Question about E-Machines T2642 PC Desktop
Switch wiring to motherboard - E-Machines T2642 PC Desktop
  • E-Machines Master
  • 10,045 Answers
Go to E machines web site and download the mother board diagram
Posted on Nov 17, 2014
WHERE DO I CONNECT THE PWER SWITCH PIN ON WINFAST MOTHERBOARD
hai, i am using winfast motherboard pc and i was remove my cpu all wire so please tell me about how to connect the power switch wire and restart wire
Oct 28, 2012 | Foxconn WinFast K7S741MG Motherboard for...
The power button on my acer aspire ex1300 is not working? How do i fix it?
Open the case, and look at the switches on the front-panel.
Trace the wires from the ON/OFF switch down to where it connects to the motherboard.
Ensure that the wires ARE connected to the CORRECT pins on the motherboard.
It's possible to purchase a replacement switch, and connect its wires to those pins on the motherboard. Any "electronics" shop (oriented towards business needs, such as home-builders) will sell you a switch.
Mar 02, 2011 | Acer Computers & Internet
I am about to switch out the motherboard for m5640 aspire 1
New motherboard will have a picture of the pin connections and where they connect on the motherboard. Just follow these connections, also the wires leading from the from the front of the case to the motherboard are labelled as to what they connect to. As a final note, the white wire on the connectors is usually always the ground wire, so look at the drawing carefully to see which side is the positive and make sure that the coloured wire goes to the positive side not the white.
AS ALWAYS INFORMATION IS FOR EDUCATIONAL PURPPOSES ONLY AND WHAT YOU DO WITH IT IS UP TO YOU.
Dec 18, 2009 | Acer Aspire m5640 PC Desktop
How do Iplug the power switch wires in the corect place on the mother board? for the emachine T2824
Hi.
Did you try to open your CPU casing to find the socket in your motherboard witch is totally fix with the power switch wire. The power switch wire are two forms, there is a 20 pins and 24 pins. If your power switch socket is only a 20 pins, you need to put only the 20 pins.
The 24 pins is not totally combined in power switch wire. If your motherboard power socket contains only 20 pins, so remove the 4 pins in your power switch wires. "Good luck!!"
Hope it may helpful for you!
Regards
ICmanServer
Jul 31, 2009 | E-Machines Computers & Internet
Tried new power supply but didn't help. (Who knows - maybe I didn't install correctly.) I first thought it was the power switch on front of machine. Was wondering if some easy test for power switch?
Tips from me:
1.If your power supply isn't coming on, I advise you to check the 20/24-pin motherboard power cable,
connector, and be sure it's down in tight. Make sure that lock tab of the power cable connector, snaps over the motherboard connector lug. Make sure that connector is in all the way.
2.Be sure the wires that come from the Power On switch, and go to the motherboard, are connected, and down all the way. The connector, or individual connectors, need to be down on those motherboard pins all the way. (The area on the motherboard where they connect, is called the Front Panel header. A connector on a motherboard is called a Header)
Also make sure both wires from the Power On switch, (Button), are connected to the motherboard, if the wires have individual connectors.
Now, how to test to see if the Power On switch is bad.
The 20/24-pin ATX motherboard power cable connector comes in three styles.
A.20-pin connector. Has two rows of 10 socket holes
B.24-pin connector. Has two rows of 12 socket holes
C.20-pin and a 4-pin connector.
NO matter what style it is, it has a Green wire going to that connector. The Green wire is the
Soft Power On wire.
With the motherboard power connector plugged into the motherboard, and the computer plugged into the surge protector, you need to jump that Soft Power On wire, to a Ground wire.
View these photos of a 20-pin ATX Main power cable. (Motherboard power cable, Main power cable.
Same/same)
http://www.playtool.com/pages/psuconnectors/connectors.html#atxmain20
Look at the photo all the way to the right. (You can save this page, and bring it up in a new window)
This shows that Green wire. Fourth one from the left.
Next to it is a Black wire. Fifth one from the left.
ANY Black wire is a Ground wire.
You need to make a jumper wire. This wire should have insulation on it. It should be as thick as those power cable wires. It should be about 3 inches long. You need to strip off 3/4ths of a inch of insulation, off of EACH end. Twist the exposed wires. Make a tight wrap. Bend this wire into a U-shape.
At this point you may want to don a protective rubber glove. Tightly fitting dishwashing glove, or perhaps a surgical style one. Reasoning is, that there will be a spark. You may feel more safe this way. I don't use one, but I'm an old tech, and maybe not too Tightly Wrapped! lol! (I also was a journeyman lineman, so this spark doesn't bother me!)
With the ATX motherboard power cable plugged into the motherboard, you are looking at the back of the connector. The wires go down into a socket. At the end of every wire is a metal terminal end.
It's pretty far down in there. One end of your jumper wire, goes down deep into the Green wire socket. It needs to touch that metal terminal end.
The other end of your jumper wire, needs to touch a Ground wire terminal end. ANY Black wire is a Ground wire. Just stick the end down into a socket with a Ground wire. Hold it there for about 1 to 2 seconds, bring the wire back out. You just want to make a Momentary Contact.
Your power supply should start.
If so, you have a bad Power On switch. If not, your problem is the power supply, or the motherboard.
Apr 19, 2009 | E-Machines eMachines Desktop PC
I can not remember where wires go
all the configuration should be printed on yur motherboard....maybe.....?
Mar 08, 2009 | EliteGroup P4VMM2 Motherboard
Wiring connections
Here is the website to find and download a manual which will have the wireing contacts on the board identified.
http://downloadcenter.intel.com/NotFound.aspx?NoMatch=rg82845e〈=eng#
Dec 29, 2008 | Intel Motherboard
Wiring
see the picture below:-
Sep 07, 2007 | MSI 694T PRO (6309-470) Motherboard
E-Machines T2642 PC Desktop Logo
Top E-Machines Computers & Internet Experts
Alun Cox
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
