Question about Refrigerators
Remove and replace filter housing assembly on samsung rfg298hdwp
2 Suggested Answers
  • 126 Answers
SOURCE: how do I remove and replace the headlight housing assembly?
it has three 10mm bolts and one alignment pin.
Posted on Apr 28, 2009
L200 Saturn 2002. Where is the blower fan located for the heat and ac?
It's in the engine compartment. See removal instructions below from autozone.com.
  1. Select the following settings:
    Turn the ignition ON Select Recirc in the OFF setting Turn the ignition OFF
  2. Disconnect the negative battery cable.
  3. Remove the wiper arm assemblies.
    CAUTION A sharp edge is revealed once the weatherstrip is removed.
  4. Remove the weatherstrip at rear of the engine compartment.
  5. Remove the cowl retaining nuts.
jturcotte_564.gif Fig. Remove the cowl screen assembly
  1. Remove the cowl screen assembly.
  2. Rotate the locking tabs outward to release the filter assembly.
  3. Remove the filter by lifting straight up.
jturcotte_567.gif Fig. Remove the wiper module retaining bolts
  1. Remove the wiper module retaining bolts.
  2. Reposition the wiper module to the right.
  3. Remove the filter housing attachment bolts.
  4. Remove the filter housing.
  5. Remove the blower motor housing:
  6. Remove the blower motor housing screws
Fig. Release the locking tabs and remove the fan housing
  1. Release the locking tabs and remove the fan housing
  2. Disconnect the blower motor electrical connector.
  3. Squeeze the bottom of the connector and pull downward.
  4. Remove the blower motor assembly by lifting straight out.
Dec 20, 2010 | 2002 Saturn L-Series
How to remove and install a new heater blower motor 2000 Saturn
Removal & Installation
  6. Remove the cowl screen assembly.
  7. Rotate the locking tabs outward to release the filter assembly.
  8. Remove the filter by lifting straight up.
  9. Remove the wiper module retaining bolts.
  10. Reposition the wiper module to the right.
  11. Remove the filter housing attachment bolts.
  12. Remove the filter housing.
  13. Remove the blower motor housing:
  14. Remove the blower motor housing screws
  15. Release the locking tabs and remove the fan housing
  16. Disconnect the blower motor electrical connector.
  17. Squeeze the bottom of the connector and pull downward.
  18. Remove the blower motor assembly by lifting straight out.
To install:
NOTE The fan motor assembly rib must be located into the channel in the module housing.
  1. Install the blower motor assembly into the module housing.
  2. Connect the blower motor electrical connector.
    NOTE The housing rib must fit into the slot in the HVAC module case.
  3. Install the blower motor housing. Snap the left and right clip into place
  4. Tighten the fan housing to blower motor housing screws to 9 inch lbs.(1 Nm).
    NOTE A new filter housing seal must be used whenever the filter housing is removed to prevent water from leaking into module.
  5. Remove the filter housing seal using a small flat-blade screwdriver.
  6. Install a new filter housing seal.
  7. Install the filter housing.
  8. Install the filter housing screws, and tighten the screws to 31 inch lbs.(3.5 Nm).
  9. Position the wiper module.
  10. Install the wiper module bolts, and tighten the bolts to 44 inch lbs.(5 Nm).
  11. Install the passenger compartment air filter. Notice the air flow direction indicator printed on side of the filter.
  12. Rotate the locking tabs on the filter housing inward to secure the air filter in place.
  13. Install the cowl screen.
  14. Install the cowl screen nuts, and tighten the nuts to 9 inch lbs.(1 Nm).
  15. Close filter access door.
  16. Install the weatherstrip at rear of the engine compartment.
  17. Install the wiper arm assemblies.
  18. Connect the negative battery cable.
  1. Disconnect the blower motor electrical connector.
  2. Remove the lower blower motor cover retaining screws.
    Fig. Remove the lower blower motor cover
  3. Remove the lower blower motor cover.
  4. Remove the blower motor nuts.
    NOTE Cut through the case as straight as possible because the motor cup must be replaced.
  5. In order to prevent damage to the component, do not cut any deeper than necessary to remove the motor cup.
  6. Remove the blower motor and cup from the lower case by cutting through the case between the circular ribs around the motor with a sharp utility knife.
