Question about Vtech Lands Phones
My one vtech phone currently says Find HS and when I register, the registration fails. It doesnt allow me to dial out? Please suggest next steps
Model # CS6419-3
SOURCE: registration
HI TEAM ,
PLZ SEARCH MY COMPUTER SCANING PROBLEM INSIDE.
REGARDS
A. S ENTERPRISES.
KANPUR
Posted on Nov 13, 2007
SOURCE: Registering a new phone
I tried your solution - putting the phone on the answering machine charger and it worked! Thank you!
Posted on Dec 28, 2007
SOURCE: Uniden DCT648 register phone problem
On the Base Station select HS Registration then on the Handset hold # for 2 sec
Posted on Apr 13, 2008
  • 4 Answers
SOURCE: How to I reset the base for a Vtech VT-2431
This worked for me after lots of digging....If you have already tryed reregistering your handsets and can only get two-or three to work try this and deregister them and re-register. If your base model number is vt2431: Take the handset out of the base, press **335782 on the dial pad of the base. (do not have the line active or anything , just put the (2) stars and 335782 in (no spaces) on the base unit. This will de-register all of the handsets at one time.
Posted on Aug 16, 2009
  • 4 Answers
This worked for me after lots of digging....If you have already tryed reregistering your handsets and can only get two-or three to work try this and deregister them and re-register. If your base model number is vt2431: Take the handset out of the base, press **335782 on the dial pad of the base. (do not have the line active or anything , just put the (2) stars and 335782 in (no spaces) on the base unit. This will de-register all of the handsets at one time. Then just re-register the handsets...
Testimonial: "This works perfectly!!! I don't know how you found it, but GREAT JOB!!! THANKS!!!"
How to register the extra cordless handset of vtech 15250
Add and register a handset
Each newly purchased handset must be registered to the telephone base before use. When first purchased, each expansion handset shows NOT REGISTERED.
You may need to charge the phone first.
To register a handset:
    ·Place the unregistered handset in the telephone base or charger. Press Find for 4 seconds. If the headset screen doesn't light up after the 4 seconds. You will need to charge it some more.
    ·After making sure it is charged set the telephone on the main base again press and hold the Find button for 4 seconds ( until the red light IN USE comes on) Then release the find button. The headset will show PLEASE WAIT; this takes about 10 seconds to complete the registration. The hand set will show HEADSET REGISTERED and the headset number assigned, you will hear a beep when the registration is finished
    ·When the registration is complete, the newly registered handset is assigned the next available handset registration number. For instance, if you already have HANDSET 1 and HANDSET 2, the next registered handset is HANDSET 3.
    ·Makes sure no other headsets are in use at the time or the registration may fail.
    ·You cannot register a handset if any other system handset is in use. Only one handset can be registered at a time.
Aug 18, 2017 | Vtech Lands Phones
Bought a used vtech 5.8 phone, charged the battery and now see message "not registered. I can not make calls... how do I register it?
I believe it is telling you it is not registered with the Base Unit. You did get the Base Unit with it didn't you, otherwise you have a paperweight.
If you do have a set then this is the answer
Tip 1 of 1
Step 1: Place the handset in the base or charger. If PRESS FIND HS 4 SEC ON BASE does not appear on the screen after a few seconds, lift up handset and recradle it in the base or charger.
Step 2: On the telephone base, press and hold FIND HANDSET for approximately four seconds. Release FIND HANDSET once the IN USE light comes on.
After a while, the handset will emit a series of tones, and the newly registered handset will be assigned the lowest extension number not previously assigned to another system handset when successfully registered. Repeat Steps 1 and 2 if the handset does not successfully register to the telephone base within two minutes.
https://vt.vtp-media.com/ecp/documents/product_Product/67/UserManual/1647/ia5874_manual_bkm.pdf
Search Results
VTech 5.8GHz Cordless Home Telephones & Handsets ' eBay
https://www.ebay.ca > ... > VTech 5.8GHz Cordless Home Telephones & Handsets Results 1 - 25 of 151 - This is a Vtech 5.8 cordless phone digital answering machine base with time stamp & a handset that needs a new battery. It came from an ...
Technical Product Support ' VTech® Cordless Phones
https://www.vtechphones.com/support/technical-support Stay up-to-date on new VTech products, emerging technology and special offers. ... My VTech DS6722-3 Cordless Phone rings once and then disconnects. Why ...
