Question about RCA HD61W66 61" Projection HDTV
No convergence My convergence choice on the menu selection to automatically coverge my tv has totally disappeared. Because I wasn't there at the time when it started I'm unsure if there was a power surge. Is there anyway to reset the tv to see if it will scan the connection to read the convergence program again? Right now my tv is kind of half mooned and I cannot pull it down for a clear picture. Thanks, Angela
  • 1 more comment
  • Anonymous Jul 06, 2008
    Mine just went haywire. The convergence is obviously wrong. Looks like 3D without classes. The auto convergence option in the setup menu has disappeared. Call RCA and they said I had to have a repair man fix it.
  • Anonymous Feb 14, 2009
    exact same problemm.....can't find autoconverge
  • jdv0001 Mar 23, 2009
    I have the same problem...I just turned it on one day and it looked 3D with no glasses...So i tryed to find the auto convergence menu and obviously it is disappeared...Any help besides calling a repair man?
  • RCA Master
  • 8,617 Answers
Usually when that happens it is related to problems on the deflection board a diode or fusible link has opened making the set act like its a direct view thereby having no convergence option. It will take an experienced tech to properly diagnose that problem.
Posted on Apr 06, 2008
How do I adjust the manual convergence? I am in the settings, but my TV is not letting me adjust anything. I chose the "reset to factory" choice, but that didn't fix the red/green shadows
Your convergence has failed and needs to be repaired. Once quick test is to goto your convergence menu and see if you can adjust red and blue. If not its has failed and needs to be fixed. You can call in a repair shop or you can get the parts and instructions from and do the repair yourself. Its a fairly easy DIY fix.
Aug 27, 2011 | Philips Magnavox 51MP392H Rear Projection...
Help with RCA projection TV P46812BL (chasis ptk195AA)
You have probably blown one of the convergence ICs. Effectively the easiest thing to do is replacing the whole convergence board, so that no soldering is involved.
Here you can buy a replacement convergence board, just select your model.
Let me know if you need further help.
Sep 13, 2008 | RCA P52930BL 52" Rear Projection...
Auto covergence will not converge
Try this with tv turned off press and hold at same time the vol- and ch- wait untill TV comes on then release Buttons,TV will either start auto convergence or you will be in the service menu to adjust convergence.
Jun 26, 2011 | GE D52GW12 52" Rear Projection HDTV-Ready...
The Auto convergence feature listed under the setup menu will do it automatically. A common problem is the auto convergence feature will disappear from the setup menu. If yours has disappeared there is the convergence option missing repair kit from will solve the issue.
Jun 14, 2011 | RCA R56WH76 Projection Television
Hi I have a convergence issue. Is there a place in NYC where I can purchase these replacement items: (1) FL231 micro fuse (1) DL231 Diode (1) CL230 radial Capacitor I repaired the initial...
This DLP model RCA tv have convergence menu disappearing is very easy to fix just replaced the convergence fuse FL 231 near the FBT also must be resoldering FBT too.U can buy this FL231 covergence fuse at,but u must have to have a soldering iron,a desoring pump or desoldering braids and know how to basic soldering?To replaced this FL231 convergence fuse near the FBT and also must resodering the FBT too for protecting the new FL231 convergence fuse.
Mar 02, 2011 | RCA R52WM24 52" HDTV Projection Television
Unable to flash focus, red curved lines at the top of screen, manual convergance will not work, problem started after a lightning storm with power surge
Ur tv now,totally have dead parts,on the tv convergence board.That,why ur flash foucus or manual covergence alignment R,G,B colors line will not matches up.The convergence board parts 2 STK convergence ICS and some or all it resistors,must be replaced to solved convergence problems.The shop will cost u $300-350 for parts and labors.
Jul 29, 2010 | Sony KP-51WS510 51" Rear Projection...
Tv just looks like i folded picture need help on configurance set
The tv have a problems known as a convergence problems,it dead.U have tools,soldering iron,solders.U know how to do solders?Try to buy a convergence Fuse(FL231).The big block of plastic call the FBT.Resolder the FBT.The 3 three fuses caps on (FL231) beside it.The covergence fuse cap in middle is dead,replaced the covergence fuse cap in the middle will solved ur convergence problems.
Jul 17, 2010 | RCA D52W20 52" Rear Projection HDTV-Ready...
I need to know what convergence board I need and part number. TV is RCA Model HD52W59YX36. Symptom is see 3 d like shadows. When I go to do the covergence adjustment from the setup menu....nothing appears...
You dont need a convergence board. The convergence option missing from the setup menu is a easy cheap repair. has the kit called ITC222 & 222A convergence option missing repair kit. It also has the CD with instructions along with the three components that repair that problem.
Mar 27, 2010 | RCA HD52W59 HDTV Projection Television
Doesnt complete automatic covergence cycle. it
Your convergence ICs are shorting. Checkout and follow the instructions for repair. They will sell good quality tv parts!
Nov 29, 2009 | RCA D61130 61" Rear Projection Television
Covergence problem
your set has indications of several problems. red green and blue. indcate convegence issue. the fact that the picture is concave is a indication of totall loss of covergence power supply. the convegence menu missing idicate loss of some voltages from what know as the flyback.AND SHUTDOWN. indicate further problems. generally when convergence fails ..not always the set wont shut down. it could be a simple issue but further trobleshooting would have to occur to narrow it down.
Feb 02, 2008 | RCA HD52W56 52" Rear Projection HDTV
RCA HD61W66 61" Projection HDTV Logo
159 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
