Question about Ask.com Ask Toolbar
Uninstall Ask.com on Linux
I nerver want it on my pc
    Master:
  • 388 Answers
Give this a try
Posted on Dec 02, 2014
How to uninstall mint linux single boot
Use the Linux menu to uninstall.
Jul 13, 2014 | Computers & Internet
Bought used need to by pass password
You didn't say what OS you are using.
1.To try and remove the password protection you can power off the PC.
remove the side panel and then remove the battery. Leave it for 10 minutes, refit the battery and then power up the PC. The password protection may have been removed.
2. Or at start up, enter the bios settings. You may be able to disable the password from within the settings.
3. If you're not bothered which OS you use, try a new install of XP or Windows 7.
If you don't have XP or Windows 7, ask a friend to download linux and burn it onto a dvd for you(or put it onto a usb flash drive). Put the linux dvd into your dvd drive and restart the computer. You will have the choice of completely erasing Windows, or installing Linux alongside Windows.
Linux is free. It will do everything Windows can do. Linux comes with its own version of 'Office'. The best free versions of Linux are Ubuntu or 'Mint'.
You can download Ubuntu here: http://www.ubuntu.com/download/desktop
Webcams do NOT work in Linux. Apart from that, Linux will do everything Windows can do (but free!) and you won't ever get a virus.
Jan 03, 2014 | Sony Computers & Internet
My screen is stretched
Find 'system restore' and restore your laptop to a date prior to when you uninstalled the prog.
Oct 31, 2012 | ASUS 8.9" Eee 4GB PC Netbook Computer with...
I have a desktop PC with HP v72 monitor and a GeForce FX 5200 video card installed. I uninstalled Windows XP and installed Ubuntu Server 11.04. The problem is that after the initial boot screen my monitor...
why run server, , sure you actually want a server.. sure.
Linux, run the newest Ubuntu on new pc
or older on older pc, ive no idea at all what PC you have.
v72 old CRT , glass tube monitor a RELIC in today world.
why post OS questions lacking what HP computer you have of 1000s.
XP gone great idea, for sure....
OK F8 is Microsoft , for get them it not MS now, not at ALL.
in the Linux world its failing to find the correct minimum or
best resolution to match your old monitor
the monitor is year 2000.
the best resolution is 1024 x 768
you are using new linux, and it does not use that old old CRT
weak as a cat resolution,
you can use and older linux, or newer monitor
or change the resolution
using
if seen and done this 100s of time, endless,
btw your OLD CRT monitor does not use proper PnP plug and play
data comms.. its too old, why mess with CRTs in 2017?
walmart sells a $45 LCD , use that? and avoid darkages resolutions.
the way to do this is to run in command line mode
and change the config file, called, xorg.conf
https://techblissonline.com/ubuntu-804-set-default-resolution-1024-768-virtual-pc-2007/
there are other ways,
recompile the kernal to default to this reso? relic
or there is hot key at boot, read the manual on ubuntu
and change to lowest poor resolution
then run setups with a working desktop.
ask on a Ubuntu forum, it can vary by year, OS made and version
and what what desktop running of the many.
https://wiki.ubuntu.com/X/Config/Resolution#Resetting_an_out-of-range_resolution
keep in mind
your CRT is not supported now.
you must force it.
one more for V12, dropped the startup manager, wow....
best is to ask only for your version and choices at install time.
grub , KDE? what?
http://ubuntuguide.net/monitor-signal-out-of-range-problem-in-ubuntu-12-04-precise-fresh-installation
Jun 11, 2017 | HP V72 17" CRT Monitor
How to unistall kalydo player
Uninstalling programs varies from Operating system to operating system. If you are running Windows, you should be able to go through the "Add/Remove programs" function located in the control panel. If this is not working, try visiting this site:
http://www.ehow.com/how_2457_uninstall-windows-program.html
there are step-by-step instructions for uninstalling windows programs there. If that did not help, try using this program:
http://www.error-expert.com/uninstall_any_software.html?gclid=CJyNnqi2hqkCFcxL2god5BAioA
I have not tested this program myself, but the descriptions I have read about it say it should work without a problem. If you don't trust this program, check CNet.com for "uninstall programs". They are a well-known and virus-free site for information and downloads regarding computers.
If you are running a Linux OS, check the distributor's web site for more info on uninstalling the package. There are so many different distributions for Linux that it is impossible to give an exact procedure without knowing which one you are using.
If you are running a Mac system (you have posted in the wrong place, but I'll help anyways :-) go to : http://www.ehow.com/how_4922735_uninstall-programs-mac-computers.html the directions are there, and should be able to guide you through it.
Best of luck!
May 26, 2011 | Computers & Internet
I will ask if i can download windows 7 on linux acer aspire 4738?there will be a problem?
there won't be any problem as far as Windows and Linux, but this is a fairly involved procedure.You'll first need to create a Windows partition on your hard disk in NTFS file system format. Otherwise,Windows might overwrite / erase your linux installation when Windows 7 installs.
make the windows partition the "Primary" or "Boot" partition.
When Windows 7 installs, it may ask if you want to delete the linux partition.Answer "NO" to this.
The next concern is which operating system will boot by default,Windows or Linux.
I had no problem doing this with Windows Vista, and whe Vista booted,it listed a choice of operating systems to boot,and I would select either Windows Vista or Ubuntu Linux.
Apr 03, 2011 | Acer Computers & Internet
I am currently trying to uninstall my old HP printer. I don't have it anymore and a new one is on its way, but I can't get it to uninstall. I believe I need to reinstall it to uninstall it. The...
are you really running LINUX or did you join the wrong forum?
windows.
the drivers never need uninstalling
just the HP application programs.
so you do to Control panel
then click, programs.... bla bla.
unstall HP printer apps.
done
if linux tell the linux you are running ,its like 100s of distrubutions and times zillions of releases, like Red hat, or opensuse or Ubuntu, my fav.
tell the helper what PC is this. xw4600a
and what OS exactly.
Apr 27, 2017 | HP xw4600 Workstation Linux Installer...
I have just purchased an acer one notebook with linux system...the delete private data option dosn't work...please help.Google toolbar keeps trying to load itself onto the system when I'm online even...
Seems like you best go looking for some Linux tutorial on the internet, or go back to Windows.
Simple google search got me this, you can try it:
www.linux-tutorial.info
May 19, 2009 | ASUS Eee 2G Surf Notebook
Computers & Internet Logo
50 people viewed this question
Top Ask.com Computers & Internet Experts
General Systems...
ka4iup
ka4iup
SANJEEV KUMAR SURI
SANJEEV KUMAR SURI
Are you an Ask.com Computer and Internet Expert? Answer questions, earn points and help others