Vtech 5.8 Phone Instructions ' Techwalla.com
https://www.techwalla.com/articles/vtech-58-phone-instructions Mar 31, 2015 - The Vtech 5.8 is a cordless phone that allows you to add additional handsets to your main phone so that you can have quick access to phones ...
[PDF]User's manual - VTech Canada
www.vtechcanada.com/support_docs/vtt/CS/CS5111-x_en_cib.pdf everything new at VTech, visit our website at www.vtechphones.com. ..... Once you have initiated your call by dialing the phone number in pulse (rotary), press.
[PDF]User's Manual
https://vt.vtp-media.com/ecp/documents/product.../67/.../ia5874_manual_bkm.pdf and operate your new VTech phone . Please take the ... Enhanced 5.8GHz Technology - Dual band transmission combines the best of 5 .8GHz and 900MHz ...
Video as well in link
vtech 5 8 phone Google Search
Jul 17, 2017 | Vtech Lands Phones
How do I register my vetch cordless phone?
General - Product Troubleshooting - VTech® Cordless Phones
www.vtechphones.com/support/.../35/178
VTech Communications Inc.Step 1: Place the handset in the base or charger. If PRESS FIND HS 4 SEC ON BASE does not appear on the screen after a few seconds, lift up handset and recradle it in the base or charger. Step 2: On the telephone base, press and hold FIND HANDSET for approximately four seconds.
Product Registration - VTech® Cordless Phones
https://www.vtechphones.com/.../product-re...
VTech Communications Inc.Vtech DECT 6.0 cordless phones are among the most advanced and innovative homephones on the ... Product Registration. How do I register my product?
vtech cordless handset, how to register - YouTube
? 3:21
https://www.youtube.com/watch?v=dV9rZ_cYcks
Feb 22, 2015 - Uploaded by Brian Williams
i registered my handset but im not able to call and answer call from my ... you lose your phone you have to de register allphones and start over.
Jan 21, 2016 | VTech Communications CS6114 - cordless...
I cant dial out it says register HS i am not familiar with the procedure.
When you reset a handset (or if you buy a new one1, that handset displays a Handset Not Registered message. If you see this message on a handset, you need to register it to a base before you can use it.
Registering a handset
Does the handset fit in the base cradle?
Yes
No
Place the handset in the base.
The display should say Handset Registering.
1. On the base, open the menu and select Register Handset. The display should say Handset Registering.
2. On the handset you want to register, press and hold # until the handset display says Handset Registering (about 2 seconds).
In about 30 seconds, the handset display should say Registration Complete. Press TALK ( )/FLASh and make sure you get a dial tone. page29image32024
27
If...
Try...
- you don't hear a dial tone- the display says Registration Failed
Making sure the handset is fully charged, then start over at step 1.
To register a handset to a different base, see the section "Expanding Your phone" in the user's guide for the other base.
Mar 18, 2014 | Uniden DECT 6.0 Cordless Phone ID
I have a uniden Tru9466 base station and a uniden TWX 977 that the later that was previously registered with the first displayed a out of range notice so I went thru the process in the owner's manual...
Welcome to FixYa.
  1. Turn OFF your handset (TWX977) and any other handset registered to the base (9466).
  2. Unplug the base from its power source.
  3. Unplug the phone line from the base.
  4. Wait for 15 mins.
  5. Plug back the power source and the phone line.
  6. Turn ON the handset (TWX977)
  7. Reset the handset (TW977) by doing the following:
  • Press the MENU soft key. Select the DEREGISTRATION submenu.
  • ARE YOU SURE? appears. Move the cursor to select YES. Press the OK soft key.
  • To clear other handset information, please follow these steps:
  • From the handset, press and hold [ ] and [#] for more than 5 seconds. Select the DEREGISTER HS submenu.
  • Move the cursor to select the handset ID to be de-registered from the list, and then press the OK soft key.
  • DEREGISTER HS appears. Move the cursor to select YES. Press the OK soft key.
  • ARE YOU SURE? appears. Move the cursor to select YES, and then press the OK soft key. You will hear a confirmation tone.
8. Register the handset by doing the following:
  • With the base in standby, press the MENU soft key.
  • Move the cursor to select REGISTER HANDSET. Press the OK soft key.
  • On the handset, press and hold [#] until you hear a beep.
