Tv showing alot of number codes how can I fix it
  • 139 Answers
Showing numbers on all inputs?
Posted on Nov 26, 2014
TV power button comes on to turn tv on & goes right back off but nothing on screen & no sound
Hello
This could be alot of things but I tend to lean towards a power supply issue. The short story is that when your tv starts up, it checks alot of things to make sure they are correct. If one of the voltages is off, then the tv protects itself and turns back off. In my experience when they turn back off its almost always power supply issues. It could be a card pulling down the powersupply, or the neat gizmo that powers the light. But I have not seen alot of that.
Generally if its not a power supply fault that the tv just cant tolerate it will flash a code at ya. Blink blink (Im messed up and here is the number of the fault) Blink blink BLINK!
I wish I had better news, however powersupplys are one of the cheaper and easier things to fix.
Best of luck
Nov 25, 2010 | Mitsubishi CS-32307 32" TV
I have a Philips TV Model # 32pt5441-37. When I turn on the tv a red line a green line and a blue line show up for about 10 seconds and then it turns off. The power button is blinking - 1 long 3 shortis...
This was a common problem for these tv,s. The tv is getting to hot it sounds like and that is why it comes on and then off right away. The tv is made to shut off if it sense something wrong like, over heating, something goes out and the tv knows so it shuts it down as well. That could be alot of problems to find out the wright problem you might need schematics for that tv. The tv is putting out a code as well right? The code that you mentioned might tell it for you. Enter the tv and model number in your seach provider and it will come up with a little searching on the internet your blinking problem.Thanks
Oct 06, 2010 | Philips 32PT5441/37 32" TV
I have mediacom cable TV and they gave me a universal electronics Atlas OCAP 5-Device Remote Control It is preprogrammed for my set- top box. I can not turn my TV off and on or turn my volum up and down,...
Not all remote control devices use the same signalling method for Infrared communication. You may have to get a true universal remote like a Logitech Harmony which can not only output most signaling codes but can learn codes from your existing remotes. It also permits one to define tasks, such as "Watch DVD" using a relatively simple web interface. Once programmed, pressing Watch DVD will cause it to turn on the proper devices with the proper inputs selected.
Note that these programmable remotes can be expensive. I bought an older Harmony 550 for a lower price and it handles my satellite box, stereo system, TV, DVD and VCR with one-button selections.
Jan 02, 2010 | Insignia LCDTV26 26 in. Television
My rca toshiba 50 inch projection tv is showing a 3d color curve
Need the model number to help as I am not sure of you have a RCA or a Toshiba
Dec 19, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
Need the remote code for flat screen tv
google your emerson remote's part number and you should find a list online.. i do this alot...
Apr 25, 2009 | Philips Magnavox 32MT6015D TV
When somebody text me, it shows the number.
Make sure the way the number shows up is the same way you put it into your contacts. (If there is a "+" in front of the number add it to the rest of your contacts)
Then when they text or call, the person's name should show up instead of their number.
Apr 04, 2009 | AT&T CECT Unlocked i68+ Quadband GSM FM...
Samsung 52' TV Is showing red
MY SAMSUNG TV MODEL NUMBER LE32R87BD IS DISPLAYING A RED FLASHING LIGHT ON THE POWER BUTTON AT THE FRONT OF THE TV THERE IS NO PICTURE PLUS IT WONT TURN ON CAN ANYONE ASSIST ME WITH THIS PROBLEM
Feb 06, 2009 | Samsung PCN5425R 54" Rear Projection...
Flashing red light . i have unplugged and plugged back in green light comes on then goes away and red light returns and flashes. i have had the tv 2 yrs to the day almost. what do i do
When the led flashes a certain number of times it tells the technician what circuit is at fault causing a problem resulting in total shutdown. There are no secret codes or methods to get your tv back up and running without having it repaired "SORRY". On Philips models a 7 flash window indicates an under voltage within your power supply circuit. This means there's a Op-Amplifier, high wattage resister, Power-IC, Diode, or NPN-PNP transistor that has developed an internal defect and needs to be replaced. Keep in mind that these TV's produce alot of heat and so the components on the circuit board are prone to thermal breakdown over time. I can show how to fix this problem if your willing to cooperate with me and follow some steps.
Your tv will not work again unless its opened and serviced! Period.
Jan 20, 2009 | Philips 42PF7320A 42 in. Plasma HDTV
Code number for sky remote
Hi! I have the same TV and nearly gave up on this but by trial and error found 0206 works! Hope this works for you!
Sep 07, 2007 | Televison & Video
Smart lock access code on tv
A model number for your Magnavox TV would be helpful because the Parental Control Reset procedure varies. There should be a sticker on the back of the TV showing the model number. If you have a newer LCD model, the unlock code is usually 0711. Ignore any "Incorrect" warning and enter 0711 again. Then set or clear the Parental Access Code.
Sep 07, 2007 | Akai CFTD2083 20 in. TV/VCR/DVD Combo
Televison & Video Logo
23 people viewed this question
Top Televison & Video Experts
Electro Med Services...
