Question about Electronics - Others
How to fix BC1 error on Tajima
Converted to USB drive. All of a sudden it will not read usb stick and keeps giving error BC1
SOURCE: To Fix my 8gb usb stick
Hi Karpai.
I've had the same problem, and after weeks of working on it - I was able to fix it quite easily. there is a radiation chip within the system which at times needs to be rebooted. Usually you have to take it back to the manufacturer ever month or so to get this done. However if you place the chip in the microwave for approximately 30 seconds it should do the trick. Make sure you cool it down before inserting it back into your pc.
Posted on Jan 03, 2008
  • 53 Answers
SOURCE: Verbatim USB 512mb storage device and Vista
sounds like a bad usb cable
Posted on May 01, 2008
  • 145 Answers
SOURCE: Micromax 2GB usb key cannot be formatted
Dear, Its is a know issue to microsoft, you try after installing latest service pack http://support.microsoft.com/?kbid=836618
And while formating from my computer, instead of FAT32, you can use NTF and try
Posted on Oct 17, 2009
SOURCE: my usb 4gb flash don my computer only reads in a secure K with 1m
See http://www.maxell.eu/FAQ2/FAQ.html
Venture USB contain two partitions - one named 'Public' and the other 'Secure'. Unfortunately we have noticed a compatibility problem between these drives and some computers running Windows Vista. In these cases only one drive is showing in 'My Computer' - usually the 'Secure' drive. As a result you are unable to access the user manuals and software which are in the 'Public' drive and cannot alter the partition sizes to allow access to the entire capacity.
Please follow the below instructions to resolve the problem:
1. Connect the USB to the computer
2. Please unzip and run the attached program
3. After completion please unplug the USB
4. Re-insert the USB to the USB port
5. You should now be able to access both drives.
Please click here to download the program and instructions
Posted on Jan 28, 2010
laikexpert
  • 281 Answers
SOURCE: my transcend usb jfv60 model is not accessible
1. Download this tool:
http://dl.dropbox.com/u/4040651/LLFTOOL.EXE
2. Format
(WARNING: After running this low level format tool,
the whole USB flash disk surface will be fully erased.
Therefore, data restoration will be impossible after using this utility!)
Posted on Jan 31, 2010
I can't add files to my USB stick, it gives me read only error. I'v done running Using Registry Editor and diskpart,still the error is present. What will I do?
it is write protected which means that you cannot add anything to the usb stick
you will have to get the administrators permission to change to edit the usb stick
if you are the originator of the original entry , then go to the permissions section and change to read and write
Jun 30, 2017 | The Computers & Internet
How do I fix error code BC1 on Tajima Embroidery Machine when there are designs on the flashdrive that did work yesterday
The format of your program may have different formats that will work for Brother but not Tajima. The extension of the program is the key to the one to use. You will notice a program name that is the very same but the extension is different. Your program can't be found if you use the wrong extension. Use other design extension or you may need to register the program.
Nov 18, 2014 | Sewing Machines
PC stops booting after USB devices are enumerated
Firstly when you restart your computer, does it dispay an error message reading, THE SYSTEM HAS RECOVERED FROM SERIOUS ERROR.
Apr 05, 2013 | EliteGroup GeForce6100PM-M2 (V3.0)...
Windows - No Disk error when using 3G USB stick
Make sure it is formatted in FAT and not NTFS, also eject/unmount vs. unplugging it. Trying plugging the USB drive in the back of the PC's USB port instead of the front panel USB port.
Nov 17, 2012 | Microsoft Windows Xp Home Edition Sp2...
How to change from xfat to fat 32
HERE you can read how to fix errors and format a USB memory stick.
Oct 22, 2011 | Kingston (DTIU3/2GB) 2 GB USB Hard Drive
Sony memory stick duo pro 1gb is using for Sony handycam is suddenly started giving error message like reinsert memory stick. I have important pictures and video in it, now i need to recovery them. Do...
Hi Devika,
Buy a card reader that can read your memory card and connect to the computer. (Less than $8 in Sri Lanka). Connect it to PC and insert the card to the card reader.
Download Recuva and run it. select the memory card. Try to recover the files.
Best of Luck!
Sep 21, 2011 | Sony 1GB Memory Stick PRO Duo Memory Card
USB drive does not regularly read the USB flash
I have a Designer I USB that suddenly started not reading the usb stick that came with the machine. I was terrified that my machine was going bad, but I always start with the cheapest solution first. I bought a new usb stick, loaded the designs from the old one into my software then loaded everything on the new usb stick. My machine reads it every time so far. I replaced the usb stick about 3 months ago and have not had another problem since. I don't know if this is your problem, but usb sticks can go bad and since they are so cheap, I would try this first.
Jul 11, 2010 | Husqvarna Designer I
USB drive read problem Designer I USB
I have heard that the problems with these converted Designer 1 USB's have been and always will be problems for mechanics. I can suggest who you to call for help. His name is Gary and he is the main mechanic at the Montavilla Sewing Center in Portland, OR. He is my good bud. You can call him at 503-2547317 and ask him your question and say that you are a friend of Lin Baker's. I hope he can help you. Otherwise, you can talk with Billy Martin the software guru there. Someone there should be able to help. The USB's should never have been converted over. The new drives are not communicating with the initial floppy drivers. BIG TROUBLES. Trade it in on the LE asap before it loses it's value if it hasn't already. Hope this helps.
Jun 15, 2009 | Husqvarna Designer I
Will playstation 3 play blu ray movies off usb memory stick? all other movies worked but blu ray one didn't work.
the PlayStation 3 can read just about any usb memory stick and play can movies from them, since a usb's bandwidth is significantly lower then the ps3 hard drive it's recommend to copy the movie to the ps3's hard drive.
also it matters how the movie was converted. some converted movies wont play on the ps3 no matter what codec your using to encode the movie with.
Jun 03, 2009 | Sony PlayStation® 3 (80GB) Console
FY100
From all the info I can get it is the same chassis as a brother PE100. It used custom eeaprom cards and read .PEC or .PES files.
It could also be like the Bernette Deco 500 or 600 series. I have also seen a modification of this chassis called the EM10 by Husqvarna and it is USB direct connect and comes with software that outputs .HUS files.
Jan 29, 2008 | Sewing Machines
Electronics - Others Logo
76 people viewed this question
Top Electronics - Others Experts
Are you an Electronics - Other Expert? Answer questions, earn points and help others
