I recently purchased an LG NB3740 Soundbar and everything works great as far as sound. The problem I'm having is that when I try to access the home screen menu to search thru apps, settings and other content, it will only stay on the menu for a split second then revert to an optical page that says something about using Optical in..... Now, the system is hooked to the tv using the provided optical cable and I also used an HDMI cable. I've tried unplugging one and using only the other but nothing seems to allow me to use the menu screen. I still need to look thru the disc manual that came with it, on my computer but does anyone have any thoughts or ideas? Thx
  • Daniel Olivas Haro
    Daniel Olivas Haro Nov 06, 2017
    Did you manage to fix it? I have the same problem
  • 10,263 Answers
Disconnect the HDMI cable and use only the optical cable for better sound. Don't connect both at the same time. Once the set sees the optical cable it switches to it.
Posted on Nov 17, 2014
  • Doug Nov 17, 2014
    Ok, thank u..... I will try it tonight. I thought I did that already but maybe not. Hopefully that works. Thanks alot!!
  • Doug Nov 18, 2014
    Ok, only used the optical hookup and the problem is, the bar has a home setting which shows on the tv screen. I believe it's using the HDMI for the video feed. Which, I don't understand as I thought optical carried both sound and video?? I used the optical to go from directTV to the bar and HDMI from the bar to the tv. Same issue.... I think the problem lies in the input setting for my Vizio tv. The directv is HDMI 1 and the sounbar is on HDMI 2....why it doesn't read it as optical i have no clue. But like i said, if i just use optical, i get no pic as far as using the home scren of the bar for my settings and apps. Should i be using the directv as a go btwn??
5 Suggested Answers
  • 9 Answers
SOURCE: hooking up a sony playstation 3 with digital optical cable
Here's one solution, if you have an audio output from your tv, you can go from the audio output on your tv to the audio input on your receiver that way anything that is playing on your tv for example, playstation 3, dvd player etc. Anything playing on your tv will have audio on your onkyo home theater system. The other thing I would try if you want to hook ps3 directly to receiver is go to your connection settings on your ps3 menu and change your connection method to digital optical cable.
Posted on May 15, 2009
smarthome2
  • 1114 Answers
SOURCE: Sony HT-CT100 soundbar + STR-DG720 = Yes misery, no audio
It's not going to do whayt you want. On the premise that you can't run a dedicated receiver to a dedicated receiver. One processor is not going to override another. The soundbar is a "self contained" closed system. Much like Bose products. I understand what you are looking for, it just can't be done with this product. Options: replace the sony soundbar with a passive polk soundbar or similar and keep the AV receiver or: Return the AV receiver and use the nice, but limited sony amplified soundbar. Hope this helps
Posted on Jun 25, 2009
  • 85 Answers
SOURCE: I have an LG TV
There are two things that I can suggest.
1-Test your optical cables to make sure they a good on a known working source because they are very fragile and break very easily.
2-Try to eliminate the use of optical output from tv to receiver. There may be a problem from the HDMI to optical conversion at the tv. Instead, try running the audio directly from the source to the receiver, and let the tv deal with video input only.
Hope this helps,
Good Luck.
Posted on Jan 07, 2011
  • 22 Answers
SOURCE: I have an RCA home theatre...model rt2910. I have
You should have the HDMI plugged into the Home theater unit. The theater unit then is attached to the TV using the HDMI out.
The home theater unit passes the HDMI through to the TV while playing the audio for you.
You will likely need to select the correct source on your RT2910.
Here is a link to the manual.
http://www.1800customersupport.com/productdocuments/RT2910_RCA.pdf
See the section entitled "Connecting to HDMI Components" for an illustration of what I have described above.
Posted on Feb 28, 2011
The vizio amp speaker plugged into my tv and bluray player stopped outputting sound when watching a dvd and now only blinks in a set of light at the bottom. What does this mean and how can I fix it?
TV sound bar problem - Audio - Audio - Tom's Guide
www.tomsguide.com/answers/id-1991267/sound-bar-problem.html
Jan 23, 2014 - I recently purchased a Vizio E Series Razor LED 60" tv for my home, and ... The TV plays sound with built in speakers fine, ... on the source playingthrough the tv, if via hdmi, the soundbar would ... Alright I plugged it in but still nosound. ... the tv hooked up yet but my bluray player runs off HDMI and my xbox ...
No Sound Thru Speakers (only sound thru TV) - VUDU Forums
https://forum.vudu.com/showthread.php?...No-Sound...Speakers...sound...
Jun 18, 2011 - 10 posts - ‎8 authors
Just purchased and connected an LG wireless internet-ready TV to a receiver, a DirectTV HD DVR satellite box, and surround sound speakers. ... Cable, Blueray player, and others internet services, like Cinemanow provide ... because i have a Vizio Soundbar 210WS model, and i have to go into the TV ...
Jan 01, 2016 | Vizio VSB210WS Soundbar
Sub woofer wont pair, brand new NB3740 LG Sound Bar
smart electronics sometimes aren't as smart as we wish for eh
Feb 23, 2015 | LG Audio Players & Recorders
Connecting a sound bar
Typically you will connect the RCA audio output jacks to the audio input jacks on the sound bar, but if your television does not have RCA audio output, you may have to buy additional hardware to make the soundbar work. If your TV has a headphone jack, then you will need to purchase an 1/8" Headphone connector to RCA Connector cable from a local electronics or audio store. If your TV doens't have any audio outputs, you may need to purchase a digital tuner box and connect it to your TV and soundbar.
Jul 19, 2014 | Sharp home theater system HT-SB300 User...
Sound bar compatibility
Make sure red glow is coming from TV's Opt out cable when TV is on. If it is, it is working. The best solution is use an LG soundbar with an LG TV. There is a differnce in digital outputs and with a "service remote" (used by authorized LG servicers) you might be able to change the TVs factory setting to make the vizio soundbar work. but I think you'll be better off with the LG soundbar.
Feb 18, 2014 | LG 47LH55 47 in. LCD HDTV
How to pair my soundbar and wireless lg soundbar
Press and hold the reset button on the back of the subwoofer until the light on the front starts blinking. Then with the soundbar turned on, press the stop button on the soundbar and the mute button on the remote at the same time. The display should say "REMATE". The sub light should stop blinking then and should be linked.
Feb 03, 2013 | LG Lsb316 Sound Bar With Wireless...
We bought a Samsung Soundbar x810 but the Subwoofer does not seem to be working properly although the blue and red led light up. I have tried rebooting/resetting per user manual instructions but it still...
Purchased a x810 & everything tests out fine except TV signal sounds from cable box. We have the Comcast cable box connected to the 50" Samsung Plasma TV hooked up to Samsung x810 Soundbar all using HDMI cables. But we are not getting cable shows sound through Soundbar. Please advise
Nov 04, 2009 | Samsung HT-X810T Theater System
Need to multi region Phillips Soundbar
HI Ian,
Have also just purchased a Philips HTS8140 with Philips LCD screen.
Found a result on web as follows:
1.Turn on TV
2.Turn on Sound Bar System.
3.Press eject.
4.Press 9 9 9 0 (0 being Region Free or place the desired region #)
(a message displaying "region 0",or the region you chose, will appear on the screen.)
5.Switch soundbar off to soundby.
6.Turn player back on and it should be either region free or the region you selected.
So far I have not been able to check with anyother disc exept region 4.
Hope this is of help for you!
Xtopher
Jan 10, 2009 | Philips SoundBar DVD Home Theater with...
183 people viewed this question
 Grubhead
Grubhead
