. I don't know if this is your problem, but usb sticks can go bad and since they are so cheap, I would try this first.
Jul 11, 2010 | Husqvarna Designer I
I have downloaded 5 x 7 designs which I have placed in my documents file and need to transfer them to my dongle for the designer 1 machine but have no idea how to do this - please advise if you can help me...
Okay. Firstly, a dongle is the security device for your software so you won't be downloading designs to it. Do you have a USB Designer 1 or a floppy disk Designer 1? I'm guessing USB. You need to load designs onto your USB stick - the Husqvarna one or another generic brand one - same process for both - through Disk Manager 3D program on your computer. This program is part of the 3D or 4D software suite, or you should have got it on a CD with your machine. It is a stand-alone program - you don't need all the other 3D or 4D software to run it.
Your "dongle" is likely a blue USB stick that came with the machine, yes? Do this:
Open Disk Manager program;
Insert USB stick into your computer;
In Disk Manager at the top menu bar you will see a little USB stick icon and a down arrow; click on this and the contents of your USB stick will be read to the Disk manager screen;
Now you load the designs you want to use into empty menus. Empty menus are the grey ones on the left-hand side. Click on one of those and four sub-menus become available. Open one of these (while you are still getting familiar with all this, write down the disk No. and menu No. you are about to use - makes it easier to find your designs at the machine);
You load designs by either clicking on the little blue camera icon (this will bring up thumbnails of your designs) or the file with green curved arrow icon (this will bring up your computer's files - like a Windows window). Navigate your way to where you have your designs saved, just like using Windows windows. If you are using the camera/thumbnail choice you can click many times on the designs and they will load as you go. If you are using the folder/file method you can only load one design at a time then have to re-open the icon.
Once you have populated your menu with the designs you want to embroider, click on the USB Write icon (blue USB stick and Up arrow).
You will be warned that all designs will be deleted. AS LONG AS YOU HAVE CLICKED ON READ USB STICK BEFORE DOING ANYTHING ELSE as per instructions above, all will be well. Your new designs will be written to the stick along with the existing designs that you read into Disk Manager.
Make sure the stick is NOT write protected. Can't remember which way the sliding clip should be for the blue HV stick so if it doesn't work one way, try the other. I think it is away from the computer - but not 100% sure.
If you have your own USB stick that you want to use, open Disk Man., insert your stick then under the Disk menu you will find Format USB embroidery stick. Click on this and it will do it for you. You can still use your stick for Word files, photos etc - just don't load it up with these files. It confuses the HV software if there are loads of non-embroidery files on the stick. Once formatted, your stick will work just like the HV one.
I trust you are okay on how to use the stick on the Designer 1 machine itself? Write back if you need help here too.
Nov 29, 2009 | Husqvarna Designer I
I just bought a Bernette Deco 340 and I am having a terrible time loading from the interbet design that will go on the USB stick and be accepted on my sewwing machine....I have call the sewing center,...
The first thing you need to do is put your blank USB in your Deco and turn the Deco on. When you do that, the Deco will create a EMB file on your USB stick. Then you need to download EXP design files and put them in that EMB folder.
Nov 20, 2009 | Bernina Sewing Machines
I HAVE A JANOME EMBROIDERY350E MACHINE
I think the problem may be with the folder structure on your flash drive!
You need to start by creating a new folder called EmbF5, and put your designs in that, in another folder which should be called MyDesign. You can have other folders within EmbF5 - all the folder names must have 8 letters or less, but the design names can be longer. The machine uses jef format designs.
There are several Yahoo Groups for users of the Janome embroidery machines, many of the folks on them are very knowledgeable and will help with problems.
I hope this helps
Feb 02, 2009 | Sewing Machines
Need help with transferring designs to machine
Put the cd into your computer drive and open it. Put your usb stick into one of the ports and open it as well. You must have the emb folder on the usb stick to put the designs into. If they are not there already- turn off your sewing machine and put the stick in. Turn on the machine and go to settings, then embroidery. Find the one that says Format. and touch that one and then let it do it's thing.
Once you have the folders on the usb stick- you can highlight the design name you want from the list (cd file) and drag it to the folder on the usb stick. Alternatively... right click on the design you want to move. Select copy. Open the folder on the usb stick and right click inside it. Select Paste. The design should appear in the folder for the usb and then you can take it out of your computer... put it into the machine and find the design.
If I can help with anything else... lmk.
Tracy in Nashville, TN
Jan 03, 2009 | Janome Sewing Machines
Sewing Machines Logo
43 people viewed this question
Top Husqvarna Sewing Machines Experts
Douglas Plant
Douglas Plant
Tally Girl
Tally Girl
Wayne Fellows
Wayne Fellows
Are you a Husqvarna Sewing Machine Expert? Answer questions, earn points and help others
