Question about Cell Phones
Remove blocked numbers - Cell Phones
Can you block a phone number on a Doro 6520 cellphone
Yes you can
How to block a phone number on Doro 6520 - Phone-Info
https://phones.brain-start.tech/block-phone-number/how-to-block-a-phone-number-o...
Aug 12, 2017 - Because you have an Doro 6520, you can also block text messages from a phone number. First, open the application "Messages" and then press the menu button located at the top left of your Doro 6520. Then you will see a list and you will need to press "Settings". Then click "More". You will have access to ... People also ask How do you block a number from your phone?
How do you block a number on a consumer cellular phone?
How do you block a phone number on an LG flip phone?
How do you block a number on a ZTE phone?
Feedback
How to put or remove a blacklist contact on yo ur Doro 6520 - Phone-Info
https://phones.brain-start.tech/.../how-to-put-or-remove-a-blacklist-contact-on-yo-ur-d... Jul 17, 2017 - To actually add the number to the blacklist on your Doro 6520, simply go to the contact containing the number in question, click on the 'menu' key of your Doro 6520, and select the 'block this contact' option or 'add it to the blacklist'. That's it, your contact is now added to the blacklist of your Doro 6520.
Doro 6520 - Turn call barring on or off
https://userguide.vodafone.co.nz/doro/6520...os/calls.../turn-call-barring-on-or-off/ Turn call barring on or off. You can block certain types of calls such as incoming calls when you're abroad. Key in your barring password and press the Navigation key. The default barring password is 0000.
Feb 20, 2018 | Cell Phones
Call blocking is full. How do I free it upp
Hello, Tamara -
To free up space on your list of blocked numbers, you will need to remove one or more of the numbers in your call blocking list.
You will have to decide which number or numbers to remove.
When I have to do that, I choose the oldest numbers in my call blocking list.
Best wishes.
Jan 27, 2018 | Cell Phones
Unblocking a blocked number that was blocked accidently.
Go into Settings and Look for Blocked Numbers and Unblock it.
Instructions here
Unblocking blocked number Google Search
Dec 11, 2016 | Cell Phones
How do do removed calls from the blocked call list.
For reactivating the Blocked numbers go to CONTACTS/settings
and remove the blocked numbers ,
Dec 19, 2015 | Lands Phones
How to restore blocked number
Unblock by going to:
  1. Settings
  2. Phone
  3. Blocked
  4. Edit
  5. Delete number you no longer want to block.
Sep 01, 2014 | Apple iPhone 4 Black Smartphone
How can i unblock a previously blocked phone number from my blackberry phone
Hello.
First, access your Block List:
  • 1 Press the "Menu" key or option from the home screen on the BlackBerry.
  • 2 Scroll to and select your "Address Book" icon.
  • 3 Click the "Menu" key when your Address Book list appears.
  • 4 Select the "Manage Numbers" option.
  • 5 Click on the "Block List" option.
  • 6 Select "OK" or "Yes" to access the block list in your address book.
Then, remove the number:
  • 1 Select the option for "Number" or "Unknown Numbers" from the block list.
  • 2 Delete the number that you want to unblock or remove.
  • 3 Press the "Menu" key when you are finished.
  • 4 Scroll to and click the "Save" selection.
Hope this helps.
May 26, 2011 | Cell Phones
I have a mobile phone samsung sgh 700i i blocked a number but cant remove the blocked number from the reject list, how do i do that please?
please dial from that number and then in your mobile immediately check the options on the call for view and then remove the call reject list for a particular number or all number
Mar 27, 2011 | Samsung SGH-L700 Cell Phone
How can i block a junk fax number in a hp j3640 thanks in advance
Set the junk fax mode
By default, Block Junk Fax mode is turned On . If you do not subscribe to a caller ID service through your phone provider, or do not want to use this feature, you can turn off this setting.
To set the junk fax mode
Press Setup .
Press the right arrow to select Basic Fax Setup , and then press OK .
Press the right arrow to select Junk Fax Blocker Set Up .
Press the right arrow to select Block Junk Fax the press OK .
When prompted, press 1 for Yes or 2 for No .
Add numbers to the junk fax list
There are two ways to add a number to your junk list. You can select numbers from your caller ID history, or you can enter new numbers. The numbers in your junk list will be blocked if Block Junk Fax mode is set to On .
To select a number from the caller ID list
Press Setup .
Press the right arrow to select Basic Fax Setup then press OK .
Press the right arrow to select Add Number to Junk List , and then press the right arrow to select Number and then press OK .
Press the right arrow to scroll through the numbers from which you have received faxes. When the number you want to block appears, press OK to select it.
When the Select Another? prompt displays, do one of the following:
If you want to add another number to the list of junk fax numbers , press 1 to select Yes , and then repeat step 4 for each number you want to block.
If you are done , press 2 to select No .
To manually enter a number to block
Press Setup .
Press the right arrow to select Basic Fax Setup press OK .
Then press the right arrow to select Junk Fax Blocker Set Up and then press OK .
Press the right arrow to select Add Number to Junk List press OK , and then press the right arrow to select Enter Number .
Use the keypad to enter a fax number to block and then press OK . Make sure you enter the fax number as it appears on the display, and not the fax number that appears on the fax header of the received fax, as these numbers can be different.
When the Enter Another? prompt displays, do one of the following:
Remove numbers from the junk fax list
If you no longer want to block a fax number that number can be removed from the junk fax list.
To remove numbers from the junk fax list
Press Setup .
Press the right arrow to select Basic Fax Setup then press OK , and then press the right arrow again to select Junk Fax Blocker Set Up then press OK .
Press the right arrow to select Remove Number from Junk List .
Press the right arrow to scroll through the blocked numbers. When the number you want to remove displays, press OK to select it.
When the Delete Another? prompt displays, do one of the following:
If you want to remove another number from the list of junk fax numbers , press 1 to select Yes , and then repeat step 4 for each number you want to block.
If you subscribe to a caller ID service through your phone provider, you can block specific fax numbers, so the HP Fax does not print faxes received from those numbers in the future. When an incoming fax call is received, the HP Fax compares the number to the list of junk fax numbers you set up to determine if the call should be blocked. If the number matches a number in the blocked fax numbers list, the fax is not printed. (The maximum number of fax numbers you can block varies by model.)
Thank you.
Sep 17, 2009 | HP J3680 Officejet All In One Printer
Blocked number
the caller has blocked their number not you
Feb 05, 2009 | HTC S730
Cell Phones Logo
27 people viewed this question
Top Cell Phones Experts
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