  • While the handset is registering, HANDSET REGISTERING will appear in the LCD. When REGISTRATION
  • COMPLETE is displayed; the handset has been registered to the base. If REGISTRATION FAILED appears,
  • please try these steps again.
Thank you for using FixYa.
Have a great day.
Jas247
Aug 22, 2011 | Uniden TRU9466 Cordless Phone
My vtech phone says not registered and not sure why and how come? can this be fixed or do i have to buy new one? model # CS6114 S# LR605935851
Here is a direct link to the User's Manual for your phone:
http://vt.vtp-media.com/ecp/documents/product_Product/1624/UserManual/5352/cs6114_manual_i6.pdf
To view the Owner's Manual with Operating Instructions just use your mouse to click on the link, which is the underlined and highlighted text just above. This will open a new web browser page automatically for you and allow you to view the information at the website indicated and the contents of the Owner's Manual.
You may need ADOBE READER installed on your computer to read PDF documents.
You can download this free at WWW.ADOBE.COM if necessary.
Click on the DOWNLOAD ADOBE READER button on right side of the ADOBE home page when you get there, then follow the onscreen instructions to install the software on your computer.
See page 26 of the manual for detailed instructions on HOW TO REGISTER THE HANDSET TO THE BASE.
Basically, the manual reads as follows:
Not registered appears on the handset and it does not work at all.
The handset may be deregistered from the telephone base.
Follow the steps below to register the handset to the telephone base.
1. Remove the handset from the telephone base.
2. Press and hold FIND HANDSET button on the telephone base for about four seconds until the red IN USE light turns on.
3. Then press # (pound key) on the handset.
It displays Registering... and it takes about 60 seconds to complete the registration.
The handset displays Registered for a few seconds and you hear a confirmation tone when the registration process completes.
I hope that was helpful to you, good luck and take care.
Joe.
Aug 13, 2011 | Vtech 2653 Cordless Phone (VTECHEV2653)
I just purchased from Vtech LS6475 plus two accessory handsets LS6405. The two handsets that were packaged with the base registered without a problem. The two access. hs's are not registering. They go...
the accessory hand sets have to be vthech ls5475 units the same as what came in the original packaging
the extras you got will not register with an incorrect base
take them back and exchange for the correct units
Feb 08, 2018 | Vtech LS6204 1.9 GHz 1-Line Cordless...
On the screen of the phone says not registered and wont allow me to make phone calls or recieve
Please try the following procedure to register the handset:
  1. Place the unregistered handset in the telephone base. If PRESS FIND HS 4 SEC ON BASE does not appear on the handset screen after a few seconds, remove the handset and place it in the telephone base again.
  2. On the telephone base, press and hold FIND HANDSET for about four seconds (until the red IN USE light on the telephone base turns on) and then release the button. The handset shows PLEASE WAIT... and it takes up to 60 seconds to complete the registration. The handset shows HANDSET X REGISTERED (X represents the handset number assigned) and you hear a beep when the registration completes.
When the registration is complete, the newly registered handset is assigned the next available handset registration number. For instance, if you already have HANDSET 1 and HANDSET 2, the next registered handset will be HANDSET 3
Mar 05, 2011 | Vtech DECT 6.0 Digital Cordless Phone
I cannot get my Vtech LS6204 to register. I have tried everything and the screen always reads registration failed.
I have a 2-handset VTech CS6419 that I had been using w/o problems for months. Both HS were always plugged in and charged. One day I found the base HS would not ring and the screen had the message that I needed to register the HS. Pressing the "find HS" button to start the process only made the accessory HS, not the malfunctioning base one, ring. I solved the problem by 1) unplugging the base, 2) pulling the batteries from BOTH handsets, then 3) replugging in the base and reattaching the battery for ONLY the malfunctioning HS. 4) I then did the registration process again (press the "Find HS" button on the base for 4 seconds, then press the # button on the HS and wait.) The malfunctioning HS then registered! I then reattached the battery to the accessory HS and returned it to its' base. Problem solved!
Jan 01, 2011 | Vtech LS6204 1.9 GHz 1-Line Cordless...
May 29, 2009 | Vtech VT-2431 Cordless Phone
Lands Phones Logo
24 people viewed this question
Top Vtech Lands Phones Experts
David Burbee
David Burbee
Are you a Vtech Lands Phone Expert? Answer questions, earn points and help others
