Question about Cameras
My Canon 480EG Speedlite cannot any longer being fired neither with the camera coiled cord nor of sync cord nor the slave connector. When connected to battery pack it charges and can be fired pressing the test button but I unable to fire it on normal camera setting. I contacted Canon and they no longer care on this product. What can I do? What can happened to it? Where can I find service for it?
5 Suggested Answers
  • 216 Answers
SOURCE: Nikon SB-800 Failure
Check by testing flash that I've posted on 1/15/08
atdlee@netzero.com
Posted on Jan 15, 2008
SOURCE: Novatron 240 Flash Kit
First you need to isolate the problem by doing some troubleshooting.
1) try a known good sync cord to determine if the problem is the sync cord and not the power pack.
2) try a known good sync cord with a known good camera to determine that the problem is not in the camera.
3) try your camera with a different power pack to confirm your camera is triggering the power pack OK.
These steps will isolate the source of the problem.
Posted on Oct 06, 2008
SOURCE: Canon speedlites 550EXII and 550EX Set up for master and slave units in TTL
From what I've experienced the slave need to be set to B-1. Don't know why.
Posted on Nov 04, 2008
  • 57 Answers
SOURCE: 580EX speedlite not firing
Does the pilot lamp light up? If so can you fire it manually by pressing on it? If the batteries are low it may simply just be taking a while to charge, the camera will not wait for it to be ready to fire and it may seem to be not working. If your flash can be fired manually however, there may be a problem with the cameras shutter or the hotshoe. You can do a basic check by pressing the star button at the rear of the camera, you should get a pre-flash. If not, there is a problem with the cameras hotshoe which you will need addressed by a service centre. If you get a preflash you can next check the cameras shutter by setting the second curtain to sync with the flash. This can be done via the cameras "Custom Function" menu, c-Fn 15. Set the camera to TV mode and chose a 1 second exposure. Take a shot with the flash attached, if the shutter is working correctly, the flash should fire a pre-flash and then a main flash. If it doesnt, the switch inside the shutter is broken and the shutter needs to be replaced. This is a pretty labour intensive repair and you may consider an upgrade as more economical.
Posted on Apr 15, 2009
Canon Speedlite 580ex ii - won't work with camera
Caroline, you should try to set the camera on "M" and the flash in 2nd curtain flash sync.
Or set flash in ATG wireless IR ETTL Slave modes and pop-up the flash on Canon EOS-70D.
Truly,
atdlee@netzero.com
Feb 08, 2014 | Canon SPEEDLITE 580EX TTL Flash
My speedlite 480 eg seems to hot is any setting for 10' indoor facial shots. How do I cool it off?
you are kidding???? that flash is 6000 degrees kelvin? as hot as the sun? i gess your trying to blind some one?
Nov 28, 2010 | Canon Speedlite 480EG TTL Flash
Can I use it wirelessly with a canon EOS 40D
Yes you can but it won't TTL and you will need to fire it from or with a slave/light cell. This will make your system more like a studio set up. You will need to increase/decrease the light intensity using different modifiers for special effects. My portable/location set up uses 2 Vivitar 283's, a Canon 533G, Nikon SB 15 and a Canon 420 EX all fired from little flash slaves. here is an e-Bay reference link
http://cgi.ebay.ca/Flash-Slave-Trigger-Hot-Shoe-Sync-Adapter-Sensor-US-/110405132832?pt=LH_DefaultDomain_0&hash=item19b4a8a220
Hope this was a help
May 19, 2010 | Canon Speedlite 540EZ TTL Flash
Only get one flash when using slave
Yeah you should go into the menu on your camera and see if there is anything you need to change!!
Apr 02, 2010 | Canon Speedlite 430EX TTL Flash
Trigger a Speedlite 430EX II with a studio flash
  1. Make sure the trigger you are using is compatible with digital flashes.
  2. isolate the smaller contact so they do not "short out" on the trigger.
  3. make sure the trigger is working and will fire other flashes
Nov 03, 2009 | Canon Speedlite 430EX TTL Flash
Can the Canon speedlite 430EX be the slave to the 550EX speedlite
Most any slave light will work I use a old vivitar flash with a slave module in the cord to camera outlet woks gook for a fill light. helix camera .com ritz camera. or ebay don't digital flashes a little different than strobes i played with the settings until i got the desired lightng I wanted., if your camera has a hot shoe you can get a slave to fire an external flash with it.hope i helped
Dec 27, 2008 | Canon Digital Rebel / EOS-300D Digital...
Canon Speedlite 580 EX II
is your master flash set on a camera? The EX II has something that makes it have a 1 second delay when using sync mode, unless the master flash is set on the camera.
Dec 27, 2008 | Canon Speedlite 540EZ TTL Flash
Remote Firing of Flash Units
The EOS 40D does not have a transmitter built in. The remote flash units must be set to "Slave" and the on-camera external flash unit (eg Speedlite 580EX) or transmitter (ST-E2) set to "Master". Note that the Speedlite 430EX doesn't have the function to act as Master and you need a minimum or the 580EX or a ST-E2 speedlite transmitter (or similar) as Master/s.
Jul 29, 2008 | Canon EOS 40D Digital Camera
Canon Speedlite 580EX
if u set the 580ex on master and the 430 EX on slave it works :) u dont need STE2 for this simple task.
Oct 18, 2007 | Canon SPEEDLITE 580EX TTL Flash
Wont work
According to the Canon feature chart I have here; the 540EZ Speedlite flash is not compatible with the Digital Rebel XT in ETTL mode. The 480EG is also not compatible. The 550 or any of the others in that product line are would work. David Millier Advance Camera Repair
Feb 26, 2007 | Canon Speedlite 540EZ TTL Flash
Cameras Logo
102 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
