Question about Samsung WA400PJHDWR
Codes reset for samsung washer - Samsung WA400PJHDWR
My Samsung washer is throwing a code looks like a BE code how do I reset it. All I do is turn on the washer and in 20 second the code comes up with out touching anything
You can try plugging the washer from the outlet. Turn on the power knob on the washer for a couple seconds to release any stored power, then turn power knob off. Plug washer back in the wall outlet to see if this resets the code back to normal.
Apr 03, 2015 | Samsung Washing Machines
My samsung vet washer is reading a code 5 what could it be?
If it's an AE5 then it's a communication error between the LCD PBA and the MAIN PBA and you should call customer service.
1-800-726-7864
Sep 11, 2014 | Samsung 3.5 cu. ft. High Efficiency VRT...
Samsung washer reset
sound like module problem try to remove all the conection connecting the module and connect maybe after 30 mins.
Nov 06, 2013 | Samsung WF218AN Front Load Washer
WF328 AAG OE error code...how do reset this? or can I reset this?
The code OE is a draining error. The washer has sensed that the water has not completely drained all of the water within 10 minutes and will display this error code.
  1. Locate your drain pump access door on the front of the machine.
  2. Clean out the filter area.
If you are unable to resolve the issue by cleaning, I would recommend replacing the drain pump.
Jan 24, 2011 | Samsung WF328AA Front Load Washer
Washer error code
try a hard reset *2767*3855#
Jun 15, 2008 | Samsung SGH-E900 Cellular Phone
Samsung washing machine reset code
i have samsung
6 kg WA80HAG silver nano
dear'
plz help me to reset washing
machine
thanks
Mar 18, 2008 | Samsung WF337AA Front Load Washer
Samsung WA400PJHDWR Logo
203 people viewed this question
Top Samsung Washing Machines Experts
Jaime Hernandez
shaun taylor
Are you a Samsung Washing Machine Expert? Answer questions, earn points and help others
