Question about Vacuums
Genesis hydrovac extreme thin wire from the amshire/motor to brushes when switch on sparks and broke off
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 105 Answers
You're going to need to have to get the motor repaired at an electric motor shop
Posted on Nov 24, 2014
Replace belt genesis upright
Turn vacuum upside down on flat surface, remove the 6-7 screws from the bottom of the power nozzle, lay it on it's side and pry on the two accessible internal tabs to pop top cap of the nozzle off to access the pn motor assembly. Lay flat on it's back again and remove the screws that hold the roller brush in, remove the roller brush, remove old belt, install new belt on brush roll and pn motor geared spindle, push brush roll back in place, replace screws and pn top and VOILA!..you're back in bidness! Hop that helps!
Jun 25, 2014 | Electrolux Vacuums
Vacuum just quit, while in use
If the Power from the wall receptacle was OK, and you did not trip a circuit breaker, then the motor may have shut down or the on/off switch broke. Usually your house power would go out if a short circuit occurred while plugged into the house current. Check all wires, and smell the housing for any burn odor. Look at the brush for accumulated matter that collected and stopped the motor and brush from moving. Clean if necessary.
Apr 03, 2014 | Royal 2028 Classic Household Upright...
The belt is fine and tight but when you turn on vacuum the motor doesn't spin at all to turn the brushes
You will have to see if there is power getting to the motor and if so maybe it is burnt out. Could even be a bad switch.Make sure your receptacle is working where you plug it in. Also check your wiring as well as the plug. sometimes a wire could be broke.
Feb 27, 2014 | Electrolux EL8502 Versatility Bagless...
Power goes on and off.
It could be three different things- or one or more of these three, but more than likely just one.
1- a bad cord or plug end
2- a bad switch
3- a motor brush is losing contact due to poor pressure due to the carbon brush being worn- of the two motor brushes, their length is normally sufficient to last for years with trouble free service. However, if a vacuum is neglected, as in the filters never cleaned or replaced ( use 10/ $2.99 electrostatic register vent filters from any home store's furnace filter section. Cut to fit, and in the case of the Hepa filters, if you have a dusty family you'll go broke changing these so just cut your electrostatic ones and maybe stack a layer or two, but since they are cheap be liberal and change often). What happens with dirty neglected vacuums is they overheat causing the motor brushes to glaze the copper commutator they ride on and eventually wear out the carbon. The added brush dust cakes up and acts as an abrasive.
Alright, so it's not an issue of neglect or jerked on cords? Well, unfortunately several manufactures have lately installed somewhat inferior switches on their vacuums by way of saving a few cents in manufacturing costs. The amperage ratings on the switches are rated just above the typical 12 amp motor ratings on the vacs motor. In real world use though the strains of suction resistance and cord resistance caused by ultra thin copper wire in the cord add up to extra heat at the switches terminals. The plastic in the switch will get very hot as you vacuum and when you flip the switch off each time you finish vacuuming it literally shifts the switching contacts into positions a little more distorted from their original setting. Arcing is the next thing that happens and then its a heated plug end.
That's the story of how a vacuum cleaner works when it's stressed and strained. Ironically when all of this goes on the bearings also overheat due to the arcing motor brushes. And because the belt for the roller is on this motor as well, when you shut the vac off the belt will heat up and even melt slightly. Then when you go to vacuum again the belt will vibrate causing more damage...
This is why bag vacuums are better.
Better yet, get a Rainbow D4 and ALWAYS ALWAYS ALWAYS spin the separator by hand to assure the brushes are not sticking before powering it up. The D4 is the best vacuum ever made. The Eureka Vibragroomer is the best upright ever made.
Oct 07, 2009 | Vacuums
No power. electric is OK. system will not turn on. Please help
Detach the vac itself from low voltage thin wiring leading to the house. With the vac plugged into power, try the manual switch and then try shorting across the low voltage exterior terminals with a rubber gripped set of pliers.
If you can hear a clicking inside, this is the vac's relay trying to start the motor. If the vac is more than 5 years old , or used more than 2 hours a week, you may need new carbon brushes, or a motor overhaul or replacement depending on wear. Carbon brushes are specific to the motor model # inside the vac, most often an AMTEK Lamb motor.
If you need brushes, the motors comutator should also be inspected for excess,wear, like gap ing between its conatct segments and "apple core" shaped wear
You you have a meter and can test for continuity across the motor leads, do so and post back.
If you don't have a meter, you will likely want to lift the vac off the wall after these checks and take to a repair shop, saving $$$$ for a house call...
Oct 06, 2009 | Broan-NuTone CV353 Central Vacuum
Sparks in the el. motor of Electrolux Canister.
check the wiring it might have gone bad
Jul 07, 2009 | Vacuums
Eureka Capture 8803AVZ - EXTREMELY loud
Had it checked for the noise. Motor bearings go out after a few months is what the AUTHORIZED repairman said. Toss it.
Mar 05, 2008 | Vacuums
Kenmore canister vac model 116. 2641381
Sounds like motor brushes may be going. Is the vacuum cleaner old? I suggest bringing the unit in for service to replace the motor brushes. Get a quote to see if is worthwhile to fix.
Feb 27, 2008 | Kenmore 22812 Bagged Canister Vacuum
Vacuums Logo
81 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