  7. Release the blower motor retaining tab and remove the motor from the cup.
To install:
  1. Install the blower motor into the motor cup that was cut out of the lower case.
    Fig. Install the blower motor (1) into the motor cup (2) that was cut out of the lower case
  2. Install the blower motor nuts, and tighten the nuts to 21 inch lbs.(2.4 Nm).
  3. Attach the service ring to the motor cup with the screws included in the kit, and tighten the screws to 15 inch lbs.(1.8 Nm).
  4. Install the blower motor and service ring into the HVAC module using the screws included in the kit. Make certain the blower motor electrical connector is pointing rearward in the vehicle, and tighten the screws to 15 inch lbs.(1.8 Nm).
  5. Install the lower blower motor cover.
  6. Install the lower blower motor cover retaining screws, and tighten the screws to 15 inch lbs.(1.8 Nm).
  7. Connect the blower motor electrical connector.
Hope this helps (remember to rate and comment this).
Oct 04, 2010 | 2000 Saturn Ls 4dr Sedan
Need diagram for serpentine belt
2004 SUZUKI FORENZA - L4 2.0L 2000cc GAS FI N
Adjustment
The belt is automatically adjusted by the auto tensioner.
Drive Belt Routings
Fig. Accessory drive belt routing-2.0L engine
  1. Remove the air filter housing assembly bolts and the air intake tube.
  2. Remove the air filter housing assembly from the vehicle.
  3. Use a wrench to turn the tensioner bolt clockwise, compressing the tensioner, and releasing the tension on the serpentine accessory drive belt.
  4. Remove the serpentine accessory drive belt.
To install:
  1. Use a wrench to turn the tensioner bolt clockwise, compressing the tensioner, and releasing the tension on the serpentine accessory drive belt.
  2. With the wrench in place on the tensioner bolt, loop the serpentine accessory drive belt loosely over the pulleys.
  3. Slip the belt over the tensioner.
  4. Remove the wrench from the tensioner bolt and the belt will tighten itself.
  5. Install the air filter housing assembly into the vehicle.
  6. Install the air intake tube and the air filter housing assembly bolts.
  7. Tighten the air filter housing assembly bolts to 53 inch lbs. and nm
I really hope helped with this. remember rated this help. Good luck.
Nov 12, 2009 | 2004 Suzuki Forenza
Where is the fuel filter on a turbo desail
Your fuel filter is mounted on the rear of intake manifold, under air cleaner or on rear firewall.
Just a little hint on replacing it, remove your fuel tank cap to release pressure or vacuum in the tank. I'm sending you a diagram the fuel filter assembly so it will make it a little simpler for you to replace your fuel filter. Start by removing the filter element nut. Remove filter element by lifting straight out of filter housing. It is not necessary to drain fuel from filter housing when changing the filter element.
Installation, ensure mating surface between filter element assembly and filter housing is clean. Install new filter element by aligning widest key slot located under element assembly cap with widest key in filter housing assembly.
Tighten element nut by hand. Bleed air from fuel manager/filter assembly. Connect a hose to air bleed valve and place other end of hose in a container.
Disconnect fuel injection pump shutoff solenoid wire. Crank engine for 10 to 15 seconds. Allow starter to cool down for one minute between cranking intervals. Repeat procedure until clear fuel is observed at the air bleed hose.
Close air bleed. Connect injection pump shutoff solenoid wire and reinstall fuel filler cap. Start engine and allow to idle for five minutes. Check fuel manager/filter for leaks.9df1ca0.gif
Oct 03, 2009 | 1994 Chevrolet C/K 2500
How to change cabin filter in 2006 Honda Odyssey EXL model
Remove the glove box housing. Remove the dust and pollen filter assembly from the evaporator. Remove the filter from the housing, and replace the filter. Install in reverse order.
Jul 10, 2009 | 2006 Honda Odyssey
Replace headlight for 2005 Chev Trailblazer
59Shadow.
Thank you for sharing the information on the light bulb. You just saved me money from having to take my 2003 Trailblazer in to have the low beam bulb replaced. I did exactly what you said.
1 Open hood and lock.
2. Take filter cover off (4 screws and they stay with the filter).
3. 3 inch cover pulls off.
4. Twist light bulb 1/8 turn.
5. Unclip the wiring harness to light bulb assembly.
6. Test by turning light switch on.
7. Align assembly with light housing and turn 1/8 until it snaps in.
8. Put 3 inch cover back on.
9. Place filter cover back on and hand tight the 4 screws.
10. Close hood.
Dec 12, 2008 | 2005 Chevrolet TrailBlazer
Refrigerators Logo
43 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
