Question about Admiral Dryers
Admiral Dryer, runs bu t does not heat
Model AED4475TQ runs but does not heat
  • Admiral Master
  • 10,137 Answers
The thermostat, timer or the heating element itself are the places to check. Look at the circuit breaker for the dryer in the power panel. It will be two breakers connected together. If one trips but not both, the heating element will not heat but the dryer will run.
Posted on Nov 17, 2014
4 Suggested Answers
  • 1122 Answers
SOURCE: I have an Admiral dryer that is over heating. Its
bad high temp. theremostat on heater box-mike
Posted on Mar 15, 2009
SOURCE: Admiral 6.5 Cu. Ft. Super Capacity Electric Dryer not drying load
does the admiral aed4475tq have a reset button it will not turn on it is only 9 months old
Posted on Jan 01, 2010
SOURCE: my admiral dryer model AED4475TQ belt came off and the pulley is laying lose I need a diagram to fix it please help
Hopefully this helps! My drawing isn't great or good for that matter. The washer has a place to insert the pulley in front of the motor. Put the belt around the drum. Then push the pulley back away from the drum and insert the belt in between the forks and then wrap it around the pulley of the motor. I really hope this helps.
Posted on Oct 27, 2012
Admiral dryer won't heat. Fuses have continuity. Does run though. Heating element has continuity as well. Have both legs of power going in.
Check the high limit switches next to the drum and element. they are around the size of a quarter dollar, about one and a half inches. check continuity.
Jul 07, 2016 | Admiral AED4475TQ
Why isn't it drying?
Do you feel hot steamy air exiting the outdoor vent when machine is running? You should feel a pretty good blast coming out of there. If not, and the dryer is hot inside, you may find the fan is slipping on it's shaft and turning way too slow. Access the fan and hold the pulley that drives it and see if you can turn the fan without the pulley and shaft turning. The fan is made to slip under high torque, but often the clutch clamp lets it slip too easy.
Nov 10, 2015 | Admiral AED4475TQ
Won't dry but heats up and tumbles
Check the pipe where it comes out of the back for a blockage. Take it off completely. Also check the inside of the pipe and the vents where the steam exits your home. Sometimes birds nest in them or they just fill with fluff.
You can do a quick check by running the dryer with no pipe attached. Open the windows when you do it.
Elements will fail when they overheat due to blockages and lack or airflow.
Nov 04, 2015 | Admiral AED4475TQ
I have a admiral aed4475tq less than a year old and it just stoped and wont restart
Does the motor hum when you try to start it in the above mentioned manner? Does the door switch click when you push and release it?
Feb 14, 2013 | Admiral Dryer. 6.5 cu. ft. Electric Dryer...
Going from a 3 prong to a 4 prong dryer plug
Admiral AED4475TQ is an electric dryer? Was your old dryer gas? If so, you need a 220 line installed to run the electric dryer. Here is a link to instructions from ehow http://www.ehow.com/how_5824435_wire-220-plug.html.
Jan 13, 2013 | Admiral AED4475TQ
My admiral dryer model AED4475TQ belt came off and the pulley is laying lose I need a diagram to fix it please help
Oct 27, 2012 | Admiral AED4475TQ
Dryer suddenly stopped heating
Heating element, thermostat or thermal fuse
Feb 24, 2012 | Admiral AED4475TQ
I'm trying to install a 4-wire system electrical
Hi heathvaneato...
Go to the following webpage and you will see a picture and description of how to wire your dryer.
Please take time to rate me thumbs up.
http://www.selfhelpandmore.com/switch-outlet/dryer-circuit-wiring-and-hookup.ph
Sep 23, 2011 | Admiral AED4475TQ
Nov 29, 2009 | Dryers
Mar 14, 2009 | Dryers
Dryers Logo
150 people viewed this question
Top Admiral Dryers Experts
gbob59
Sal De
Are you an Admiral Dryer Expert? Answer questions, earn points and help others
