Question about Vizio P50HDTV20A 50 in. Plasma HDTV
Is there a fuse in tv
No power to tv outlet ok
  • Vizio Master
  • 9,639 Answers
Fuse is located on the power supply board inside the TV.
Posted on Nov 17, 2014
Tv does not turn on, after a thunder storm.. tv was off during storm.. but heard a click as if I was turning off tv.. Blueray player , ok Direct tv box ok , all come on that was connected to tv... whi
during thunder storm, is your TV connected to wall outlet, if it so your set have a problem on power supply, you are lucky if is only a blown fuse.
Aug 06, 2014 | Televison & Video
Have lg tv model 26ld350 and will not power on. Have checked outlet and power cord and they are ok. Does this tv have a fuse? Appreciate any assistance.
Yes,the power supply board have a fuse near the edge of the board.That the board,where the power a/c cord plug into it.
Mar 25, 2011 | LG 26LD350 26 in. TV
Television has no power. outlet has power and cord from outlet to television has power. is there a fuse?
All telivisions has fuses inside. Some of them has one, and some has two. If your tv doesn't power on, and power chord and outlet is ok, surely the fuse inside may blown out. There may be some reason for the blowing of fuse. Fuses are used inside tvs are for protection purposes. f any overvoltage or over current taken by the system, the fuse will blow out. you must fist find out the resom for the bowing of fuse. New fuse must be put in only after that check. Otherwise you will spoil the whole circut board inside the tv irrepairable. Concat a service personnal, and let him do that. Ok.
Remember, different tvs have different power ratings. Must select proper fuse according to the ratings.
Oct 13, 2010 | RCA 32F531T 32" TV
SAMSUNG LN52B610 TV TURNED OFF BY ITSELF. CANT TURN TV ON. NO RED LIGHT ON TV FOR POWER. OUTLET WAS CHECKED AND HAS POWER. CORD IS IN GOOD CONDITION. PLUGS FIR SNUG IN...
Hello.
If you have multimeter available you can actually check if voltage present at the end of your power cord first.
If it's OK than you have to remove back cover from your TV and locate power supply board. It's very easy - it should be next to the power cord receptacle. First look for capacitors that have bulged tops instead of flat ones. If you locate any - replace them and check if it's going to take care of problem.
Right next to receptacle connection is fuse located and you have to check if it's open. Replace it if needed. If new fuse got blown right away - you have short in power supply board. If fuse is OK - connect power cord and using multimeter try to figure out if 5V is supplied from Power supply board to the main board (the one that have all inputs attached to it). If 5V is present but power LED in front of the TV is still dead - you could have problem with main board.
Best regards.
Russ.
Aug 17, 2010 | Samsung LN52B610 52 in LCD TV
Tv turns off and dont want to turn on again
check outlet power by connect other device, check power cord if OK check then unplug tv and open the back cover and check power filter fuse power filter is the one that you hooked power cord if OK check power supply board fuses if OK check the power supply board for bad blown components .good luck
Apr 29, 2010 | Westinghouse LTV-32w1 32 in. HD-Ready LCD...
No picture or sound
Does it have power LED on/blinking? Any clicking sounds from inside when you connecting TV's power cord to the wall outlet? If it's completely dead - check power outlet in the wall, check power cord with multimeter, than open up rear cover and check fuses with multimeter. If they are OK - you need professionals diagnose it. Repair will start with power board replacement.
Mar 10, 2010 | Vizio VP422 42 in. Plasma TV
Tv won't turn on
check one by one :
1. power in outlet by plugging an other equipment in the outlet used for your TV,
if ok try #2
#2: carefully open the back and check the power cable with ohmmeter
if ok , try #3
#3. check for the fuse ,
if ok , call a technician because there is some fault which you can't do by yourself
Sep 14, 2009 | Televison & Video
There is no power to my TV. I have checked fuses and sockets and they are all working
plug something else into that outlet to see if there is power there. if there is no power you should replace the fuse anyway as sometimes the fuse looks ok when it is not.
if there is power at the outlet plug the tv back in and try it again. if it won't start up the problem is likely in the start button.
Jul 11, 2009 | LG Flatron L1750S 17" LCD Monitor
I have an emerson tv and it will not power on at all. The little light wont even come on.
Solution 1 was just step 1. If the outlet gets power and the fuse or circuit breaker is ok, then U have a bad tv. That seems to be the most common problems with lcd's when they go bad. They either give the blinking light and not coming on, or they go completely dead. Most common causes are a bad power supply or a bad board/PCB/Circuit board.
Apr 20, 2009 | Emerson EWL3706 37 in. LCD Television
My TV does not turn on I have a Mitszubushi 60 Inch
The first thing to do is check the outlet that it is plugged into.
Do you have a gfci outlet that may have tripped?
Sometimes the whole circuit that the tv happens to be plugged into may have tripped at the electric panel.
Chek for a blown fuse or tripped circuit breaker.
If that is ok, check inside the tv for a blown fuse close to where the power cord is attached.
If still no power, then it will take a checking of the power supply/power circuit board, which may be something a service person should check into.
Apr 08, 2008 | Televison & Video
Vizio P50HDTV20A 50 in. Plasma HDTV Logo
Top Vizio Televison & Video Experts
CoppellTVRepair.com
Computer Repairing
Computer Repairing
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
